Re: Does Harbor Freight sell a DECENT engine hoist?
[Re: BradH]
#2387409
10/14/17 04:52 PM
10/14/17 04:52 PM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought a fold up Goodyear engine hoist years ago and like it so much when I saw a used one local for 80.00 I grabbed it for my house garage. Now I don't have to drag it 100 feet thru the gravel.
[Re: BradH]
#2387529
10/14/17 11:10 PM
10/14/17 11:10 PM
Posts: 4,457 Washington
madscientist
Washington
I have one and it's fine. Just get the bigger model.
[Re: BradH]
#2387624
10/15/17 09:45 AM
10/15/17 09:45 AM
Posts: 314 Medina, OH
dart440_72
Medina, OH
I have one. It has always worked fine. No issues here
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: BradH]
#2387655
10/15/17 11:20 AM
10/15/17 11:20 AM
Challenger 1
Cincinnati, Ohio
Hard to coordinate with the local tool rental places, so I'm considering purchasing one. There is a Harbor Freight nearby, but IIRC there have been a lot of complaints about their hoists leaking, possibly other issues, too.
Any feedback available here to help with my decision? Thanks - Brad Back around 1985 I bought this one from the local tool rental without a hydraulic cylinder. I rented one just like it so many times one day asked how much to buy it and he sold me this hoist/crane without a lift cylinder for 200 bucks. That was a lot of money then and it took me months more to save up for a hydraulic cylinder. Used it for larger V8 truck engines which are much heavier than a 440. I have wore out 2 cylinders over the years using it. It is holding up the front of the car in this picture. Then I bought this a few years ago from the local auto parts store, I think I gave around 190 bucks for it. I got it because it folds up and is easier to use at home and I keep my one above at work in my race shop. Used to take it home to use. I use the import one to do light duty work like lift the front of the lawn mover to clean the deck and change blades and small block engine swaps. I feel this hoist was at it's limit in this case, would not feel comfortable doing this with a big block engine. My driveway was a little out of level which made the hoist very unstable. Nothing like my wide base breakdown model I showed above which is way better. FYI. And when I got it in, the crane was touching the front bumper. It does not have the reach that my other crane has. A car with longer front end it would not work. I did the install by myself in a afternoon.
[Re: BradH]
#2387685
10/15/17 12:11 PM
10/15/17 12:11 PM
Challenger 1
Cincinnati, Ohio
The complaints I see repeated about the current models they offer include things like parts not fitting correctly, incomplete parts and/or hardware packed, machine work issues, etc. I don't have the time or patience right now to deal with any of that crap and will look elsewhere for a solution to my immediate need. I would keep an eye out for used one like the breakdown model I showed above.
[Re: BradH]
#2387691
10/15/17 12:18 PM
10/15/17 12:18 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
The smaller silver one that HF always puts on sale isn't worth it. Won't work for us. Not enough capacity or reach. The full size one isn't bad. The best thing I ever did was buy a second hand heavy duty hoist that had a leaking cylinder. Got a $60 ram from HF. They have several models, so getting a compatible one was easy. Check your local craigslist listings. You can probably score on a nice fold up one for the right price. I now have 2 hoists so I can pull the body off my Cuda without any help. And everything packs up out of the way when done.
[image][/image]
[Re: BradH]
#2387718
10/15/17 01:27 PM
10/15/17 01:27 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My HF (Maybe it was Northern Tool?) collapsible hoist was purchased in the mid 90s. It has served well and still uses the original cylinder.
Lately, it has developed a habit of tilting to the left under load. Dangerous tilting. When we have to lift an engine rather high I stand on the left rear leg to counter the lean. The hoist is lowered as quickly as possible.
After a thorough examination I found that the hinge holes for the boom were wallowed out and allowing the arm to lean to one side. I bored the holes and made a larger pin. The lean has improved but not gone away. As best I can tell the left leg pin hole is a bit worn. This lets the leg lift, causing the rig to lean.
I plan on getting it straightened out before it gets used again.
[Re: feets]
#2387734
10/15/17 01:52 PM
10/15/17 01:52 PM
RapidRobert
My HF breakdown is OK tho I did weld some gussets where the main vertical leg bolts to the base to further strengthen it.
[Re: BradH]
#2387779
10/15/17 04:26 PM
10/15/17 04:26 PM
Posts: 30,989 Oregon
AndyF
Any feedback available here to help with my decision? Thanks - Brad Brad, tell the wife you need a bridge crane......
[Re: BradH]
#2387781
10/15/17 04:32 PM
10/15/17 04:32 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I bought one for like 99 on sale... only reason I bought it. They apparently have 2 different ones. Well I got mismatched parts and holes didn't line up. So use the base for moving engine/transmissions around. Use the other parts for various things around the shop. Used the hydraulic cylinder on another hoist. So wasn't too upset in the end... but I wouldn't buy one from them again to actually use for lifting engines.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: BradH]
#2388158
10/16/17 02:05 PM
10/16/17 02:05 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I have an Arcan CEH-41 foldable crane 4000 pound unit I bought at the turkey rod run about 25 years ago. I use it many times every day, at work. I replace anywhere from 1 to 3 engines a day. I've replaced the rams about 4 times, just get the 8 ton ram. Last one I bought is air operated so it's a real pleasure compared to having to pump that thing.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: moetown]
#2388201
10/16/17 03:14 PM
10/16/17 03:14 PM
Posts: 10,019 MN
JERICOGTX
MN
I didn't see one in their latest flier...
69 GTX
68 Road Runner
[Re: BradH]
#2388223
10/16/17 03:56 PM
10/16/17 03:56 PM
Posts: 1,379 Az
69hemibeep
Az
I saw this thread earlier and went to HF for some gloves, thats the only thing I buy there. So I went and looked at the engine hoist selection and they had one thing in common, all the welds sucked! HF tools, for when it doesn't matter if the job gets done today!
1969 Hemi Roadrunner 2nd owner
[Re: Guitar Jones]
#2388245
10/16/17 04:48 PM
10/16/17 04:48 PM
Challenger 1
Cincinnati, Ohio
I have an Arcan CEH-41 foldable crane 4000 pound unit I bought at the turkey rod run about 25 years ago. I use it many times every day, at work. I replace anywhere from 1 to 3 engines a day. I've replaced the rams about 4 times, just get the 8 ton ram. Last one I bought is air operated so it's a real pleasure compared to having to pump that thing. Those import cranes like you have are fine for small engines like what you work on. But not enough crane to lift a big block V8 and transmission in our old muscle cars. IMO Plus too many places for it(import) to wear out and become unsafe. I have HF 1/4 mile from the house, only go in there every couple years to buy gloves like said above! lol
[Re: 69hemibeep]
#2388246
10/16/17 04:52 PM
10/16/17 04:52 PM
Challenger 1
Cincinnati, Ohio
I saw this thread earlier and went to HF for some gloves, thats the only thing I buy there. So I went and looked at the engine hoist selection and they had one thing in common, all the welds sucked! HF tools, for when it doesn't matter if the job gets done today! I bought a bunch of HF equipment 25 years ago, like drill presses, hydraulic press, porta power and plenty more for home and at work. Today that same equipment is so cheaply made it is not funny. Sad And I thought it was cheap stuff 25 years ago but now it looks good compared to what they sell now.
[Re: 69hemibeep]
#2388305
10/16/17 07:03 PM
10/16/17 07:03 PM
Posts: 258 Cochise Co, Az, From Detroit
moetown
I saw this thread earlier and went to HF for some gloves, thats the only thing I buy there. So I went and looked at the engine hoist selection and they had one thing in common, all the welds sucked! HF tools, for when it doesn't matter if the job gets done today! If you look at the welds on most of the fold up cranes under 300.00, they all have the same hit and miss welds.
[Re: BradH]
#2390598
10/21/17 12:00 AM
10/21/17 12:00 AM
Posts: 11,484 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have a Sun International cherry picker that I bought out the back of a pick up truck with South Carolina tags years ago. I think the stuff was made in the Carolinas. Old guys on the east coast know who I'm talking about. Thing is heavy made, works great. Had to put a cylinder on it a while back. Don't know if they can still be had or maybe find one for sale. Then there's OTC or some of the professional stuff.
