how to remove accelerator cable from the floor #2390524
10/20/17 10:04 PM
10/20/17 10:04 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
of 69 b body car.thanks
Re: how to remove accelerator cable from the floor [Re: moparpro] #2390575
10/20/17 11:20 PM
10/20/17 11:20 PM
Happy Birthday RapidRobert  Offline
it might be the flat pedal assy with the 2 integral threaded studs & if so you would see the 2 nuts on the engine side of the firewall, unbolt them then the pedal assy can come out/off of the carpet on the inside.
Re: how to remove accelerator cable from the floor [Re: moparpro] #2390582
10/20/17 11:25 PM
10/20/17 11:25 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
some of those accelerator cables have a small clip
that disintegrates to pieces over time.
you might have to dig into the plastic square with a paperclip
or wire to knock the pieces loose.
Re: how to remove accelerator cable from the floor [Re: moparpro] #2390615
10/21/17 12:24 AM
10/21/17 12:24 AM
there is a spring steel press on retainer that slides onto the cable housing end, pull it out with a good set of pliers and your done scope wrench up
