get the heads and intake gaskets you plan on using. mount the heads. use a dab of silicon(between the heads and the intake gasket) and place your intake gaskets exactly where you want them on your heads. use just enough silicon to hold the gaskets where you want them. once the silicon is dry apply silicon to the intire intake gasket that is exposed. mount intake, let dry. now when you disassemble, gasket will be glued to your intake, showing you exactly where your head ports are in relationship to your intake ports. use putty knife to separate gasket from head. since this is not a max hp effort, leave the CNC ridges alone texture on port walls helps fuel stay suspended
