18 or 23 spline which one #239122
02/28/09 07:36 PM
02/28/09 07:36 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
So Im looking for a 4spd, Should I spend the extra for a 18 spline or will a 23 spline hold up for a street strip 450-500 hp small block.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: 18 or 23 spline which one [Re: 65 NSS 500] #239123
02/28/09 07:43 PM
02/28/09 07:43 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
You will be more then fine with 23 spline....
Re: 18 or 23 spline which one [Re: 9 Sec Phill] #239124
02/28/09 07:46 PM
02/28/09 07:46 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 18 or 23 spline which one [Re: 65 NSS 500] #239125
02/28/09 08:19 PM
02/28/09 08:19 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
if it is making that at the rear tires i am going to say no for the 23 spline if you are going to race on slicks, unless you put a good adjustable clutch in it.mine is starting to twist the input shaft splines with a centerforce df setup.
Re: 18 or 23 spline which one [Re: fasthawk6] #239126
02/28/09 08:31 PM
02/28/09 08:31 PM
Northampton Pa
Northampton Pa
Mine would be flywheel Hp, I probably would only race 2-3 times a year
