#2398572 - 11/04/17 08:21 PM Need Gen 1 CTD help
Mr. Smurf Offline
Loc: Mid Michigan
The intake heater grid on my 92 W350 has decided to quit working, the dash light cycles, but nothing happening under the hood.
All the connections are clean & tight, I've no clue where to go next.
Any help is appreciated.
Ed
#2398594 - 11/04/17 09:27 PM Re: Need Gen 1 CTD help [Re: Mr. Smurf]
W.I.N. racing Offline
Loc: Byron, NY
First check continuity of the grid...don't know what the resistance should be but open is bad...
have you checked for power to the grid?
Is the Relay clunking(mine always made a pretty loud actuation noise) - if not check for power to the relay. Test for a signal to the switching side of the relay (low amperage side)
FOR SALE'02 D1500, Blown/Inj KB, Veny Heads,Bruno/CS2,Dana 60 FOR SALE
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T8
'60 Willys CJ5
'01 International LPX - Project, 8.3L Cummins, Allison 2000
'64 Plymouth Valiant S/P, 528 Hemi, 2spd
#2399169 - 11/05/17 11:13 PM Re: Need Gen 1 CTD help [Re: W.I.N. racing]
Mr. Smurf Offline
Loc: Mid Michigan
Haven't had a chance to look at it yet....hopefully tomorrow.
Thanks for the input.
Ed
#2399425 - 11/06/17 01:10 PM Re: Need Gen 1 CTD help [Re: Mr. Smurf]
Guitar Jones Offline
Loc: in a cattle trailer down by th...
Check for codes first before anything. Turn the ignition on, off, on, off, on. Watch the check engine light it will flash 2 digit codes. 55 is the end of the sequence.
11 No Crank Speed sensor signal during cranking
12 Battery connection disturbed within the last 50 starts
15 No signal from VSS (Auto or Cruise Control equipped only)
22 Coolant temp sensor shorted or open (Auto only)
23 Air temp sensor shorted or open
24 TPS shorted or open (Auto only)
33 A/C clutch relay shorted or open
34 Cruise control shorted or open (cruise control equipped only)
41 Generator field not switching properly
42 ASD relay (charging circuit supply) shorted or open, or no ASD voltage at PCM
45 OD solenoid shorted or open (Auto only)
46 Charging system voltage too high
47 Charging system voltage too low
53 Internal PCM failure
62 same
63 same
The Scamp is sold, now just two old trucks.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc conversion. Hydroboost coming soon
'74 W200 Crew Cab 360, NP435, D44, D60 and NP205 divorced transfer case. Magnum 5.2 MPI coming soon.
#2399993 - 11/07/17 12:57 PM Re: Need Gen 1 CTD help [Re: Guitar Jones]
Mr. Smurf Offline
Loc: Mid Michigan
I did check the grid for continuity, all good there.
Will look at the codes tonight.
Ed
#2401979 - 11/11/17 01:24 PM Re: Need Gen 1 CTD help [Re: Mr. Smurf]
superwrench Offline
Loc: PORT ALBERNI , BC., CANADA
Really check the ground wire at the grid (the one under the bolt). They will go crusty . Otherwise, I'd suspect the solenoids on the left fenderwell.
66 SATELLITE 426 HEMI
71 CHALLENGER 496 6PAK R/T
68 GTX 440 AUTO
07 3500 Ram CTD
07 CHARGER
54 DODGE 1/2 ton PU
New best of 6.701 103.80 MPH in the 1/8th
And 10.81 123.84 MPH in the 1/4
#2402312 - 11/11/17 10:18 PM Re: Need Gen 1 CTD help [Re: superwrench]
Mr. Smurf Offline
Loc: Mid Michigan
Will do.
Haven't had time to get close to it, had to cobble a denso starter for the tractor tonight.
Ed
25,383 Registered Members
190,904 Topics
bench vise valve spring compressor psi checker, accurate?
by RapidRobert
07/19/18 01:34 AM
Wheels
by cudatom
07/19/18 12:01 AM
Dart Vinyl Top
by CUDASROCK
07/18/18 11:47 PM
Gen 3 Hemi Block Info
by DarrenB
07/18/18 11:02 PM
