Re: 1" Dominator/4150 adapter needed...............
[Re: MartyQ]
#2388749
10/17/17 02:33 PM
10/17/17 02:33 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I can't access that but if it's an e-bay thing, not interested but thankxxx.............
[Re: Thumperdart]
#2388795
10/17/17 03:51 PM
10/17/17 03:51 PM
Posts: 1,317 Ohio
jlatessa
Ohio
I have a Wilson 1-1/2" high, 3-7/8" sq. to 4-3/4" sq.
Can you use that? Let me know, I'll send it off...Joe Latessa
PS Wilson # 27030
[Re: srunge55]
#2389017
10/17/17 10:33 PM
10/17/17 10:33 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
Which heads and intake are you running now?
[Re: Thumperdart]
#2389060
10/17/17 11:44 PM
10/17/17 11:44 PM
Posts: 487 St Louis, MO, USA
srunge55
St Louis, MO, USA
I'm building a low deck 512. Planning to use the Trick Flow 270 heads. I have a Indy 400-3 single plan intake. It appears to have had some deep port work done to it (I don't know who or what exactly, bought it that way). Since this will be a street/strip car (70/30) I thought I should use a 4150 carb. A friend of mine has a bunch of carb parts laying around so I'm building a mongrel carb from them. I have a 950 Proform body with a QF base. I need to buy some metering blocks for it. I was thinking maybe these https://www.summitracing.com/parts/qft-34-10qft/overview/ . I'd love to hear any recommendations. Thanks, Steve
[Re: srunge55]
#2389132
10/18/17 02:48 AM
10/18/17 02:48 AM
Cab_Burge
[Re: srunge55]
#2389282
10/18/17 01:00 PM
10/18/17 01:00 PM
Thumperdart
State of confusion
Which one did you order from Summit? I'm planning to run a 4150 on a 4500 intake (I have the intake and don't want to buy a new one, plus it has some extra porting done to it also). From the people I talked to so far I'm not sure its a good idea. Anyone else doing this and how is it working for you?
Debating whether I should break down and just buy a 4150 intake.
thanks,
Steve Got the 2" made by Dart but I flip it over just for running 4150's in the garage not driving but the BLP's I build have a dual pattern base plate. Cab, I run the Victor heavily ported by Ed Mosler and a 2" fully blended adapter.........
