Page 1 of 2 1 2 >
#2393170 - 10/25/17 10:34 PM Relocating leaf springs
clutch Offline
Loc: S.L . MI
Anyone relocate their rear leaf spring under the frame on a D100
#2393306 - 10/26/17 10:04 AM Re: Relocating leaf springs [Re: clutch]
scratchnfotraction Offline
Loc: Florida
KenworthGoose moved the hangers to the inside frame rails d-chassis and a cut and narrowed his 8 1/4 and resplined the stock axles.
I did a d chassis with the rear shackle flip and flopped A-body 8 3/4 under there to tuck 12x15 325/50/15 in the fenders. following your truck adding the caltracs LOL!
I did a d-chassis with the shackle flip axle flop then added some weight in the bed to get the lower ride height I wanted.
then welded some brackets/ladder bars/coil overs under it with the ladder bars in-line/centered to the frame rail.
then removed the leafs/brackets from the outside of frame rails. got the new ride height and kept the pinion angles correct also went to a 14x15 rim.
I did not like the ladders on inside the frame rails on my first attempt at ladders.. too narrow for me. I can only bring the tire/wheel in as far as the outside frame rail so no need to have the ladders inside IMHO.
in-line is fine.
#2393315 - 10/26/17 10:20 AM Re: Relocating leaf springs [Re: clutch]
Loc: Florida
I have some pics I will post later of some mounts/leafs that are on Ferlins green truck.
easy to fab up and works out nice with leafs in line with frame rails. IIRC he had 14x15 also.
slowly working a short 4x4 chassis to make a mid 80s 2x gasser truck with straight axle/leafs up front, 3" straight tube with the yokes/spindles/hubs/rotors off the 80s front diff.
this should keep all the stock caster/camber/toe-in specs and stock steering linkage.
but then again a front & rear 4 link with king shocks would be cool?
#2393578 - 10/26/17 09:09 PM Re: Relocating leaf springs [Re: scratchnfotraction]
clutch Offline
Loc: S.L . MI
Shocks are already relocated on Competition engineering brackets just want to move springs to get more tire clearance It hooks up good right know so I don't' want to mess with it to much . Just got it back to the track it hasn't been out for 7 years
Last Saturday
Edited by clutch (10/26/17 09:11 PM)
#2395437 - 10/30/17 01:43 PM Re: Relocating leaf springs [Re: clutch]
Jwilli500 Offline
Loc: Oklahoma City
Love watching that truck launch! up
It absolutely hauls the mail!
Glad to see you back as well. up
Edited by Jwilli500 (10/30/17 01:43 PM)
#2397044 - 11/01/17 09:02 PM Re: Relocating leaf springs [Re: clutch]
68dodge Offline
Loc: ,Pa.
are you just using stock leaf springs?
#2397207 - 11/02/17 08:31 AM Re: Relocating leaf springs [Re: 68dodge]
clutch Offline
Loc: S.L . MI
Stock Replacement springs, bent the originals ones they wrapped up so bad before the Caltracs. They are D100 4 leaf pack just missing the overload leaf.
#2397342 - 11/02/17 01:07 PM Re: Relocating leaf springs [Re: clutch]
68dodge Offline
Loc: ,Pa.
Are traction bars any good if you have them right up to the front leaf spring eye? Trying to get mine to hook better.
#2397425 - 11/02/17 03:57 PM Re: Relocating leaf springs [Re: clutch]
Loc: Florida
I have a set of SSM lift bars for A-body. since I flopped A-body 8 3/4 in there for 12x15 325/50/15 M/Ts they went right on thruck
they replace the shock mount with a plate/traction bar that clamps to the leaf just behind the front eye. about the same spot caltracs pushes on the leaf. bolts solid and preloads the springs. lifts as it plants the tires.
it has steel wedge pieces square u-bolt clamps to fine tune it and instruction said to use 2 on pass side with 1 on driver side to start.
I had got down too 2 stock leafs with the lift bars and got lots of lift but blow the tires loose when it over extended the shocks...with a bang.. need moved like on your (clutch) truck.
I like them better than the slapper bar/rubber bumper old skool traction bars as the clamp solid up front and have pre-load built into them.
want to give them a shot or pics LMK.
working on my lap top now or I would post a few pics of different set ups
Edited by scratchnfotraction (11/02/17 04:00 PM)
#2397538 - 11/02/17 08:33 PM Re: Relocating leaf springs [Re: 68dodge]
clutch Offline
Loc: S.L . MI
Part of your problem on the rear is the angle of the shocks when you flop the rear end to the top of the springs . The shocks are at to extreme of an angle to do their job. You could try some spring clamps on the forward section of the spring also . I have actually done way more work to the front end to get mine to hook than the rear. The rear is basically shocks relocated On CE brackets Rancho 9 ways with Caltracs in lower hole and shackle bushings honed out till the move freely when assembled.
#2397555 - 11/02/17 08:50 PM Re: Relocating leaf springs [Re: clutch]
clutch Offline
Loc: S.L . MI
Front end:
van lower control arms
Stock upper control arms
5th avenue front spindles
with the steering arms on upside down
stock strut rods removed replace with
chromoly tube and rod ends with heavy
duty tabs welded to frame and c lower control arm
Moroso GM F body trick springs for a big block
All bushings honed and greased
until control arms move freely
Strange adjustable shocks for B body
with extension
#2397742 - 11/03/17 08:04 AM Re: Relocating leaf springs [Re: clutch]
68dodge Offline
Loc: ,Pa.
Thanks clutch !! I already had the shock moved from the truck location to the same as a car, I will move them again. Now are the Caltracs from a B-Body or did you have them made? Thanks again
#2397751 - 11/03/17 08:21 AM Re: Relocating leaf springs [Re: clutch]
Loc: Florida
LOL! and rack & pinion, weight reduction holes..
tell me more about the spindles & rack. how did you mount the rack to chassis?
by the looks of the launch you make it is working rather well. I will be moving my shocks for sure.
those front end mods look very interesting and like the use of the trick springs in there but confused on the upside down steering arm?
#2397790 - 11/03/17 09:20 AM Re: Relocating leaf springs [Re: clutch]
clutch Offline
Loc: S.L . MI
They had to be flipped so the tie rod don't hit the strut bars. 5th avenue spindles steering arms are bolted on. The rack is mounted on a piece of 2"x3"
heavy wall tube with a nut welded to the back mount just like it did on a Dakota. The trick springs and some 90/10 shocks making sure the control arms
move freely will get you a long way.
Edited by clutch (11/03/17 09:21 AM)
#2397794 - 11/03/17 09:25 AM Re: Relocating leaf springs [Re: clutch]
clutch Offline
Loc: S.L . MI
They will make the Caltracs to fit your truck just have to take a couple measurements They probably already have a setup by now with the flopped rear end.
#2398055 - 11/03/17 03:56 PM Re: Relocating leaf springs [Re: clutch]
Loc: Florida
did you fab a lower steering shaft to hook the rack up? stock upper steering?
and 1 more ?... when you say "hone out the bushings" that's using the poly bushings and letting them spin in the c-arm bushing shell?
not the ones with the shell to be pressed in.
same for lower arm?
#2398071 - 11/03/17 04:20 PM Re: Relocating leaf springs [Re: scratchnfotraction]
clutch Offline
Loc: S.L . MI
stock steering column with fabricated shaft with 3 ujoints. I hone out the center hole of bushing where the steel sleeve goes and then grease it up with some moly graphite grease both upper and lower . Don't use the urethane bushings in the strut bars they are to stiff .
#2398477 - 11/04/17 04:40 PM Re: Relocating leaf springs [Re: clutch]
huimerind Offline
Loc: est
I think, it would be easier to mount the springs inside the frame rails. You have to relocate the crossmember or how guys call it..
I would probably move that crossmember, box the frame and make new front mounts for the spring.
I made them like that, you could do something similar, but inside the frame rails.
If you need more separation, move the front spring eye higher.
#2398484 - 11/04/17 05:00 PM Re: Relocating leaf springs [Re: clutch]
huimerind Offline
Loc: est
Rear mounts
#2398542 - 11/04/17 07:09 PM Re: Relocating leaf springs [Re: huimerind]
clutch Offline
Loc: S.L . MI
I thought about just moving them to the inside ,but after some measuring there is way to much stuff in the way that would have to be
moved ( cut off and re-welded ). I found some afco front spring mount that will weld right to the bottom of the frame after trimming
cross member. Also found some ball bearing sliders that weld under the rear . That will make it sit about the same or slightly lower.
Page 1 of 2 1 2 >
25,068 Registered Members
185,584 Topics
spark plugs ?
by sixbbl 69
Today at 12:06 AM
A100 power steering
by 2002bluert
Yesterday at 10:00 PM
W23 Recall Wheel Price
by 2002bluert
Yesterday at 09:58 PM
Low Friction Upper Control Arm Ball Joints, Opinions?
by moparAL
Yesterday at 09:49 PM
