#2394400 - 10/28/17 07:51 PM 5.7 in an 05 Dakota
cudaman1969 Offline
Loc: fredericksburg,va
Tried this post in the truck section but no response.
Been thinking of changing over to the Hemi for awhile. The V6 in it now is getting a little tired so I have this hemi setting around and thought why not. Anybody on here done this? If so what do I need to get to install? No racing or pulling just normal driving. Will the V6 trans bolt up (4x4)? I have the car intake, I know I have to replace that and would like to keep the throttle cable instead of the fbw. Would the Durango be a good source of parts since the 5.7 Hemi was an option. Thanks for any help
#2394649 - 10/29/17 06:53 AM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
ric3xrt Offline
Loc: Trumbauersville PA
over on Hemi Truck Club, there's a user( Vladek ) doing a 05 Hemi Swap, there is also another user(DakkotaJ) over there who has a swap in to a 04.
http://www.hemitruckclub.com/forums/f171/slow-start-for-the-hemi-swap-17571.html
the kid who bought my 97 440 Dakota just finished up a G3 Hemi swap in to that truck.
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2394681 - 10/29/17 09:23 AM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
ric3xrt Offline
Auto or Stick? either way the Hemi will bolt up, as for keeping the cable TB, you can with a 4.7 PCM for the Dakota.
YEs A 05 Durango would be a great source for the odds and ends pieces...I can't tell you if the Durango Hemi mounts will work..I don't see why not.
#2394698 - 10/29/17 10:01 AM Re: 5.7 in an 05 Dakota [Re: ric3xrt]
Satilite73 Offline
Loc: Between Houston & Galveston TX
I found a guy on YouTube that uses '05 Durangos for frame swaps. I posted about it over in the general section. One of the guys response to my post was that the dakota frame is the same as the durango. shruggy
Around here, '05 hemi durangos can be had for less than $3K.
Linky to my post
John
#2394723 - 10/29/17 10:29 AM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
cudaman1969 Offline
Thanks guys great info so far, I'll be going to junk yards looking for Durangos, pcm, mounts, wiring and all the small parts. The truck is an auto, the small one I know, but like I said just normal driving. Be nice to find a wrecked Hemi Durango and just start swapping parts. Be nice to get hooked up with the guy using frames to see what he has.
#2394920 - 10/29/17 02:25 PM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
MattW Offline
Loc: Ontario Canada
Go to dakota durango forum under the 5.7 hemi section.
Look for FrenicX post.
He did a 2005 4.7 to 5.7 swap.
Used the 4.7 ecm with a tune.
HP tuners has the ability to tune said ecms from 04 and up.
If you use the stock ecm you cam keep all the bells and Whissels with no check engine light.
Matt
#2395186 - 10/30/17 12:53 AM Re: 5.7 in an 05 Dakota [Re: MattW]
cudaman1969 Offline
Matt
Thanks, but mines a 3.7 V6
#2395463 - 10/30/17 02:12 PM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
HotRodDave Offline
Loc: Kalispell Mt.
The motor mounts on a dakota and durango 4x4 are different, at least the drivers side is very different in how the diff bolts into it all and will need to be made.
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
#2395676 - 10/30/17 07:45 PM Re: 5.7 in an 05 Dakota [Re: HotRodDave]
cudaman1969 Offline
Isn't Chrysler amazing making it so simple.
Edited by cudaman1969 (10/30/17 07:46 PM)
#2396295 - 10/31/17 07:35 PM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
MattW Offline
Loc: Ontario Canada
Matt
That's supported as well!
My understanding is that the ECM are all the same, just the programs is different that go into it.
I think you can reprogram the 6 ECM to an 8 and away you go.
If not get a use 4.7 ECM an go from there.
Once again I have not done this but will be in the near future.
Matt
#2396297 - 10/31/17 07:37 PM Re: 5.7 in an 05 Dakota [Re: cudaman1969]
MattW Offline
Loc: Ontario Canada
Same webpage as stated above. Has been done. Cut the steel mount of and re weld to new fabricated mount.
Matt
#2396703 - 11/01/17 01:16 PM Re: 5.7 in an 05 Dakota [Re: Satilite73]
73MagDuster Offline
Loc: Hershey, PA
Linky to my post
This is untrue. They did share front clips until the 2004 Durango came out, and the 2005 Dakota is designed similarly but not the same. The Dak is slightly narrower and has coil over front suspension while the Durango has torsion bars.
25,347 Registered Members
190,226 Topics
Rough '70 GTX V code
by ChryCoGuy
06/22/18 11:26 AM
Wall Street Journal reviews past global warming predictions
by DaveRS23
06/22/18 09:58 AM
Big gas bare heads?
by fbs63
06/22/18 09:38 AM
Can this crack in this hemi block be repaired?
by Challenger 1
06/22/18 09:19 AM
