Page 12 of 48 1 2 10 11 12 13 14 47 48
Re: Modern Bullitt build [Re: Black 69 Beeper] #1951025
11/14/15 12:46 PM
11/14/15 12:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Pulled the motor back out so I could modify the inner fender to make room for one of the brake lines off the master cylinder.
Pat
Re: Modern Bullitt build [Re: Keepat] #1951708
11/15/15 04:25 PM
11/15/15 04:25 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Welded the seams on the inner fender covers, coated them with bed liner and installed a rubber gasket I got from McMaster Carr. Now they should keep most of the water and dirt out.
Pat
Re: Modern Bullitt build [Re: Keepat] #1954609
11/20/15 12:00 AM
11/20/15 12:00 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I bent the right front brake line to run along the seam between the firewall and floor. This is much cleaner than the original run in the middle of the firewall.
Pat
Re: Modern Bullitt build [Re: Keepat] #1954779
11/20/15 10:20 AM
11/20/15 10:20 AM
mopar4don Offline
mopar4don  Offline
up Looks GREAT Pat
Re: Modern Bullitt build [Re: mopar4don] #1954917
11/20/15 04:08 PM
11/20/15 04:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By mopar4don
up Looks GREAT Pat
Thank You Don!
Re: Modern Bullitt build [Re: Keepat] #1955862
11/22/15 03:41 PM
11/22/15 03:41 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Finished the left front brake line and started on the rear brake line. Fuel lines are next.
Pat
Re: Modern Bullitt build [Re: Keepat] #1959006
11/27/15 11:14 PM
11/27/15 11:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
It’s not a ported head intake runner, but it will have fuel running through it. What do you think it is?
Answer will be in the next post
Pat
Re: Modern Bullitt build [Re: Keepat] #1959025
11/27/15 11:44 PM
11/27/15 11:44 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I needed to make a large fuel pass-through in the trans cross member as there will be two ½” fuel lines. I used part of the rear frame rail I cut off last winter to make the reinforcement for the hole I put in the cross member. Now I can bend full length fuel line to fit.
Pat
Re: Modern Bullitt build [Re: Keepat] #1959961
11/29/15 11:04 PM
11/29/15 11:04 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I installed the fuel tank so I could mark the trunk access for the fuel pump and sending unit. The tank has a EFI pump inside and adding the trunk access will make it easy check or remove without dropping the tank.
Pat
Re: Modern Bullitt build [Re: Keepat] #1961353
12/01/15 11:59 PM
12/01/15 11:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The fuel tank access cover is done, now I can bend the fuel lines
Pat
Re: Modern Bullitt build [Re: Keepat] #1962750
12/03/15 11:37 PM
12/03/15 11:37 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received the new RMS rear sway bar kit today just in time before I bend the fuel lines. I will locate the sway bar mounts first, so I can route the lines around them. This kit has been in the works for over a year and it was worth the wait! It is a great looking kit and very reasonably priced!
Pat
Re: Modern Bullitt build [Re: Keepat] #1964079
12/06/15 12:02 AM
12/06/15 12:02 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I put the rear back in the car so I could fit the new RMS sway bar. The sway bar kit fit great after I quickly figured out it is a rear mount system. All the RMS sway bar prototypes I saw at Carlisle had front mounts. Bill said the kit will work with TTI 3” exhaust and it does look to have more than enough room.
Pat
Re: Modern Bullitt build [Re: Keepat] #1964341
12/06/15 01:40 PM
12/06/15 01:40 PM
Superfreak
Superfreak
Nice work.
Re: Modern Bullitt build [Re: ] #1964528
12/06/15 08:15 PM
12/06/15 08:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By Superfreak
Nice work.
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #1969246
12/14/15 12:59 AM
12/14/15 12:59 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I almost finished the fuel lines this weekend. Just one S/S line left to make and a few hose.
Pat
Re: Modern Bullitt build [Re: Keepat] #1973166
12/20/15 11:24 AM
12/20/15 11:24 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finished the rear fuel lines and all that is left is the Much II tank vent system.
Pat
Re: Modern Bullitt build [Re: Keepat] #1975446
12/23/15 11:17 PM
12/23/15 11:17 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Before removing the fuel line I made an AC condensation drain and fire wall pass-through.
Pat
Re: Modern Bullitt build [Re: Keepat] #1976021
12/25/15 08:11 AM
12/25/15 08:11 AM
P
PasiR Offline
PasiR  Offline
P
Very nice work and details - I like this!
Re: Modern Bullitt build [Re: PasiR] #1976321
12/25/15 09:02 PM
12/25/15 09:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir, I appreciate your comment!
I hope you have a Great holiday!
Pat
Re: Modern Bullitt build [Re: Keepat] #1976899
12/27/15 01:41 AM
12/27/15 01:41 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the II Much vent canister, starting with punching out a 2 ½” hole where there was a 1 ¾” body plug using a knockout punch tool. This is a clean way to put holes into steel panels. Then I bent a 3/8” S/S vent line running downhill to the two tank vent fittings. I step closer to starting the bodywork.
Pat
