Re: What will cause a wheel stud to do this?
[Re: 79machocharger]
#2388024
10/16/17 07:23 AM
10/16/17 07:23 AM
Posts: 5,764 ohio
ruderunner
ohio
I'm with 6bblgt, incorrect lug nuts not threaded deep enough.
Don't drive the truck, your wheels are loose. Examination of the lug holes in the wheels is needed.
Open ended lugs, trimmed studs are options for fixing.
Angry white pureblood male
#2388026
10/16/17 07:53 AM
10/16/17 07:53 AM
Posts: 5,443 ME
79machocharger
ME
Just realized what I did wrong, got looking on eBay and it looks likes 2016 ram takes 14 1.5 lug nuts. Man I hope I just didn't ruin all my threads
#2388037
10/16/17 09:49 AM
10/16/17 09:49 AM
Posts: 10,126 A Red State
SNK-EYZ
A Red State
Just realized what I did wrong, got looking on eBay and it looks likes 2016 ram takes 14 1.5 lug nuts. Man I hope I just didn't ruin all my threads That would do it. All the newer Mopars have Metric thread wheel studs.
[Re: moparx]
#2388307
10/16/17 07:11 PM
10/16/17 07:11 PM
Challenger 1
Cincinnati, Ohio
Thanks for info guys, the lugs nuts were inclosed long gorilla brand ones. I'll go and get some open ended ones and trim off the bad part like you said i can't recommend this, as then your studs may be too short to use with your new wheels. i would replace all the studs. if you look close, your pic shows thread damage below the really buggered up portion [the shiny three or so threads]. these threads are deformed, and i wouldn't trust 'em. i know that may not be what you would want to hear, but 20 studs would be WAY cheaper than a crashed truck. just my opinion, and repairing threads in many things over 50+ years. Yes I agree, all 20 studs need to be replaced. At least it was not 24 or more lugs. So sorry and not trying to be negative but once you force the wrong sizes together it destroys both fasteners. So sorry it happened. Please replace those studs and get new lug nuts and and chock it up as a learning experience.
#2388326
10/16/17 07:38 PM
10/16/17 07:38 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Relatively cheap learning experience!
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2388380
10/16/17 09:07 PM
10/16/17 09:07 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
I really hate to break with the pack but I wouldn't go out and start replacing the studs just yet. When I look at the pictures I see 75% of the stud untouched. I'd get a metric die and clean the threads up. Not a thread chaser, a die. Then I'd do some careful measurements to see how much of the studs would be engaged by the nuts. If the nuts engage at least two thirds of the stud, I'd just drive it. Now if you have driven the truck with the incorrect nuts, then I'm with the pack. I'm sure the studs have been flexed and that's never good.
#2388507
10/17/17 12:51 AM
10/17/17 12:51 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Have to agree with not replacing the studs but disagree with 6pacBee on the use of a threading die. I would use a thread chaser. A thread chaser will straighten the damaged threads, a die will cut new threads where they are damaged reducing the strength in the damaged area. Just get the proper lug nuts after you fix the threads.
[Re: 6PakBee]
#2388512
10/17/17 01:00 AM
10/17/17 01:00 AM
Posts: 10,537 Freeport IL USA
poorboy
Freeport IL USA
I really hate to break with the pack but I wouldn't go out and start replacing the studs just yet. When I look at the pictures I see 75% of the stud untouched. I'd get a metric die and clean the threads up. Not a thread chaser, a die. Then I'd do some careful measurements to see how much of the studs would be engaged by the nuts. If the nuts engage at least two thirds of the stud, I'd just drive it. Now if you have driven the truck with the incorrect nuts, then I'm with the pack. I'm sure the studs have been flexed and that's never good. Sorry this is wrong. I see at least 1/2 of the threads on the front 3 studs are messed up. The studs are cheap, replace all of them, and all of the lugs on each wheel you tried to force the incorrect lug nuts onto. Gene
[Re: poorboy]
#2388583
10/17/17 05:06 AM
10/17/17 05:06 AM
6PakBee
North Dakota
I really hate to break with the pack but I wouldn't go out and start replacing the studs just yet. When I look at the pictures I see 75% of the stud untouched. I'd get a metric die and clean the threads up. Not a thread chaser, a die. Then I'd do some careful measurements to see how much of the studs would be engaged by the nuts. If the nuts engage at least two thirds of the stud, I'd just drive it. Now if you have driven the truck with the incorrect nuts, then I'm with the pack. I'm sure the studs have been flexed and that's never good. Sorry this is wrong. I see at least 1/2 of the threads on the front 3 studs are messed up. The studs are cheap, replace all of them, and all of the lugs on each wheel you tried to force the incorrect lug nuts onto. Gene This is what I see from the picture. On the closest stud there are about four threads that are destroyed. Then there are about 6 threads that look to have some damage. The remainder (14-16) look pristine. How many threads do you need to achieve rated tensile loading on the stud? I would guess a little over half an inch. I did compare a 9/16 NF thread to a 14 1.5 metric. 0.5625 major diameter and 18 TPI versus 0.5512 major diameter and 17 TPI (based on 1.5 mm/thread). I can see how the two worked, kind of. This is just my opinion.
#2388630
10/17/17 10:59 AM
10/17/17 10:59 AM
Posts: 3,041 N.W. Florida
Fat_Mike
N.W. Florida
Looks like I'll need to take axles out to replace the back studs. I'll change them out to be safe. I really wish they would put the size on the factory lug nuts. I did notice last night that there was a M on the end of the nut. I would replace them also, if for no other reason, peace of mind. I'm not sure pulling the axle is necessary though. Most vehicles have a hole or slot somewhere on the backside that'll allow room to push out/pull in the studs. Having said that, I've never pulled an axle on one of those...maybe it's the easiest route.
[Re: 6PakBee]
#2388647
10/17/17 11:15 AM
10/17/17 11:15 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you do not know the answer to that question you shouldn't comment. The minimum engagement is the same as the diameter. If you have a 1/2" stud you need at least 1/2" engagement. Looks to me like EVERY thread the wrong lug nuts engaged are damaged to some extent. The undamaged threads were not engaged by the lug nuts. Questions is, how did they ALL get damaged like that. Impact wrench. Which is exactly why I do not use them in install lug nuts.
[Re: Supercuda]
#2388811
10/17/17 04:14 PM
10/17/17 04:14 PM
6PakBee
North Dakota
Nothing like being lectured by someone who apparently doesn't know what a rhetorical question is.
#2388873
10/17/17 06:04 PM
10/17/17 06:04 PM
Supercuda
About to go away
About to go away
up yours
When safety is on the line rhetorical questions are stupid.
As is the suggestion to clean them up and run them.
Any more comments?
[Re: Supercuda]
#2389013
10/17/17 10:28 PM
10/17/17 10:28 PM
6PakBee
North Dakota
Any more comments? Anyone who doesn't appreciate the value of rhetorical questions is an idiot. What is it like to know everything about anything? I'll bet you feel real special waking up in the morning being the last word on anything. You got any more comments? I mean useful ones other than this garbage you keep posting? There's such a thing as civility, apparently yo' momma didn't teach you that. It's people like you who make me wonder after all these years why I'm still on this forum. I'm done with you.
