Re: Need Gen 1 CTD help
[Re: Mr. Smurf]
#2398594
11/04/17 11:27 PM
11/04/17 11:27 PM
Posts: 2,094 Byron, NY
W.I.N. Racing
Byron, NY
First check continuity of the grid...don't know what the resistance should be but open is bad... have you checked for power to the grid? Is the Relay clunking(mine always made a pretty loud actuation noise) - if not check for power to the relay. Test for a signal to the switching side of the relay (low amperage side)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Mr. Smurf]
#2399425
11/06/17 04:10 PM
11/06/17 04:10 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
Check for codes first before anything. Turn the ignition on, off, on, off, on. Watch the check engine light it will flash 2 digit codes. 55 is the end of the sequence.
11 No Crank Speed sensor signal during cranking 12 Battery connection disturbed within the last 50 starts 15 No signal from VSS (Auto or Cruise Control equipped only) 22 Coolant temp sensor shorted or open (Auto only) 23 Air temp sensor shorted or open 24 TPS shorted or open (Auto only) 33 A/C clutch relay shorted or open 34 Cruise control shorted or open (cruise control equipped only) 41 Generator field not switching properly 42 ASD relay (charging circuit supply) shorted or open, or no ASD voltage at PCM 45 OD solenoid shorted or open (Auto only) 46 Charging system voltage too high 47 Charging system voltage too low 53 Internal PCM failure 62 same 63 same
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
