#2397120 - 11/01/17 11:10 PM 5.9 Magnum oil dipstick issues, kinda long
poorboy Offline
Loc: Freeport IL USA
I'm building a 39 Dodge pickup on a 91 Dakota Chassis. I'm using a 5.9 out of a 97 Dodge truck.
I'm having an issue with the dipstick, it fits tight in the tube, and stops all together when it gets to the first curve on the rear sump pan. I've had the pan off and on 3 times now. First I tried to remove the dipstick tube, but it won't come out. I've tried to insert a 5/16" rod from the bottom and tried to drive it out, no go. Then I pounded a 1/4" round rod all the way through the tube (from the bottom first, then from the top). Even after the 1/4" round rod has passed through the tube, it feels like the dipstick is turning just before it enters the block, and when it gets to the curve in the pan, its facing the wrong way and can't follow the curve in the pan. With the pan off, the dipstick will go through the tube in the pan just great, and I know the tube in the pan is lined up with the dipstick tube because that 1/4" rod will pound through the dipstick tube from the top until it hits the curve in the pan. I can't understand why the 1/4" round rod goes through everything up to the curve in the pan, but the dipstick tube wants to turn as it enters the pan in such a way it won't go through the curved in the pan. The worst part was this combo of motor and pan were together in the last vehicle they were in. I believe the dipstick tube may have gotten bent in transit.
After fighting with it all day, I've cut the tube off about 2" from the block, if I can lay the stick horizontally flat, and go straight at the remaining dipstick tube, I can force the tube through the pan, but it has to be a straight shot, something that will never happen when the belts & radiator are in place.
Is there a kit I can add the dipstick to the side of the oil pan and plug off the original dipstick tube hole? Gene
#2397146 - 11/01/17 11:52 PM Re: 5.9 Magnum oil dipstick issues, kinda long [Re: poorboy]
rhad Offline
Loc: garnett kansas
years back some cars had a piece that was riveted to the side of the pan that the dipstick fit into,no idea if you could find one these days?,maybe a antique car restorer or summit???
seems i had a 383 out of a pickup that used some sort of pan mounted dipstick holder?,its been several years and whats left of my memory is fuzzy on some stuff
my ladder of success is missing some rungs
#2397587 - 11/02/17 09:36 PM Re: 5.9 Magnum oil dipstick issues, kinda long [Re: rhad]
Satilite73 Offline
Loc: Between Houston & Galveston TX
Actually, big block oil pans for '70's Dodge PU & vans are this way. Probably wouldn't be too hard to replicate on a different pan. None of the pieces are rare one off bits.
John
#2398174 - 11/03/17 09:07 PM Re: 5.9 Magnum oil dipstick issues, kinda long [Re: poorboy]
poorboy Offline
I found a Moroso Dipstick tube "#25970 kit" with a piece you weld into the pan, dipstick tube, and dipstick for just under $24 with shipping. Its suppose to be here Wed. Will see if it works.
The first response reminded me I had a 440 truck years ago with the dipstick in the pan. It leaked like a sieve, hopefully this works better then that one did. Thanks for the help guys. Gene
25,149 Registered Members
186,772 Topics
Mds delete question
by 68shifter
02/23/18 07:10 AM
Slant 6 Torsion Bars 622 / 623 Install Sides
by 360tripleblack77
02/23/18 06:33 AM
Oil priming a 440
by ozymaxwedge
02/23/18 01:35 AM
meziere flex plate for BBM to JW 2 speed
by qwkmopardan
02/23/18 01:30 AM
