Vote for the Carb(s) I test on the Dyno!
#2388314
10/16/17 07:26 PM
10/16/17 07:26 PM
BradH
OK, sometimes I can't help myself from posting this sort of stuff... even when I probably shouldn't for a variety of reasons. None the less... I have an ever-expanding collection of 4150-type carbs as listed below. As much as I'd like to throw each one on the engine dyno to see what's what, the reality of time constraints will likely limit testing to two, maybe 3, if any level of dialing in a particular carb is to be done. In addition, one carb that absolutely needs to be in the subset being tested is the #1 carb in the list, because that's the last baseline I have and what was run successfully on my car in the past. ------------------------------------------------------------------------------------- 1. BG Race Demon RS set up w/ 1.42" venturi sleeves => previous tune as used on my car when it ran 10.5s as driven to the track ------------------------------------------------------------------------------------- So... that means you can pick two (2) of the remaining carbs listed. 2. BG Gold Claw set up w/ 1.50" venturi sleeves => new & untested config => pushing the limit for venturi size w/ downleg boosters that I believe will work well on my car 3. QFT/Proform 1.45" venturi main body used as basis for complete carb => original boosters; new & untested => Basically a Proform "950" with a better tune 4. QFT/Proform 1.52" venturi main body used as basis for complete carb => BLP modified boosters; new & untested; this is the limit for venturi size w/ downleg boosters I'll try => comparable to a QFT Race-Q 1000, which Quick Fuel used to win the small-block class in the last BLP Carb Challenge held a few years ago 5. QFT/Proform 1.59" venturi annular booster main body used as basis for complete carb => original boosters; new & untested => comparable to a QFT Race-Q 1050-AN, which AndyF said has been the best performing 4150 carb he's tested so far 6a. Holley Ultra HP/XP 1.60" venturi carb re-fitted with Mark Whitener's custom annular boosters => purchased from AndyF 'cuz I thought it looked "interesting" => Dominic "Thumper Carbs" worked on the tune to make it more driveable vs its original dyno tune 6b. Same as #6a, only with Holley Ultra HP/XP 1.56" venturi main body blended out to 1.58" and equipped with the same 12-hole annular boosters as the #5 carb => new & untested config => Mark Whitener's flow testing of a variety of carbs showed the modified Ultra HP/XP 1.56" (1.58") venturi main body flowed noticeably better than Holley's 1.60" venturi body... so I decided to build one ------------------------------------------------------------------------------------- Do your votes really count towards what I run? Ummmm... nope. The final choices are still mine, but I'm interested in hearing people's feedback & thoughts on the subject, regardless. Before anyone says anything about it - right, no Dominators. I'm A$$uming most people are familiar w/ my junk, as much as I've posted over the years. If you're not, the $.05 tour will be brief: - 440 street/strip car - 3800#s w/ driver - pump fuel... that'll probably need to get spiked w/ some race gas cuz the CR is now up to 11.5 - 4500-stall converter - 4.10s - 275/60R15 DOT drag radials - Guess-timating the new combination will make... 650+ HP... and the car "should" be capable of running closer to 10.0s once sorted out OK, back to all the other stuff I have to deal with. - Brad
Re: Vote for the Carb(s) I test on the Dyno!
[Re: BradH]
#2388344
10/16/17 08:04 PM
10/16/17 08:04 PM
Posts: 4,457 Washington
madscientist
Washington
Send a carb to Dom and have him tune up it. Use that as your base carb.
[Re: BradH]
#2388363
10/16/17 08:41 PM
10/16/17 08:41 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Is this testing going to be on a engine dyno or chassis dyno? Test the three biggest ones, #5 and 6A Are you going to change the jetting on all of them or not?
[Re: madscientist]
#2388365
10/16/17 08:46 PM
10/16/17 08:46 PM
BradH
Send a carb to Dom and have him tune up it. Use that as your base carb. That would be 6a, as noted in the description. Also, 6b is 6a with a main body swap, not two separate carburetors. That's why they're not listed as 6 & 7.
[Re: Cab_Burge]
#2388368
10/16/17 08:48 PM
10/16/17 08:48 PM
BradH
Is this testing going to be on a engine dyno or chassis dyno? Test the three biggest ones, #5 and 6A Are you going to change the jetting on all of them or not? Engine dyno. Bringing lots of brass, but time is always a factor.
[Re: BradH]
#2388384
10/16/17 09:16 PM
10/16/17 09:16 PM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Brad , #1 , 4 , 6b
#1 because it is a known unit . #4 bigger venturi same style . I ran a HP1000,1.56 venturi , on my 440 . Very happy, more power than my BG 825 #6b , a little bigger again . But if #4 shows improvement this will then show if annular is better for your motor . Then you will have to try them all again on the street / strip to confirm results .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: BradH]
#2388394
10/16/17 09:25 PM
10/16/17 09:25 PM
madscientist
Washington
Send a carb to Dom and have him tune up it. Use that as your base carb. That would be 6a, as noted in the description. Also, 6b is 6a with a main body swap, not two separate carburetors. That's why they're not listed as 6 & 7. Sorry, I flat missed that.
[Re: BradH]
#2388460
10/16/17 11:22 PM
10/16/17 11:22 PM
Posts: 1,979 s. e. pa.
calrobb2000
s. e. pa.
hi ,
i vote for trashing them all and using a holley 3 bbl !
[Re: BradH]
#2388531
10/17/17 01:37 AM
10/17/17 01:37 AM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
1, 5, 6a & b
Then, time permitting 2 or 4.
If they aren't "close" ootb...... It can really eat up dyno time trying to sort them out.
IMO, with limited dyno time available, if you bolt one on and it's just out to lunch...... I'd put that one aside and try a different one.
[Re: BradH]
#2388703
10/17/17 12:57 PM
10/17/17 12:57 PM
fast68plymouth
So. Burlington, Vt.
I made my picks, but I'm in agreement with Andy on this point...... Test the ones you think will be/want to be the best first.
Edit- after hearing Doms comments about the 6a being a little fat..... I guess I'd start out with the known quantity tune of the #1 carb. No point in risking washing the rings down right off the bat.
I'd do the initial run it with the #1 carb, get it all warmed up, lash the valves, make a couple pulls ...... And hopefully that carb has a decent enough fuel curve to establish a baseline without having to do a bunch of tuning on it.
The next carb I'd try would be the 6a.
[Re: davenc]
#2389058
10/17/17 11:41 PM
10/17/17 11:41 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
TEST THEM ALL, LET DYNO SORT THEM OUT
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: BradH]
#2389125
10/18/17 02:23 AM
10/18/17 02:23 AM
Posts: 304 Florida
Mark Whitener
#5, 6B will be nearly identical but 5 gets the nod. Scrap the 1.60 you got from Andy for the test. And the Race Q1000 down leg should be a 1.500 venturi, that might be an interesting test against the 1.59 annular.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: AndyF]
#2389289
10/18/17 01:12 PM
10/18/17 01:12 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
6a was dialed in pretty good when I ran it. AFR was in the low 13's, made 650 hp on my 470 back before the intake was ported, BSFC was 0.400, Correction Factor was 1.02 so pretty good air. Dyno shop is close to sea level.
My dyno sheets show that we had 88 and 99 jets in it for those pulls. That was the Mark W tune. Worked great from 3500 to 7000 rpm. If you're testing near sea level then I'd use the original Mark W. tune and let it rip. Makes sense that as MOST dyno's do from 3500-7500 and up it may have been ok but trust me, it killed my oil n plugs below that and could NOT even do a burnout. I'm not bagging on anyone or pointing fingers but on the steet where it matters most, it was a pig and I know it was loaned out as well so who knows there. IIRC, it had .080-.090 but not 100% and not near my book..............I see zero reasons to EVER run a 4150 on any motor making good power and have proved it many times even on small-blocks that have picked up a several mph and .010's so me, I'd ditch/sell em all and put a real carb on that puppy........... And .088-.099 jets........that's insane and even 1250's rarely run that size which should tell ya something...........
[Re: Mark Whitener]
#2389333
10/18/17 03:10 PM
10/18/17 03:10 PM
BradH
#5, 6B will be nearly identical but 5 gets the nod. Scrap the 1.60 you got from Andy for the test. I had been thinking along the same carbs to test (the QFT 1.52 downleg & the QFT 1.59 annular) along w/ the baseline BG. The Holley 1.60 annular conversion is sitting on a stand ready to bolt on (except I did notice the linkage is binding for some reason). No reason not to at least throw it on to see how it does... time permitting. And the Race Q1000 down leg should be a 1.500 venturi, that might be an interesting test against the 1.59 annular. That's what I expected, too (i.e., 1.50" venturi). However, I measured mine after you installed the BLP boosters and found it measured 1.52", and later on found a QFT spec sheet that listed the RQ-1000 as 1.52", also. It makes sense, considering their venturi increases from "950" to "1000" is .07", and from "1000" to "1050" is another .07".
[Re: sixpackgut]
#2389337
10/18/17 03:11 PM
10/18/17 03:11 PM
BradH
TEST THEM ALL, LET DYNO SORT THEM OUT This is the carburetor equivalent of "Kill 'em all. Let God sort 'em out.", right?
[Re: davenc]
#2389339
10/18/17 03:13 PM
10/18/17 03:13 PM
BradH
What criteria are you planning to use to evaluate the carbs? Peak numbers, area under the curve, something else?? The evaluation won't be strictly on peak HP & torque #s, but also the fuel curve, amount of air being used, differences in where a particular carb might show better than another, etc. I've seen where two carbs that made virtually the same power on the dyno still ran .2 & 2 MPH differently on the car. Whatever looks like the most worth testing based on the dyno results will still get flogged on the car to prove it.
[Re: BradH]
#2389354
10/18/17 03:32 PM
10/18/17 03:32 PM
sixpackgut
Charleston
TEST THEM ALL, LET DYNO SORT THEM OUT This is the carburetor equivalent of "Kill 'em all. Let God sort 'em out.", right? Yes
[Re: AndyF]
#2389477
10/18/17 08:07 PM
10/18/17 08:07 PM
BradH
Any chance you have more carbs than you need Brad? Why the He11 would you think that??? Oh wait, before you answer that would you like to buy a carb Brad? I don't think I need my QF-1050-AN anymore now that I switched to EFI so I'll make you a good deal on it....... That reminds me... can you provide me w/ your QFT RQ-1050-AN tune so I can duplicate it w/ all the parts I have sitting around to build one myself?
[Re: BradH]
#2389623
10/19/17 12:05 AM
10/19/17 12:05 AM
Posts: 598 NC, USA
davenc
NC, USA
And that is what I was wondering. If the criteria isn't clear going into your test, you may pick the wrong carbs to test. To me, it would seem that the best criteria would be area under the curve, in the RPM range encountered during the run; the right carb for a narrow range is likely different than for a wider range. Not knowing any of those details, my vote would be for 1, 4, and 6B.
[Re: davenc]
#2389718
10/19/17 08:53 AM
10/19/17 08:53 AM
BradH
And that is what I was wondering. If the criteria isn't clear going into your test, you may pick the wrong carbs to test. To me, it would seem that the best criteria would be area under the curve, in the RPM range encountered during the run; the right carb for a narrow range is likely different than for a wider range. Not knowing any of those details, my vote would be for 1, 4, and 6B. The on-track differences like I pointed out were due to shift recovery (how quickly the carb adjusts to change in RPM & load) characteristics, which a basic engine dyno doesn't take into account.
