seized carb linkage. evaporust? #2390986
10/21/17 10:17 PM
10/21/17 10:17 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
would evaporust be a good dip for siezed carb linkage? if not any tricks?
Re: seized carb linkage. evaporust? [Re: chrisf] #2390989
10/21/17 10:29 PM
10/21/17 10:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What's seized exactly? Shafts & Butterflies or just the side linkage? Evaporust works on rust it can reach but if the rust is in tight areas like throttle shafts inside the bores, etc. it won't get in there enough to work in most cases.
Re: seized carb linkage. evaporust? [Re: chrisf] #2391019
10/22/17 12:06 AM
10/22/17 12:06 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
not sure yet Scott. ill dip and see whats up. thinking shafts
Re: seized carb linkage. evaporust? [Re: chrisf] #2391034
10/22/17 12:53 AM
10/22/17 12:53 AM
that's what I would do,soak it in evaporust since you already have some, otherwise I'd just let it set in some regular solvent.
Re: seized carb linkage. evaporust? [Re: chrisf] #2391041
10/22/17 01:23 AM
10/22/17 01:23 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Diesel is a good cheap soak liquid too. Heat is your friend.
Re: seized carb linkage. evaporust? [Re: chrisf] #2391046
10/22/17 01:47 AM
10/22/17 01:47 AM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
i got both. thanks
Re: seized carb linkage. evaporust? [Re: chrisf] #2391130
10/22/17 11:37 AM
10/22/17 11:37 AM
moparx Online content
moparx  Online Content
i soaked a pair of 1952 rambler carbs in ATF that were completely froze solid. loosened them right up, including the mix screws. kinda messy, but it worked. if you are looking for speed though, i don't remember how long it took because i just dumped 'em in and forgot about them for weeks.
beer
