5.9l magnum forum
#2389780
10/19/17 12:40 PM
10/19/17 12:40 PM
Posts: 1,547 Michigan
Kiddart
I was reading on a 5.9l magnum forum and I keep seeing over and over that some guys are reusing the same head gaskets after tear down and inspection. I was always told, that is something that should be replaced no matter what. Is this a bad practice.
I took the heads off my motor to get some work done and there is no way I am reusing the head gaskets or any other gasket for that matter,
looking for thoughts and a positive answer. Maybe I just like to spend money?
Thank you Kiddart
Re: 5.9l magnum forum
[Re: Kiddart]
#2389789
10/19/17 12:51 PM
10/19/17 12:51 PM
Triple Threat
Renton Washington
Unless its an MLS gasket, there's no chance I'm reusing a head gasket.
It's not worth the small savings, to risk a leak at such a crucial location.
[Re: Kiddart]
#2389818
10/19/17 01:42 PM
10/19/17 01:42 PM
Kiddart
That's how I feel Dustin, I just cant see the savings of $100 or less. My understanding when reading the articles is they took junk yard motors and did a inspection put them back together and put them in older mopars as a swap. it makes sense to do the swap but not to cut your hands off to save a few dollars.
Thank you Kiddart
[Re: Kiddart]
#2389829
10/19/17 02:11 PM
10/19/17 02:11 PM
Kiddart
I don't need them I just found it odd that they were reusing them. seems penny foolish to me
Thank you Kiddart
[Re: Kiddart]
#2390585
10/20/17 11:31 PM
10/20/17 11:31 PM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
What 5.9 Magnum Forum is this? Please send me the link if you don't mind.
Mo' Farts
Moderated by "tbagger".
