Base plate for Holley
#2387504
10/14/17 10:39 PM
10/14/17 10:39 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Is this base plate OK for use with 4-corner idle carb. I need to have port to attach a vacuum gauge and a PCV valve and my current Quick Fuel base doesn't have any ports on it. I was going to get this Quick Fuel replacement and I was just wondering if it would work. I really don't know how to identify a 4-corner idle base plate. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Base plate for Holley
[Re: rickraw]
#2387537
10/14/17 11:31 PM
10/14/17 11:31 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Or a 1 inch spacer if you have room
[Re: AndyF]
#2387574
10/15/17 01:28 AM
10/15/17 01:28 AM
fourgearsavoy
Rittman Ohio
Well the nice thing about living 20 minutes from Summit is that I can look at it before I buy it. I may still just go with a spacer an re-engineer my air cleaner with a 1" shorter element because there's not much room with the Performer RPM and a stock hood. I would drill the intake but it's a dual plane and I would have to go into the side of the plenum and I would really like to get a better signal to this new PCV. Thanks guys Gus
[Re: fourgearsavoy]
#2387578
10/15/17 01:43 AM
10/15/17 01:43 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well the nice thing about living 20 minutes from Summit is that I can look at it before I buy it. I may still just go with a spacer an re-engineer my air cleaner with a 1" shorter element because there's not much room with the Performer RPM and a stock hood. I would drill the intake but it's a dual plane and I would have to go into the side of the plenum and I would really like to get a better signal to this new PCV. Thanks guys Gus I just bought this air cleaner base from summit because I wanted to put an air pan on my Duster and needed it dropped down because of my high intake and 1 inch spacer. It dropped me down 2 inches. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
[Re: pittsburghracer]
#2387582
10/15/17 01:55 AM
10/15/17 01:55 AM
fourgearsavoy
Rittman Ohio
That looks like one of those circle track deals,I might have to look at one of those. I'd like to keep my 4" element. Gus
[Re: crackedback]
#2387674
10/15/17 11:53 AM
10/15/17 11:53 AM
fourgearsavoy
Rittman Ohio
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer I have always wanted to try it so here is my opportunity. I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base. Thanks guys Gus
[Re: fourgearsavoy]
#2387677
10/15/17 12:01 PM
10/15/17 12:01 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer I have always wanted to try it so here is my opportunity. I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base. Thanks guys Gus Hope it helps you. Do yourself a favor and either install the fitting before installation or at least check out the threads. Most of these spacers are mass produced and the taps are way past being worn out. Easier to check on the workbench than while bending over a fender.
[Re: fourgearsavoy]
#2387686
10/15/17 12:11 PM
10/15/17 12:11 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I believe that is a four corner idle base plate. The holes on the outside of the transfer slots are the idle ports. There are four. Sine most cars benefit from a spacer, I would rather go that approach, myself. I would make sure there are 2 holes. 1 for the PCV, 1 for your vacuum gauge. You won't get an accurate vacuum reading if you use the same port where you already have a vacuum leak coming in (PCV is only a regulated vacuum leak).
[image][/image]
[Re: fourgearsavoy]
#2387698
10/15/17 12:31 PM
10/15/17 12:31 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer I have always wanted to try it so here is my opportunity. I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base. Thanks guys Gus Yep, and if you run the WIX racing a 3" flows more than your present carb iirc and I run one w/a 1050 or 1150 dommy w/out issues. Plus the added plenum volume usually helps accordingly..........
#2387775
10/15/17 04:14 PM
10/15/17 04:14 PM
Posts: 4,457 Washington
madscientist
Washington
Well the nice thing about living 20 minutes from Summit is that I can look at it before I buy it. I may still just go with a spacer an re-engineer my air cleaner with a 1" shorter element because there's not much room with the Performer RPM and a stock hood. I would drill the intake but it's a dual plane and I would have to go into the side of the plenum and I would really like to get a better signal to this new PCV. Thanks guys Gus I just bought this air cleaner base from summit because I wanted to put an air pan on my Duster and needed it dropped down because of my high intake and 1 inch spacer. It dropped me down 2 inches. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr Can you post a link to that base PBR? I just looked on summit and I don't see it. Thanks
[Re: madscientist]
#2387867
10/15/17 09:22 PM
10/15/17 09:22 PM
fourgearsavoy
Rittman Ohio
Well I put the spacer under the carb and installed my new Wenger PCV valve and the engine seems to idle smoother. I haven't driven it yet to get some butt dyno figures but the air is really cool around here now so it's hard to tell. I'm thinking of hitting the Halloween thing at D42 this weekend so we'll see how the spacer works on the track. Gus
[Re: Thumperdart]
#2387881
10/15/17 09:53 PM
10/15/17 09:53 PM
fourgearsavoy
Rittman Ohio
Here's another thought....K&N SUCKS the power outta your motor NOT adds it..........fact......... Yeah Dom I gotta laugh when a car rolls into the shop with a "cold air kit" It's next to impossible to beat the factory set-up on any car. Many times I try to get customers to go back to a factory filter and they won't because they believe the hype Gus
[Re: fourgearsavoy]
#2387929
10/15/17 11:35 PM
10/15/17 11:35 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
The Engine Masters show did a test with like 40 different air filters recently, pretty interesting results!
68 Barracuda Formula S 340
[Re: Bad340fish]
#2387976
10/16/17 01:19 AM
10/16/17 01:19 AM
Thumperdart
State of confusion
What were they...........
[Re: fourgearsavoy]
#2388195
10/16/17 03:05 PM
10/16/17 03:05 PM
Bad340fish
Tulsa OK
Keep an eye on youtube they will probably release it soon, they checked everything from a stock single snorkle(lost 150HP) to a stainless steel salad bowl cut to fit the carb and sealed with a K&N filter top. It was a really cool episode, they relase it on Motor Trend on demand first for members but it should eventually hit youtube.
[Re: Leigh]
#2392537
10/24/17 08:45 PM
10/24/17 08:45 PM
fourgearsavoy
Rittman Ohio
Well my engine doesn't like the spacer as jetted. It has a lean stumble at tip in that it didn't have before the spacer so either I try and jet up and tune my pump shot or just change the base plate I was whipped by a ZO6 Vette last weekend at the track He got hook on street rubber and I blew the tires off at the hit but I had his bumper at the stripe. Talked to him after the race and he said he heard my coming about half track Gus
[Re: Thumperdart]
#2392672
10/25/17 12:17 AM
10/25/17 12:17 AM
fourgearsavoy
Rittman Ohio
Just a basic 1" spacer with a port on it for a PCV hose. It's definitely running lean because it was never "cold blooded" before. I'm just gonna get a baseplate for it and get rid of the spacer and go back to way my engine used to run. Gus
[Re: fourgearsavoy]
#2392733
10/25/17 02:21 AM
10/25/17 02:21 AM
Thumperdart
State of confusion
Rich-en it up w/the mixture screws first or idle bleeds since those are easy enuff to do and if it's in the cruise zone that will help. Worse case, jet up a bit IF you are on the boosters.........
[Re: Thumperdart]
#2393033
10/25/17 07:36 PM
10/25/17 07:36 PM
fourgearsavoy
Rittman Ohio
Thanks Dom. I turned the mixture screws out and it brought the idle up and a little more smooth and easy. I have never changed the air bleeds so I'm gonna have to get some do a little research on which ones are the idle bleeds. I still have a power valve on the primaries and I'm thinking of changing it to a higher number and see if it helps with my tip in stumble. Gus
[Re: fourgearsavoy]
#2393050
10/25/17 08:03 PM
10/25/17 08:03 PM
Thumperdart
State of confusion
Outer's idle, inner's next to bowl vents hi speed bleeds..........If the idle came up, it's talkin to ya......... Are they adjustable or fixed.........
[Re: Thumperdart]
#2393076
10/25/17 09:13 PM
10/25/17 09:13 PM
fourgearsavoy
Rittman Ohio
Yeah they're screw in bleeds on a Proform 1050 body with Quickfuel blocks and bowls. It's got a Quick fuel cast baseplate too. I should probably get an AFR gauge kit and really get it dialed in because I know how to read my plugs but on a street/strip car it's hard to get a good clean read on them. I'm going to pull the bleeds that are in there now so I know where to go with them. Gus
