Re: Small block help
[Re: jkwedge540]
#2389617
10/18/17 11:54 PM
10/18/17 11:54 PM
Posts: 7,506 Az
Crizila
Az
Looking to build a small block pro charger motor. What block and heads would you use. 59 or 48 lifter bores. First time messing with a small block. Thanks If you are looking to stay with a stock block, look for an E58 coded motor. They came in lots of HD optioned cars - late Magnums, 300's, Squads, Taxi's, some trucks. Magnum blocks would be another option. Don't know what HP you are shooting for - assume 700 max with a D1SC? Sonic testing the cyl. walls for sure. Girdle, forged rotating assembly for sure also. Rosary beads hanging from the rear view mirror - - - - .
Fastest 300
[Re: jkwedge540]
#2389822
10/19/17 01:46 PM
10/19/17 01:46 PM
Posts: 1,548 Michigan
Kiddart
if you are looking go Gen 3, its probly better way and more cost effective. just my two cents. Plus they have kits all over the place to procharge or blower style.
Thank you Kiddart
[Re: webemopes]
#2390073
10/19/17 11:06 PM
10/19/17 11:06 PM
Posts: 6,136 Melbourne , Australia
LA360
How big are you wanting to do? That is going to determine the deck height you can go with. R3 blocks are around, but it can be slim pickings. Gen III or R5/P7 ,may be a better option.
Alan Jones
[Re: jkwedge540]
#2390629
10/21/17 12:59 AM
10/21/17 12:59 AM
Posts: 3,871 Smyrna, South Carolina
STEFF
You should seriously consider the Gen 3 Hemi instead of a small block. Unfortunately the Small Block is pretty much in extinction with lack of parts. Rob Goss's Challenger is the benchmark for a procharged Gen 3. Good aftermarket Blocks an Heads readily available.
[Re: Medlock51]
#2390635
10/21/17 01:29 AM
10/21/17 01:29 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Just remember that the 59 degree blocks are not very roller cam friendly beacuse of the pushrod angle's... too much monkey motion. Offset valves/and rockers help quite a bit. Not all roller lifters will work but there is some that work just fine. I have about 2000-2500 miles on a solid roller W2 headed 59* R1 block. I am using some mopar performance/crane roller lifters that clear the R1, comp also makes a lifter with the link bar moved that would work with the 59* R blocks. I think the comp lifter is an 8043-16 but not positive. Going with a G3 would not be a bad idea though.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2390666
10/21/17 03:09 AM
10/21/17 03:09 AM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I think everyone should step up to gen 3’s too. PS, when you are ready to sell your old school stuff please let me know.
[Re: pittsburghracer]
#2390717
10/21/17 10:31 AM
10/21/17 10:31 AM
Posts: 814 in front of the computer
80arrow
I think everyone should step up to gen 3’s too. PS, when you are ready to sell your old school stuff please let me know. I agree.... . Let me know also, when you want to get rid of your outdated stuff
[Re: Medlock51]
#2390719
10/21/17 10:33 AM
10/21/17 10:33 AM
80arrow
Just remember that the 59 degree blocks are not very roller cam friendly beacuse of the pushrod angle's... too much monkey motion. Offset valves/and rockers help quite a bit. My roller lifters have been just fine? You don't need a radical cam with boost, mines very mild, it'll idle at 900 rpm pretty easily
[Re: 340Cuda]
#2391064
10/22/17 02:57 AM
10/22/17 02:57 AM
LA360
Rob Goss is running a solid cast block with Billet heads. The same block is available with water jackets. They certainly broke a lot of parts working out what worked or not.
There are many options here really, a 9.2" or 9.6" deck R3 with a W series head
A Ritter or EEI block with P7 heads
A Gen III Hemi, factory block and heads will get it done. You can can spring for a pair of Thitek heads and Aluminium block from BES
Alan Jones
