Carter TQ meetering rod diameter - where to measure? #2389193
10/18/17 10:34 AM
10/18/17 10:34 AM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
Does anyone know the official specs on where to measure the idle & cruise portions of the meetering rod diameter?
I can certainly sample what I have and come up with a number, but I'm curious if there is an "official" specification somewhere out there???
Oh, asking because I have a 2357 rod here, currently using 2004, trying 2159 (which is a tad leaner than 2004), but judging by the looks of it the 2357 is even leaner, and I think I need to go down that route. Power is easy to measure, idle...ummm, you can sort of guess-timate it, but cruise...man, somewhere on that path the transfer starts, but it's hard to tell where.
Thanks!
EDIT
So when I'm thinking of a spec it would be from the short "L" shaped part where the rod hangs from the meetering tree, basically the distance from that 90 deg turn to where on the body of the rod to measure the diameter. I have seen many rods where the rod length varied, therefore, I do not think you can go the easier route and measure from the opposite end?
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2389261
10/18/17 12:23 PM
10/18/17 12:23 PM
I have always measured at the bottom of the rods for WOT and the next step up for cruise scope
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2389263
10/18/17 12:26 PM
10/18/17 12:26 PM
I'm thinking there would be the shank dia at the top (L bend) then a curved transition then the cruise then a curved transition then the power tip at the bottom (just guessing as I dont have one anymore). Can you get a part number (4 digit iirc) & find what the listed specs for cruise/power is & go to the area on yours that is the same dimention (or real close).
Last edited by RapidRobert; 10/18/17 01:08 PM. Reason: had some stuff turned around
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2389390
10/18/17 04:38 PM
10/18/17 04:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Cab is right.
Boffin Emeritus
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2389680
10/19/17 01:40 AM
10/19/17 01:40 AM
Windsor, ON, Canada
Windsor, ON, Canada
Cab_Burge and polyshperic,
I agree with both of you that the WOT is the bottom most part of the rod, right above it is the cruise circuit. I think the measurement should be done from the top of the rod however since that is where the rod is suspended on the tree. Therefore any rod manufacturing differences, which result in the rod length being different, will always be in relation to where the rod hangs.
Well, I've got a handy assortment of rods here, so measuring out a few with known rod values will eventually get me to the "design spec" of where to measure, worth a try anyways.
Thanks!
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2389683
10/19/17 02:02 AM
10/19/17 02:02 AM
look closely at the power valve that holds the rods, how far down can it go in relation to the rod steps work scope
What I remember on them is less than .375, maybe a tiny bit more shruggy
Re: Carter TQ meetering rod diameter - where to measure? [Re: Cab_Burge] #2389749
10/19/17 11:31 AM
10/19/17 11:31 AM
moparx Offline
moparx  Offline
the rod hanging "tree" on a TQ is also adjustable so you can position the rod in the jet correctly. another adjustable tuning procedure for a TQ.
beer
Re: Carter TQ meetering rod diameter - where to measure? [Re: Diplomat360] #2391791
10/23/17 02:03 PM
10/23/17 02:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
2357 rod not listed in my Carter book
2004 .063" x .049" x .040"
2159 .070" x .062" x .040"
Floyd Lippencott IV
