can you mix blast media? #2393162
10/26/17 12:13 AM
10/26/17 12:13 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I have a small blast cabinet and have some aluminum oxide media in it and was wondering if I could mix glass bead media in with it or is that a no no?
Re: can you mix blast media? [Re: gregok] #2393219
10/26/17 02:09 AM
10/26/17 02:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Of course you can BUT I would think it's a BAD idea. To me it would be the same as putting two different grit sandpaper side by side on a sanding block. The more course grit will always be dominant and you will get a somewhat uneven finish to whatever you're blasting IMO. Kind of like how the finish is different with new glass beads versus the finish is with worn out and contaminated glass beads. I used a bead blaster at work for over 25-years and always used as fresh media of one grit as possible. Always disposed of the existing media then added all new media of one grit. Just me.
MikeR
Re: can you mix blast media? [Re: A12] #2393327
10/26/17 01:10 PM
10/26/17 01:10 PM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
Thanks Mike, just wanted a learned opinion.
Re: can you mix blast media? [Re: gregok] #2393472
10/26/17 06:22 PM
10/26/17 06:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
First, I wouldn't mix media. Second, I wouldn't bother with glass ever again. The aluminum oxide leaves such a nice finish I can't see the point in using glass. Furthermore, next to diamonds, aluminum oxide is the hardest substance on the planet so as a blast media it literally never wears out whereas the glass beads shatter into powder and create a ton of dust and need frequent replacement. There is a reason aluminum oxide is expensive !!
Re: can you mix blast media? [Re: gregok] #2394559
10/29/17 01:51 AM
10/29/17 01:51 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
silicon carbide is harder than alox and is a blast media.
#1 reason not to re-use media is contaminants, you don't want to use rust and dirt as a blast media, so even though your media lasts a long time its full of crap and it needs to be changed often. Unless you have a cyclone for removing dirt/paint/rust i would just change the media on a regular basis.
brown aluminum oxide has silica in it as well so not a good plan in a enclosed shop with no outside venting
Re: can you mix blast media? [Re: gregok] #2398954
11/05/17 06:02 PM
11/05/17 06:02 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My blaster guy mixes a blend of walnut shells, glass beads and plastic media for doing whole cars, works quite well and he avoids the large flat surfaces so they don't get wavy from the peening and heat. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: can you mix blast media? [Re: gregok] #2399347
11/06/17 02:05 PM
11/06/17 02:05 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've used mixed sands many times, works perfectly fine. It's not like using different grit sandpapers... you have how many grains of sand constantly flowing, not glued to paper in a fixed spot.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
