Re: Four Speed Overdrive Automatic
[Re: IMGTX]
#2390531
10/20/17 10:15 PM
10/20/17 10:15 PM
Posts: 10,666 North Dakota
6PakBee
North Dakota
This is the rest of the idea. I mocked up a paper crossmember that I later transferred to CAD and had laser cut. I folded it and welded it up. Fits good and the loop from bolts to bolts is seamless like the OEM so no fear of a weld breaking and the tranny falling out. That is slick!
[Re: IMGTX]
#2390561
10/20/17 10:52 PM
10/20/17 10:52 PM
Posts: 3,056 Michigan
A727Tflite
IMGTX- Did the engine remain at the normal angle or did you have to lower it in order to have the overdrive unit miss the floor board?
[Re: John_Kunkel]
#2390694
10/21/17 07:12 AM
10/21/17 07:12 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
One day when I get off of my ass, I want to get one of those A41 4 speed kits from Silver Sport. They are based on the GM 700R4.
Wise decision, the 700R4 is superior in all the areas discussed. I like a 200-4R better but leave the Automatics to the women drivers
[Re: 70RT Charger]
#2390867
10/21/17 03:27 PM
10/21/17 03:27 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Wise decision, the 700R4 is superior in all the areas discussed. I like a 200-4R better but leave the Automatics to the women drivers My understanding is the 200 is based off the Turbo 350, while the 700 is based off the Turbo 400....
[Re: Kern Dog]
#2391068
10/22/17 03:37 AM
10/22/17 03:37 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
The 904 evolved into the 500 which was later renamed the 42RH. The 727->518->46RH. 1996+ went to the RE models which are useless to you so make sure you don't get one of those.
I have read others who went to the GM 4 speed autos for better/cheaper aftermarket support and a smaller physical size to not have to cut. One day when I get off of my ass, I want to get one of those A41 4 speed kits from Silver Sport. They are based on the GM 700R4. Personally I prefer the driveability of a 200R4 over a 700R4 all day long, especially in a DD with a tight converter. The big 1-2 ratio drop on the 700R4 really can lug the motor down. I guess it depends on how picky you are on that sort of thing. And fitment is also usually better on the 200R4.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: A727Tflite]
#2391081
10/22/17 07:05 AM
10/22/17 07:05 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
IMGTX- Did the engine remain at the normal angle or did you have to lower it in order to have the overdrive unit miss the floor board? On A-bodies this is indeed what's happening, not sure on other models. I had to pound 'create' some extra space in the tunnel from beneath so the trans sat a bit higher on my '73 Dart. I chose the easy way out, but it would be best to just cut open the tunnel, position the transmission properly, and then reweld and form the tunnel back around the transmission/overdrive flange.
[Re: John_Kunkel]
#2391103
10/22/17 10:47 AM
10/22/17 10:47 AM
Posts: 619 nj
JAMESDART
nj
Wise decision, the 700R4 is superior in all the areas discussed. I put a t56 in my bb duster. Liked the overdrive in old car so much I swapped a 700r4 into my wagoneer trail truck. Worked great, for that the low 1st gear was awesome. These were not kits, stuff I did myself. I thought hmmm let me see what this sst kit will cost for the dart. wow! Talk about sticker shock.
[Re: dogdays]
#2392007
10/23/17 07:56 PM
10/23/17 07:56 PM
floridian
Lakeland FL
The 700R4 was based on the Turbo Hydro 350.
The TH2004R was based on a different transmission, all the information is available online in several places. Neither was based on the Turbo Hydro 400. The 4L80E, 4L85E, 6L80 and 6L90 were based on theTH400. I'm not sure about the 8L90.
R. TY for updating my incorrect info....
[Re: floridian]
#2392864
10/25/17 12:56 PM
10/25/17 12:56 PM
Posts: 19,239 north of coder
moparx
R. TY for updating my incorrect info.... very interesting, as i have read lots of printed material that clearly states the 700R4 WAS based on the TH400. my local trans guy has shown me the later L80 series parts comparison[s] between them and the TH400, but we never discussed the 700R4. thank you for the information ! just goes to show it's possible to teach an OLD guy[dog] new tricks !
[Re: moparx]
#2393071
10/25/17 08:58 PM
10/25/17 08:58 PM
Posts: 11,894 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Looks like the biggest down side to putting a GM based tranny in your Mopar is money. The GM based kits look to cost over a grand more than the Mopar based stuff.
Master, again and still
[Re: 6PakBee]
#2393084
10/25/17 09:28 PM
10/25/17 09:28 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It uses a flexplate with a ring gear because the GM torque converter doesn't have a ring gear mounted to it. Nothing to do with relocation.
