How will this cam idle? #2386809
10/13/17 12:33 PM
10/13/17 12:33 PM
USA
hudsonhornet7x Offline OP
USA
As I am learning about cams this particular one came across my desk:
116 LSA
243/254 @ .050
.615 intake lift, .597 Exhaust lift
This will be a fuel injected engine, and although this is a silly request, I want a VERY lopey idle.
This engine will also be supercharged if that matters.
I know this is kind of a dumb question, but I want to ask!
Re: How will this cam idle? [Re: hudsonhornet7x] #2386969
10/13/17 05:31 PM
10/13/17 05:31 PM
houston texas
gremlinsteve Offline
houston texas
You will hear it
But that 116 lsa is not something I would consider wild as far as a idle goes
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: How will this cam idle? [Re: gremlinsteve] #2387140
10/14/17 12:03 AM
10/14/17 12:03 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Is this a cam you have or a grind out of a catalog? I would talk to a cam grinder and tell them what you are looking for. I'm sure they can tighten the lobe sep a bit to get the lopey idle and still have good street performance.
Re: How will this cam idle? [Re: hudsonhornet7x] #2387144
10/14/17 12:11 AM
10/14/17 12:11 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Got to be carefull on running too tight of an LSA on a bigger cam as the valves have to be able to clear each other so you got to be carefull of bigger valves and bigger cams. I can't speak for certain on that particular cam and any particular combo of valve diameter or head casting.
Re: How will this cam idle? [Re: hudsonhornet7x] #2387173
10/14/17 01:40 AM
10/14/17 01:40 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of overlap does it have?
Re: How will this cam idle? [Re: hudsonhornet7x] #2387225
10/14/17 06:11 AM
10/14/17 06:11 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Like crap! Ain't it cool? boogie
Re: How will this cam idle? [Re: fbs63] #2387250
10/14/17 10:28 AM
10/14/17 10:28 AM
USA
USA
This is a cam we currently have, it was made for a well known gen III racer that changed his mind. His car is a 1,000 hp challenger with a vortech supercharger.
The price was right, so we snagged it.
Re: How will this cam idle? [Re: WO23Coronet] #2387471
10/14/17 08:32 PM
10/14/17 08:32 PM
USA
USA
Using the wallace calculator it shows 16.5 degrees of overlap.
Anyone want to tell me it if will have lope? lol.
Re: How will this cam idle? [Re: hudsonhornet7x] #2387552
10/15/17 12:14 AM
10/15/17 12:14 AM
Sweet5ltr Offline
Sweet5ltr  Offline
What's the advertised duration for that camshaft? Honestly, it will most likely sound near stock. Great camshaft for a turbo build.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: How will this cam idle? [Re: hudsonhornet7x] #2387648
10/15/17 11:02 AM
10/15/17 11:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It will probably have a good lope if you turn the idle down to 500 RPM, you know like one of those show cars where the idle is so low trying to get it to lope you can count the firing order?
Just kidding I have no idea, sound is always nice to have but let the tire smoke do the talking.
68 Barracuda Formula S 340
87 "Chrysler" Conquest
Re: How will this cam idle? [Re: hudsonhornet7x] #2387720
10/15/17 01:29 PM
10/15/17 01:29 PM
houston texas
houston texas
I agree
Lope doesn't mean power
If you want lope. Buy another cam
Re: How will this cam idle? [Re: hudsonhornet7x] #2396229
10/31/17 06:46 PM
10/31/17 06:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It will have a slight chop but nothing crazy. Mine is 247/255/114 and sounds nasty cold but smooths out with just a hint of chop warm at 850rpm idle.
Mopar to the bone!!!
Re: How will this cam idle? [Re: hudsonhornet7x] #2396242
10/31/17 07:12 PM
10/31/17 07:12 PM
USA
USA
Thanks. I was told by a well known hemi builder that this cam was WAY to big for the application. It did not seem to big to me but I am new to these engines.
Re: How will this cam idle? [Re: hudsonhornet7x] #2396873
11/01/17 07:39 PM
11/01/17 07:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: How will this cam idle? [Re: hudsonhornet7x] #2396980
11/01/17 09:49 PM
11/01/17 09:49 PM
USA
USA
Thanks for sharing, that sounds great!!
