2006 mega cab gas engine #2390310
10/20/17 03:05 PM
10/20/17 03:05 PM
LEBANON;PA
daron Offline OP
daron  Offline OP
LEBANON;PA
how to identify which dana is in it , no tags on the rears
Re: 2006 mega cab gas engine [Re: daron] #2390321
10/20/17 03:30 PM
10/20/17 03:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sure its a Dana?
I think they went to the American axle with that generation truck
Re: 2006 mega cab gas engine [Re: daron] #2390333
10/20/17 03:58 PM
10/20/17 03:58 PM
Lakeland, FL
sixpakchallenger Offline
Lakeland, FL
mega cabs are 2500's so with the gas engine it's an AAM 10.5". you can get your build sheet from dodge:
https://www.dodge.com/webselfservice/dodge/index.html
Click on the link down the left side of the page that says "Equipment List"
Enter your VIN in the smaller search bar and click search
Codes:
[DME]=Axle Ratio - 3.73
[DMF]=Axle Ratio - 4.10
[DRW]=Axle - Rear,10.50
[DSA]=Axle - Anti-Spin Differential
2007 Mustang GT Vert
2004 Ram 2500 QC 4X4
1971 Challenger Vert 5.7 Hemi Project
Re: 2006 mega cab gas engine [Re: daron] #2391342
10/22/17 05:38 PM
10/22/17 05:38 PM
LEBANON;PA
daron Offline OP
daron  Offline OP
LEBANON;PA
Thanks I want to check the gears
