Re: Guesses on E.T and M.P.H 426 hemi
[Re: polyspheric]
#2387425
10/14/17 06:03 PM
10/14/17 06:03 PM
Posts: 675 MI
MI Mopar Works
MI
Where does the 600 hp come from? Its a well thought out combo built for factory stock deag racing. I could go into great detail, but a 11.5:1 426 Hemi with a modern designed camshaft with heads that flow over 375 cfm better be making those kinda numbers in my opinion.
[Re: MI Mopar Works]
#2388357
10/16/17 08:27 PM
10/16/17 08:27 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
It doesn't take much to put a Hemi into the twelves. It will run mid to high twelves. A Hemi has a big high gear, should run 112-115mph.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: DoubleD]
#2389536
10/18/17 09:41 PM
10/18/17 09:41 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I have no doubt it makes 600 HP and It will run in the tens even with "seasoned bias ply tires" - just go watch Dudek run in the high nines with a worn out set of polyglas tires! fricking nutz but it works! That combination is made to work around those tires. That's why it works so well. That chassis/suspension may "look" stock, but it's far from it.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2389554
10/18/17 10:08 PM
10/18/17 10:08 PM
Posts: 2,296 NE Ohio
DoubleD
NE Ohio
I have no doubt it makes 600 HP and It will run in the tens even with "seasoned bias ply tires" - just go watch Dudek run in the high nines with a worn out set of polyglas tires! fricking nutz but it works! That combination is made to work around those tires. That's why it works so well. That chassis/suspension may "look" stock, but it's far from it. it still has leaf springs - I have the dana out the car now under my car before he switched to the 8-3/4 - it not as trick as you think - its how its driven and how much weight is the trunk of the car - the car on the other hand - was well thought out -light weight is the theme and every ounce counts combined with brute high rpm horsepower. Dudek is the master of the class and it shows
