PREPPING NEW PANELS #2389856
10/19/17 03:09 PM
10/19/17 03:09 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I have some new body panels that are e-coated by the manufacturer. Scuffed all the places I get get to w/maroon scotch brite. What about all those other places. Using a 2 part urathane.
Re: PREPPING NEW PANELS [Re: A/MP] #2390084
10/19/17 11:26 PM
10/19/17 11:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I would put an etching primer on it, then over coat that with a urethane primer / sealer
Re: PREPPING NEW PANELS [Re: A/MP] #2390311
10/20/17 03:06 PM
10/20/17 03:06 PM
South Dakota
hotairballoonpilot Offline
South Dakota
sand with 220 or 320 then apply a good 2K surfacer and ONLY etch primer on ONLY the bare metal. The small areas if using a direct to E coat product you can get away with out sanding. Products like PPG DP epoxy primers are direct to E coat. They do not suggest on outer sides of the panels but the jam areas say like underside of a hood is where that comes into play
Contact Me about AMD Prices
Re: PREPPING NEW PANELS [Re: A/MP] #2390442
10/20/17 07:34 PM
10/20/17 07:34 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
You have the surface prepped.I use PPG products,so next step would be wash with wax and grease remover(SX 330) and spray on DP 50 epoxy primer.DP 50 is medium gray in color.There are several colors available.
Re: PREPPING NEW PANELS [Re: A/MP] #2390453
10/20/17 07:44 PM
10/20/17 07:44 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
PPG certified painter here.
if you want to use epoxy over non sanded ecoat you should use the slower dry 401 catalyst NOT the faster dry 402.
perception is 90% of reality
Re: PREPPING NEW PANELS [Re: A/MP] #2391037
10/22/17 12:58 AM
10/22/17 12:58 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I would first wipe it with some laquer thinner and make sure it doesn't come off on the rag. Most the bigger name stuff has good coating, but better safe than sorry.
I like to hit it with a da and 180ish paper to get off the shine then epoxy. Then do any mud work over the epoxy.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
