Page 1 of 2 1 2 >
#2379665 - 09/30/17 10:13 PM E Body - Cars For Sale - 4th Quarter
moparts Offline
#2379784 - 10/01/17 07:27 AM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
LemonTwiist Offline
Loc: Mechanicsburg, PA
FOR SALE: Is this numbers matching engine 340 six pack AAR CUDA. It is FE5 exterior and red interior. It has an auto transmission, rally dash, AM/FM radio, front rubber bumper. There is no build sheet, but all numbers match on the engine, cowl, and radiator support. The transmission is not the original. It does have the original fender tag. The car has been featured in Carlisle for the AAR/TA reunion, Hemming's Muscle Car Magazine, and is an AACA Senior award winner. I also have an autographed glove box lid from Dan Gurney. You will not find a better example of a fully restored car anywhere. You can call me at 717-697-8367 for more pictures. PRICE $105,000.00
Edited by LemonTwiist (10/07/17 07:08 PM)
#2379993 - 10/01/17 01:41 PM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
Airgrabber Offline
Loc: Pewaukee,WI
Plymouth Cuda 2 Door Hardtop. This vehicle has undergone a complete rotisserie type restoration.Every area of the car has been restored.The rarity and collectability of the Plymouth 'Cuda makes it a smart investment.due to the following: *Original Broadcast Sheet *The significant number of factory correct and original parts *Low number of 'Cuda produced in this configuration *Original Shaker Hood *Black Billboard Stripe *The color combination. GB2 blue and black interior *High Performance Axel package w/ 3.91:1 ratio *Pistol grip 4-speed shifter *Console *Quick Ratio power steering with power steering cooler *High Capacity 26" Radiator *Outside RH & LH Chrome Plated Racing Mirrors LH Remote *Ralleye Instrument Cluster *Hood tie-down pins *Dual Chrome Exhaust Tips *Tachometer *AM Music Master Radio *Original ID Tag on RH Door *Original VIN and Trim tags *Radiator Core support and LH side of Cowl VIN Present *NOM or Trans, Correct Distributor, Alternator, Exhaust Manifolds, & Carter Thermoquad #4973 Dated 350 day of 1971 *Added Available Option Rim Blow Woodgrain Steering Wheel *Collapsible Spare Tire with Fill Canister and Jack Assembly *New Good Year Polyglass E-60-15 *New Powder Coated 15x7 Steel wheels with Original Stainless hubcaps
Edited by Airgrabber (11/21/17 02:11 PM)
Edit Reason: PRICE REDUCED
#2381246 - 10/03/17 11:29 AM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
roadrunninMark Offline
Loc: GA
SOLD!!!!
Wow, I hate to ruin the good run of beautiful ebodies for sale so far, but here goes: 1970 Plymouth Barracuda. I tried to save it but I think it is too far gone for me. Frame rails not in good shape and every floor piece is rotted through. It is a 318 auto car, no engine or trans., white w/ black vinyl top and black interior, power steering, 4 wheel manual drums, non a/c, standard gauge, console on floor, roll down back windows, open end rear. Still has grille with 3 or so horizontal pieces missing and a crack on the bottom main part; couple verticals need to be glued (should be fixable), 1 turn signal bucket with slight chip. All door glass is there. Has all door panels *weathered) and window cranks, driver's side mirror, console, top half of back seat, dash and gauges, glove box, ash tray, rear and front suspension with brakes, power steering pump. Looks like all brakes are intact, including lines, actual drums are shot I think, were stuck and pried off to get car to roll. Lots of odds and ends, 2 of the 4 side marker lights are good. I pulled it out of a junkyard. Asking $2600, bill of sale only, no title, vin tag or data plate (were missing). I do have vin number from mylar tag. I'll add more pics later. Car is in south jersey. Will come with 4 roller wheels, those cragars are just holding it up right now. Front bumper is straight, back not bad either. Will sell as whole or parts.
PM me only. Thank you
More pics here: http://s729.photobucket.com/user/roadrunninMark/library/70%20barracuda
Edited by roadrunninMark (10/30/17 01:48 PM)
Edit Reason: sold
#2381295 - 10/03/17 02:24 PM Re: E Body - Cars For Sale - 4th Quarter [Re: roadrunninMark]
MuscleMopars Offline
Loc: North Central USA (MN-WI area)
1970 Plymouth AAR Cuda
    This is a beautiful numbers matching factory FY1 Lemon Twist Yellow 1970 AAR Cuda.  It has its original born with 340 TA 6bbl engine and original born with 833 4 speed transmission.  It has one of the cleanest rust free bodies you will ever see on a cuda and was rotisserie restored a few years ago and still looks absolutely great.  Factory original options include the fast ratio power steering, the 3.91 axle package, power disc brakes, elastomeric “rubber” front bumper, fog lamps, am radio and it is a non vinyl top, non console car.  It has the original fender tags, original broadcast sheet, all original body stampings, VIN tag, door VIN decal and a clean and clear title.
    When the car was restored the engine was completely rebuilt and the rebuild is backed up by receipts and dyno sheets.  At that time a few expensive modern upgrades were incorporated to make it more reliable, safe and add some performance.  All of those things can easily be changed back to original but it is important to remember that the things that can not be changed to make this an quality investment collector Muscle Car are all here and intact.  Upgrades added were an aluminum “Be Cool” radiator with electric fan to keep it running at an optimum temperature range, a custom high flow non restrictive exhaust system with original AAR exhaust tips, a custom high charge chrome alternator, belt and pulley system, a beefy electronic ignition system, halogen headlights, Mopar Performance valve covers, am-fm radio, tach, 15” Rallye wheel spare, radial tires and a HD battery.  I have many of the original parts that were taken off for these upgrades that could go with the car if necessary.  The car has its original AAR hood, its original AAR air cleaner, original AAR spoilers, perfect AAR grill and its original dash pad.  It rolls on 15 inch Rallye wheels and BF Goodrich radial TA performance tires.
To summarize...  it is all numbers matching with its original engine and original transmission.  It has original fender tags and original broadcast sheet.  It has all of its rust free original exterior sheet metal.  It is a desirable impact color.  It has an axle package.  It is a 4 speed car.  It is multi carbureted.  It was produced in low numbers and was a “special package” car from the factory.  The car had a rotisserie restoration.  The car is nicely optioned.  The engine was rebuilt and it is backed up with dyno sheets and receipts.
    You will be hard pressed to find a better AAR cuda with everything this car has going for it.  It looks, runs and drives fantastic.  It is ready to show or drive, either way it is impressive!
    The highly acclaimed and collector car world go-to source for vehicle valuation is the Hagerty Value Guide.  It has 4 levels of condition ratings, a number 1 being at the top end and a number 4 at the bottom.  The guide publishes a 1970 AAR cuda with a 4 speed rated a number 3 condition valuation at $97,240.00.  This AAR is better than a 3 rating.  The car is priced fairly but I'm open to offers.  The car is for sale and it will be sold.
***SOLD***
Delivery is available
More pictures click HERE
Contact Eric at 715-426-HEMI (4364) or email eric@musclemopars.com
Edited by MuscleMopars (10/28/17 05:06 PM)
Thanks,
Eric
715-426-HEMI
612-669-CARS
Go to my Moparts "Profile" to see my web site
#2381467 - 10/03/17 08:22 PM Re:71 Challenger convert, Chrysler lease car [Re: VoodooCLD]
69B71E10LC Offline
Loc: Motor City
Up for sale is a 71 Challenger Convert., that I have owned for 27 years. It was completely restored by September of 1997. Everything was redone or replaced, there were a lot of NOS parts used in the resto. When i purchased the car it had 73,000 miles it now has 84,061 miles since done, which I belive to be original. It dose NOT have the original engine or trans, it is a 70 340 with correct 4973S carb, exhaust manifolds, valve covers, the trans was out of a 70 AAR cuda. I have 2 very nice build sheets that state the car is Y22 Corp lease car executive, along with Galens documentation. Below is a copy of Galens decoding of the build sheet, it would take forever to list it all. options are A/C, pwr windows, am/fm 3 speaker stereo, SE trim, all the moldings you can get, runs and drive real nice.The NOS parts used were:
Grill and head lamp bezels
3pc wide fender and hood moldings
J moldings on valance
Wide rocker moldings
Drivers door handle
Wheel lip moldings
Flip top gas cap
Locking gas cap
Rear quarter moldings and trunk lid
Door edge moldings
A/C heater valve
I am asking $59,500 for the car, no trades. I can take pictures of anything you like and call for an honest description. 586-530-8529 Andy
Edited by 69B71E10LC (11/20/17 09:41 PM)
#2381861 - 10/04/17 02:45 PM Re: E Body - project 72 Cuda [Re: moparts]
waffle Offline
Loc: Western NY
340, 4-speed, Rally Red. 29,000 original miles.I bought from original owner 37 years ago and have never driven it. Needs a restoration and original motor is gone, but I have all the rest of the original parts plus approximately maybe 50 NOS parts that I have acquired over the years. Stored inside and all body panels are fine. Have broadcast sheet and Galens sheet along with every piece of factory manual or literature including dealer only literature I could find. Asking $19,500 for everything I have. Call or text me if you want to discuss the details. Jim at 585-281-6434 is cel and home is 585-226-3427.
Edited by waffle (10/04/17 04:07 PM)
#2383333 - 10/07/17 09:08 AM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
69CudaFan Offline
Loc: Sandy Eggo, CA
Original four-owner car that has been in dry SoCal its whole life! No rust issues to contend with! Least expensive, most solid 1971 Barracuda I have seen, and no hidden issues to deal with! Get into an E-body for very little money compared to other cars. Drive it, clone it, or anything in between!
1971 Plymouth Barracuda, Light Blue Exterior, Blue interior. Original numbers matching 318 engine and A/T , Column Shift, A/C, P/S, and PDB. Has fender tag, I have not looked for build sheet. Has correct radiator and jack assy. w/hook. 14” Road Wheels (5) with BFGs. According to previous owner, engine was rebuilt about 20K miles ago. New gas tank. New hood pins and brackets. New battery. Dual exhaust was added with A body style tips by second owner many years ago, and it is in nearly new shape. Rear end is a 2.76 open differential, and rear leaf springs are original.
Car has been upgraded with a ‘Cuda Sport Hood w/Hood Pins, 70 bucket seats (upholstered with old school velour back in the 1990s to match but with Black backs), Dual Chrome sport mirrors w/driver-side remote, and front power disc brakes. 120 Speedo and gauge cluster. All glass in the car is original (with logos/date codes/etc). Car is a factory undercoated car.
Car body is in excellent condition with only a few minor chips in the paint. Dash has typical cracks, but is original and covered with a black mat. Very nice driver condition. Car has been stored in enclosed storage since 2005 until I resurrected it. I have driven this car nearly 1000 trouble free miles since I have addressed mechanical issues. Carb has been rebuilt. Water pump was replaced. Interior panels are in remarkable condition for their age. I have new kick panels and A-pillar trim I can include. Door sills are brand new, and originals are included. Plugs, wires, and fresh fluids all around.
I would not hesitate to drive this car ANYWHERE!
As you can see by the scheduled production date (6/30) and the VIN, this is one of the last 71's to roll off the assembly line.
Letting it go for $33,000.
Bank to bank transfer is the preferred method of payment, but cash or cashier's check can work (will ship once funds clear).
This is far an away the least expensive 1971 Barracuda that is ready to rack up miles the day it is delivered!
Car is located in Poway, CA. I will assist with shipping, but all associated costs are the responsibility of the buyer.
Fender tag codes:
R11 26 EN2
GB2 U G15 H51 M21 N95
GB2 H6B5 000 630 056012
E44 D31 BH23 G1B 448563
BH23 G1B 448563 - VIN
E44 - 318 2-Bbl. Engine
D31 - 3-Speed Automatic
GB2 - Glacial Blue Iridescent (Light Blue Metallic)
H6B5 - Blue Bench Seat Interior
000 - Upper Door Panel Color (N/A)
630 - June 30, 1971 Build date
056012 - Vehicle Order Number (VON)
U - Build to USA Spec
G15 - Tinted Windshield
H51 - Air Conditioning
M21 - Drip Rail Moldings
N95 - CA Emission Controls
26 - 26" Radiator
EN2 - End Of Codes
#2384402 - 10/09/17 10:52 AM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
MichaelAARTA Offline
Loc: Altamont New York
1970 440 6 PAC 4 -SPEED RT Challenger #s matching Vitimin C Orange 🍊
RARE V Code 4 Speed * in a great hi impact color 🍊
#s Matching Born with original engine ( rebuilt )
Transmission is Hemi 1970 4 speed (rebuilt) not original to car but correct trans for car
ORIGINAL born with Fender Tag ( NOT re pop)
Correct original carbs ( center carb rebuilt )
Correct original Radiator
Original date coded 15x7 Ralley wheels with center caps and trim rings
MINT dash pad and interior ( Black) new headliner
ALL original body panels no bondo
Vitamin C orange ( currently painted white )
Original plan was to restore the car to original color etc but Resto shop back log is still a year And have been waiting for over a year.
Selling at a loss $49,500 or BEST OFFER
Any question or pics please call 518 858 198three
Thank you
Edited by MichaelAARTA (10/09/17 10:58 AM)
#2385227 - 10/10/17 05:11 PM Re: E Body - Cars For Sale - 4th Quarter [Re: MichaelAARTA]
CRT Offline
Loc: Cedar Lake IN
1970 Plymouth Cuda FOR SALE
vin # BH23G0E109377
528 Ray Barton Hemi
650 HP
2 750 Carbs
Mechanial Pump
Serpentine belt system
Aluminum Radiator
Dana 60 Detroit Locker 4.10 Gear
All new Legendary Interior
All new wiring
Shaker Hood
Hemi K member
New 727 Torque Flight Pistal Grip Shifter
fresh resto $79,900. Ask for John Cope
call or text 219-712-5745 or e mail CopeRacingTrans@aol.com
Cope Racing Transmissions
#2386379 - 10/12/17 03:05 PM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
Thanatos340 Offline
Loc: Marietta, GA
For Sale:
1972 Cuda 340. 727 Slapstick. Numbers Matching, Original TX9 Car with original build sheet. Laser straight body with no body filler anywhere.
Top Quality Restoration a few years back. Car needs nothing but a new owner.
Minor Issues:
Small (About 1 inch) place in the headliner where the seam is starting to split. I believe it to be the original headliner.
Small Crack (about 1/4 Inch) in the plastic on the shifter handle (Have to be looking for it to see it).
Hockey Stick Stripe is not correct for the car. It originally came with a white 72 style stripe.
Was not a factory Go Wing Car - Go Wing was added when restored.
I show this car most weekends. It always does very well and is a crowd favorite. Get in and drive anywhere. Drives great.
I paid $35,000 for this car last year and just looking to get my money back out of it. Price is 100% completely firm. (If I take a loss, My wife will never let me hear the end of it). Also willing to consider partial Trade for Dodge Warlock or Midnight Express.
I keep the car at a private Classic Car Storage facility just outside of Atlanta. They can help with arranging transport if needed. I also have a full independent inspection report and appraisal on the car if you are seriously interested.
More pics available. Just message me.
Edited by moparts (10/12/17 07:40 PM)
Edit Reason: 4 Picture MAX
#2387536 - 10/14/17 09:29 PM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
penski61 Offline
Loc: mesa , az
1973 Dodge Challenger with body work 80% done just finished the trans tunnel patch to fit a 6 speed tr6060 transmission Car is setup for a modern gen 3 hemi swap with manual transmission(not installed) and gerst front end with subframe connectors installed and 4 link with dana 60 . The engine in the pics is sold . Car is located in mesa az and has clean title in my nameyou can contact me on here or email penski61@hotmail.com
$8500 with gerst suspension
$6500 without gerst suspension
Edited by penski61 (11/22/17 07:35 PM)
#2388755 - 10/17/17 01:00 PM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
Tooldude Offline
Loc: So Cal
1974 CUDA all matching # 360, auto, 3:55 S G green outside green inside, black top
$27,500.00 805.755.3686
We have a ton of pictures text me or e mail
Bartman805@sbcglobal.net
Listing for a friend
Edited by Tooldude (10/18/17 01:51 PM)
#2392819 - 10/25/17 08:58 AM 1970 Challenger [Re: Tooldude]
davesmopars Offline
Loc: cheshire, ct
1970 Challenger 318 Automatic console floor shift parts car
A/C system is complete
rear defrost
Tinted glass very nice
Really did stainless no dent or dings
real nice grill
and a lot more stuff
some stuff already take off but goes with car
radiator
shroud
some of the engine bay a/c stuff condenser and lines
Grill
tail lights
radio
I am sure I missed a few things off the car that goes with it
the car is rotted very bad
the car does roll tire hold air long enough to load
NO front bucket seats
pm me here
1800.00
Edited by davesmopars (10/25/17 09:30 AM)
#2393058 - 10/25/17 06:28 PM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
b5cuda69 Offline
Loc: KS
SOLD - Real 1974 cuda (BS code) project. Nicely optioned, PS, PB, A/C, AM/FM. G8 green with white top and stripe, black and white interior. Has the complete 3 speaker AC dash, rally cluster, original radio, numbers matching short block (318) and auto trans, factory front and rear swaybars. Full set of seats with brackets, radiator, gas tank, interior panels, misc parts. Frame rails and floors are solid, needs sheet metal work including trunk floor (rusted) and several small rust holes in roof from the vinyl top. Quarters had amateur repair and should be replaced. Clear Kansas title, car is located two hours west of Kansas City. $4,900.
Edited by b5cuda69 (11/08/17 06:25 PM)
#2397131 - 11/01/17 11:33 PM 1970 Cuda rotisserie restoration [Re: b5cuda69]
Canam800 Offline
Loc: Lanse,mi
Selling my 1970 Cuda. Car was rotisserie restored only 2200 miles since completed. Car was completely disassembled and acid dipped. Whole car top and bottom inside and out is finished in basecoat clearcoat sublime green. Real Cuda was a 383 auto car have the fender tag. Now has a 400 stroked to a 510 with a tremec 5 speed. 8 3/4 with 3.91 gears. Caltracs. Motor has Indy ez heads Indy single plane intake 850 carb crane hydraulic roller cam. TTI ceramic coated headers. 3 in exhaust with flow master mufflers and tti tips. Aluminum radiator has air conditioning from bouchilion. Originally was an air car. Buckets console with ralley gauges. All new interior just dashes dash pad. Front rubber bumper. AAR style hood custom made of all steel. Centerline wheels front and rear sway bars. Everything is new. Must see. Over $100,000 invested.
Thanks Brandon
Call or text for more info or pictures
Asking $75,000 Obo
815-236-1611
Car is located in Woodstock il
Edited by Canam800 (11/01/17 11:37 PM)
#2397135 - 11/01/17 11:40 PM 1971 Barracuda convertible [Re: Canam800]
Canam800 Offline
Loc: Lanse,mi
1971 Barracuda Convertible for sale. Has 383 auto was a 318 auto. No fender tag. Has a/c power steering power brakes ralley gauges power top. Runs and drives needs 2 floor pans and tail panel. Trunk is good. Has 8 3/4 rear. Great car to fix up. Not many around.
Asking $42,000 Obo
Car
Is located in Woodstock il
815-236-6254
Jackie751@juno.com
#2402102 - 11/11/17 05:13 PM 1970 V-Code Cuda for Sale [Re: moparts]
Chuck West Offline
Loc: FL-USA
For Sale - 1970 V-Code, (440+ 6), N96 Shaker Hood, Cuda.
$95,000.00
This car has been featured in several National magazines & 1 European magazine, as well as several TVshows and 1 Lithograph, by Famed Automotive Artist, Dave Snyder.
A copy of each magazine and TV show will go with the sold car!
The shows were;
-Featured on My Classic Car
-American Muscle Car on SPEEDCHANNEL. Start of shows with FY1 Cuda, behind my Cuda! At the start and end of each show!
-Lead in on Popular Hot Rodding TV laying down rubber at the start of each show!
Magazine features & Covers;
-Cover- of the 10th Anniversary Edition of MuscleCar Review - April-May 1994
-Cover of Mopar Muscle / April-May 1991
-Feature in Mopar Muscle / April- May 1995
-Feature in Classic American magazine (published in England) / Jan. 1999
-Cover of The Paddock-Dodge/Plymouth Catalog. Worlwide distribution!
-Inside Muscle Car News magazine / 1999
-Cover of Muslce Car News magazine / 1999
Specs of the Cuda;
-1970 Cuda
-Lemon Twist Yellow exterior with Black Vinyl Top and Hockey Stripe.
-Black Go Wing- not original to the car when new, added later
-Black Interior Bucket Seats. Drivers side has small 1" tear.
Passenger Side rear seat also has a 1" tare.
-All Stainless is in good shape and all there.
-All body and paint in great shape
-Rim Blow Steering Wheel with Fish Cap. Works and looks great.
-Manual Steering
-Rallye Dash / gauges / Clock not working, Tach needle just recently broke.Radio = Std. AM
-Dash is in awesome shape. No cracks, etc.
-Black Carpet with custom 'CUDA' Yelllow Inserts on floor mats.
-Headliner perfect. Overhead seatbelts and Lap belts
-Floors and Trunk floors in great shape
-Shaker Hood in great shape, Shaker is correct silver, but I added large Silver Argent Metallic Flakes
-440-6 Barrel engine runs perfect!
-Electronic Ignition
-Hood Pins-Lanyards
-Red Line Grille-Perfect
-Grille Painted to Match Shaker, as are wheel Center Caps, Rocker Gills
-Headers, Stock Exhaust Manifolds are included/ Stock replacement mufflers, original Dual Exhaust Tips / Cannisters long gone.
-Hemi Torqueflite / Shifter on the Column
-Dana 60 with 4.10
-Power Front Disc Brakes / Std. Drum Brakes on rear
-DASH VIN / Fender Tag Plate / Cowl Numbers / Radiator Support are all numbers matching. Build Sheet was lost
-956 Radiator is not in car, but I have the original radiator, but replaced a few years back
-Have reproduction Red Cap Battery (never used), that goes with car. Currently has an OPTIMA.
-Glass is in good shape
-Front & Rear bumpers are in great shape
-Car comes with a full set of Polished Weld Wheels and Mickey Thompson Tires, Front & Rear.
*Also comes with complete set of Stock Rallye Wheels, center caps and GOODYEAR Polyglas Tires
-Runs and drives great! Can drive anywhere!
-Clear Title
-Car is to be sold as is, where is! No warranty implied
-I've described the car as honestly as possible.
Any and all questions answered to serious buyers as quickly as possible!
*Not a perfect car! But very nice and fun, not to mention a great investment as you enjoy it!
No Trades!
**Asking $95K But will consider all serious offers!
Email for more information @ speed4266@aol.com
Chuck
*If Pro Street is more your style, Please see my other ad on my Pink Pro Street Car!
Thanks!
Edited by Chuck West (11/11/17 05:15 PM)
#2402384 - 11/12/17 05:03 AM Re: E Body - Cars For Sale - 4th Quarter [Re: moparts]
migsBIG Offline
Loc: San Jose,CA
Listing for my friend is a 1972 Plymouth CUDA that is a project ant been sitting for nearly 20 years since 1996 in his garage. Originally powered from the factory with a 340 4spd EB7 paint car. comes with replacement disassembled 340, numbers match 4spd, 8 3/4 rearend, floor shift power steering, power disc brakes, dual swaybars, factory heavy duty suspension, centerline wheels, Rally gauges, factory pistol grip, new Legendary interior upholstery (might be challenger, fits over same frames) chrome mirror, mint original dash pad and probably some more stuff I forgot about. Was taken down to a rolling body, but parts can be placed inside it for transport as it rolls fine. The body is close to rust free as you can get from a garaged California car with only a little rust in the lower rear window Dutchman panel and a little at each at the lower quarter panels. Trunk pan, floor pan, cowl, frame rails, inner fenders, roof, tail panel, fenders, doors, radiator support and pretty much everything else is rust free and not all wrecked up. Vin number on cowl, trans, dash vin tag, fender, original door all match. Car never had a broadcast sheet, fender tag is missing, nicely loaded and has the very rare EB7 Blue that looks so good on these cars. Located in Chico, CA and will schedule appointments with him when serious buyer is ready. He can help load onto a trailer. The other car he has in the picture is not for sale so don't ask. Has paperwork, but he can make a bill of sale and it is currently non-op with no fees.. He will be asking $11,500/obo. To schedule a time or ask question, please message me.
#2403917 - 11/15/17 09:26 AM 70 DODGE CHALLENGER T/A [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
FIRST TIME OFFERED TO THE PUBLIC SINCE "1985" A REAL 1970 DODGE CHALLENGER T/A 340 SIX PACK 4SPD "PANTHER PINK" CAR,8-3/4 3.55 SUREGRIP,15" RALLYS,THE ENGINE,TRANS,REAREND WAS REBUILT AND IT WAS DRIVEN VERY LITTLE SINCE THEN.THE FOLLOWING ITEMS WERE ALSO BOUGHT NEW EXHAUST SYSTEM,BRAKES,BRAKE LINES,BRAKE CALIPERS,GAS TANK,SHOCKS,TIRES,RECORED RADIATOR,IT HAS THE ORIGINAL CARBS AND THEY ARE REBUILT,NEW BATTERY,THE CAR WAS REPAINTED LAST IN "1989" AND LOOKS GOOD,IT DOES HAVE SOME MINOR IMPERFECTIONS IN THE PAINT AND THE DRIVERS DOOR DOES HAVE A SMALL DENT,THE CAR HAD THE ZIEBART TREATMENT DONE AT ONE TIME,WHICH IS RUST PROOFING THE MAIN BODY.THE INTERIOR IS VERY NICE AND EVERYTHING WORKS EVEN THE DOOR BUZZER AND THE ORIGINAL AM RADIO WORKS AND THE REVERSE LIGHT ON THE DASH WORKS,(((EVERYTHING WORKS))).THIS CAR IS ALSO ON THE T/A REGISTRY,BOTH FENDER TAGS,DASH TAG,DOOR STICKER ARE IN PLACE,IT HAS (2) BUILDSHEETS,AND A CLEAN OPEN TITLE DATED IN "1985" THIS IS THE REAL DEAL,IT RUNS AND DRIVES GREAT,YOU CAN DRIVE THIS CAR ANYWHERE.
$99,000
ORANGE PARK,FL.
E-MAIL: GDMUSCLECARPARTS@YAHOO.COM
SHOP # 904-272-1803
CELL # 904-589-4645
Edited by gdmusclecar (11/15/17 09:44 AM)
Page 1 of 2 1 2 >
24,966 Registered Members
185,425 Topics
A-body Window Track Parts and Universal Electric Window Kit
by MuuMuu101
11/24/17 02:06 AM
Anyone know where I can find this stupid plug?? 73 d100
by hosehead
11/23/17 09:48 PM
Tar in trunk on my 37, Amazing preservation
by AZ_A12_BEE
11/23/17 09:46 PM
belvedere trunk lids
by loren kraker
11/23/17 09:24 PM
