Greasable LCA Pivot Shaft & Bushing? #2387458
10/14/17 07:35 PM
10/14/17 07:35 PM
IN
polaraholic Offline OP
IN
Has anybody used greasable lower control arm bushings and pivot shafts?
What are your thoughts on them?
I have a k-frame for my 64 Polara and thought I had all new or restored parts to put the whole suspension together. I can only find one new original pivot shaft & bushing. I see on ebay someone has a greasable set and wondered if they are any good.
The grease zert is in the threaded end of the shaft.
Also does anybody have a diagram of how offset upper control arm bushings are installed?
Re: Greasable LCA Pivot Shaft & Bushing? [Re: polaraholic] #2387467
10/14/17 08:09 PM
10/14/17 08:09 PM
IN
ahy Offline
ahy  Offline
IN
I run the Firm Feel greasable LCA pivot. Run hard and works fine. I am sure you know the "greasable" type is for poly bushings. It won't work with rubber bushings. With poly LCA bushings, every part and dimension needs to be right on target or you can get movement at the LCA pivot. Adjustable strut rods may be needed to keep everything snug. Rubber is more forgiving in this area.
Suggest you check out Firm Feel. They probably have the standard pins. If you want greasable, I would trust their stuff.
Re: Greasable LCA Pivot Shaft & Bushing? [Re: polaraholic] #2387469
10/14/17 08:17 PM
10/14/17 08:17 PM
IN
IN
I've had a hard time finding a stock shaft for a 64. I don't know what other years will fit them.
bow I googled how to install the upper bushings and it referenced me to moparts.org so I found it. bow
Re: Greasable LCA Pivot Shaft & Bushing? [Re: polaraholic] #2387538
10/14/17 11:34 PM
10/14/17 11:34 PM
BDW Online content
BDW  Online Content
Re: Greasable LCA Pivot Shaft & Bushing? [Re: polaraholic] #2387594
10/15/17 02:49 AM
10/15/17 02:49 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Zert fittings or Zerk ?
Re: Greasable LCA Pivot Shaft & Bushing? [Re: Kern Dog] #2388471
10/16/17 11:30 PM
10/16/17 11:30 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Zerk, See:
https://www.saeproducts.com/grease-fitti...AYaAvjnEALw_wcB
Re: Greasable LCA Pivot Shaft & Bushing? [Re: denfireguy] #2388544
10/17/17 02:11 AM
10/17/17 02:11 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I keep several pairs around for future projects
Abe Lincoln
