6-Pack Carb Throttle Linkage Plating #2387639
10/15/17 10:43 AM
10/15/17 10:43 AM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I'd like to re-plate the throttle linkage component for my 6-Pack outboard carbs, but am not sure what the correct plating should be for the threaded rods, clips, etc.
Does anyone have a good reference picture of correctly restored linkage components on an OE restored 6-pack, or maybe an unrestored survivor?
Thanks everyone.
Re: 6-Pack Carb Throttle Linkage Plating [Re: B5Cuda440-6] #2387714
10/15/17 01:20 PM
10/15/17 01:20 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
First thing. The plating finishes varied. What I'm listing is what I've seen the most often.
Retention clips = Black phosphate
End link arms = Gold (usually silver with a lighter gold wash over the silver)
Center carb swivel and threaded link arm receivers = Gold
Center swivel "Axle" = Silver
Washers on center swivel = Silver
Cotter pin retaining swivel to throttle arm = Silver
Hairpin clip = Black phosphate
Idle stop solenoid adjuster screw = Silver
Idle stop adjuster screw retention clip = Black phosphate
Re: 6-Pack Carb Throttle Linkage Plating [Re: B5Cuda440-6] #2387792
10/15/17 05:09 PM
10/15/17 05:09 PM
Indianapolis, IN
Indianapolis, IN
Thanks Scott. Can I send my linkage to you with my carbs to correctly re-plate?
Rob
Re: 6-Pack Carb Throttle Linkage Plating [Re: B5Cuda440-6] #2387796
10/15/17 05:33 PM
10/15/17 05:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, no extra charge
Re: 6-Pack Carb Throttle Linkage Plating [Re: B5Cuda440-6] #2387800
10/15/17 05:41 PM
10/15/17 05:41 PM
Indianapolis, IN
Indianapolis, IN
Perfect!! Thanks, Scott. I'll add it to the package.
Rob
Re: 6-Pack Carb Throttle Linkage Plating [Re: ScottSmith_Harms] #2387956
10/16/17 12:31 AM
10/16/17 12:31 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Got to remember that deal.
