Re: How will this cam idle?
[Re: hudsonhornet7x]
#2386969
10/13/17 05:31 PM
10/13/17 05:31 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
You will hear it But that 116 lsa is not something I would consider wild as far as a idle goes
if You Like Gremlinsteve. Gremlinsteve Likes You.
#2387144
10/14/17 12:11 AM
10/14/17 12:11 AM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
Got to be carefull on running too tight of an LSA on a bigger cam as the valves have to be able to clear each other so you got to be carefull of bigger valves and bigger cams. I can't speak for certain on that particular cam and any particular combo of valve diameter or head casting.
[Re: fbs63]
#2387250
10/14/17 10:28 AM
10/14/17 10:28 AM
Posts: 1,541 USA
hudsonhornet7x
USA
Is this a cam you have or a grind out of a catalog? I would talk to a cam grinder and tell them what you are looking for. I'm sure they can tighten the lobe sep a bit to get the lopey idle and still have good street performance. This is a cam we currently have, it was made for a well known gen III racer that changed his mind. His car is a 1,000 hp challenger with a vortech supercharger. The price was right, so we snagged it.
[Re: WO23Coronet]
#2387471
10/14/17 08:32 PM
10/14/17 08:32 PM
Posts: 1,541 USA
hudsonhornet7x
USA
What kind of overlap does it have? Using the wallace calculator it shows 16.5 degrees of overlap. Anyone want to tell me it if will have lope? lol.
#2387552
10/15/17 12:14 AM
10/15/17 12:14 AM
Posts: 59 Florida
Sweet5ltr
What's the advertised duration for that camshaft? Honestly, it will most likely sound near stock. Great camshaft for a turbo build.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
#2387648
10/15/17 11:02 AM
10/15/17 11:02 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
It will probably have a good lope if you turn the idle down to 500 RPM, you know like one of those show cars where the idle is so low trying to get it to lope you can count the firing order?
Just kidding I have no idea, sound is always nice to have but let the tire smoke do the talking.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
#2387720
10/15/17 01:29 PM
10/15/17 01:29 PM
gremlinsteve
houston texas
I agree Lope doesn't mean power
If you want lope. Buy another cam
#2396229
10/31/17 06:46 PM
10/31/17 06:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
It will have a slight chop but nothing crazy. Mine is 247/255/114 and sounds nasty cold but smooths out with just a hint of chop warm at 850rpm idle.
Mopar to the bone!!!
