Re: OE 1969 340 X heads vs aftermarket aluminum heads.
[Re: Rhinodart]
#2386994
10/13/17 06:16 PM
10/13/17 06:16 PM
dogdays
They're not steel, they're cast iron. The two terms are not interchangeable.
Nearly every new car on the market, maybe all of them, use aluminum heads. So to say they have no business on a street car is an opinion whose time has passed.
Specifically, your old X heads will flow something like 220cfm, max. They have a lousy combustion chamber. Rebuilding them to stock specs will cost more than $600, if I remember the last numbers bandied about here. Fully port them and you might reach 270cfm, max. One plus is you already have them.
A brand new Edelbrock head flows 247 max out of the box. Run a good CNC program or have an experienced porter do them and you're tickling 300cfm, max.
So with the Edelbrock aluminum head you are looking at a possible 60hp gain. Other advantages to the aluminum head: all the aftermarket aluminum heads have improved combustion chamber shapes which make the engine less octane-sensitive. Plus, you can add about a full point of compression with the aluminum heads, going to 10.5:1 or a little higher. This is additional power and efficiency. Plus with the more modern chamber design you can run less ignition lead (timing) and reduce the amount of negative work done on the piston. Plus, the aluminum heads weigh about 1/3 as much as the iron heads do, and the weight is saved from high on the front end of the car, where it does a lot of good. IIRC LA heads actually weigh more than B/RB heads.
There are the Edelbrocks, the Speedmaster/Procomps, Hughes' varieties, and the Sidewinder from Todd Marsh (Sasquatch on this board.) There are also the ProMaxx heads which are the same as the Sidewinders but are priced higher. There are also the Enginequest iron replacement heads which work very well and have a Magnum combustion chamber that is pretty successful. I believe there may be another iron head out there, too. Problem with the EQs is they are pretty expensive.
Good Luck!
R.
[Re: Cab_Burge]
#2387024
10/13/17 07:44 PM
10/13/17 07:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The new aluminum heads will flow more air Since no specific head was specified you can't say this. Plenty of aluminum heads out there that are crap and need rework out of the box, I suggest you google speedmaster heads. So when some say " the cost pf rebuilding an iron head" as an excuse tend to not add the cost of making sure you aftermarket aluminum head is ready to run. Nor is there any actually data supporting the aluminum allows higher compression claims. Combustion chamber design is the major factor in allowing higher compression, iron hemi heads can run just as high a compression as aluminum ones. Assuming your new heads have efficient combustion chambers you can consider increasing your compression ratio.
[Re: Barrelhouse]
#2387026
10/13/17 07:48 PM
10/13/17 07:48 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
Funny, on my 340 F/Sock engine, NHRA rates the iron head at 300 hp and the Eddy aluminum head at 297 hp. They are lighter but we have to add the weight back somewhere. If just doing a valve job, keep them, unless you got money to burn. Downside, no hardened seat for the ex valve in stock form. Compare both on paper, list all the good-bad points and cost for each. You'll see which way is best for YOU.
[Re: Supercuda]
#2387075
10/13/17 09:42 PM
10/13/17 09:42 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
The new aluminum heads will flow more air Since no specific head was specified you can't say this. Plenty of aluminum heads out there that are crap and need rework out of the box, I suggest you google speedmaster heads. So when some say " the cost pf rebuilding an iron head" as an excuse tend to not add the cost of making sure you aftermarket aluminum head is ready to run. Nor is there any actually data supporting the aluminum allows higher compression claims. Combustion chamber design is the major factor in allowing higher compression, iron hemi heads can run just as high a compression as aluminum ones. Assuming your new heads have efficient combustion chambers you can consider increasing your compression ratio. I have to disagree on the higher comp. Aluminum heads will disapate the heat faster which will allow you to run higher comp and not have detonation. Its a know fact thats also why most say you can get away with about 1 point higher comp with aluminum heads and not because of the combustion chamber design which I do agree the newer aluminum heads do have better combustion chamber design's. Ron
[Re: dogdays]
#2387076
10/13/17 09:42 PM
10/13/17 09:42 PM
Posts: 43,517 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Good Luck!
R.
Steel is a generic term, lighten up Francis...
JB Rhinehart, Realist
A-Body's RULE!
[Re: 383man]
#2387086
10/13/17 10:04 PM
10/13/17 10:04 PM
Supercuda
About to go away
About to go away
up yours
The new aluminum heads will flow more air Since no specific head was specified you can't say this. Plenty of aluminum heads out there that are crap and need rework out of the box, I suggest you google speedmaster heads. So when some say " the cost pf rebuilding an iron head" as an excuse tend to not add the cost of making sure you aftermarket aluminum head is ready to run. Nor is there any actually data supporting the aluminum allows higher compression claims. Combustion chamber design is the major factor in allowing higher compression, iron hemi heads can run just as high a compression as aluminum ones. Assuming your new heads have efficient combustion chambers you can consider increasing your compression ratio. I have to disagree on the higher comp. Aluminum heads will disapate the heat faster which will allow you to run higher comp and not have detonation. Its a know fact thats also why most say you can get away with about 1 point higher comp with aluminum heads and not because of the combustion chamber design which I do agree the newer aluminum heads do have better combustion chamber design's. Ron There is zero data to support your conclusion and "it's a known fact" doesn't count unless you can show the data. Closest I have seen is that car craft did a iron to aluminum comparison with two otherwise identical aftermarket heads. They tested the myth that the ability of aluminum to wick away heat would affect power output. Zero difference in power output. They also detected zero issues with detonation, 10.88:1 comp ratio, using pump gas and speculated that maybe the compression ratio needed to get higher to see anything. But at that level there was NO difference in power or detonation between the two materials. http://www.hotrod.com/articles/ccrp-0602-iron-versus-aluminum-cylinder-heads-test/
[Re: Supercuda]
#2387100
10/13/17 10:28 PM
10/13/17 10:28 PM
383man
Balt. Md
The new aluminum heads will flow more air Since no specific head was specified you can't say this. Plenty of aluminum heads out there that are crap and need rework out of the box, I suggest you google speedmaster heads. So when some say " the cost pf rebuilding an iron head" as an excuse tend to not add the cost of making sure you aftermarket aluminum head is ready to run. Nor is there any actually data supporting the aluminum allows higher compression claims. Combustion chamber design is the major factor in allowing higher compression, iron hemi heads can run just as high a compression as aluminum ones. Assuming your new heads have efficient combustion chambers you can consider increasing your compression ratio. I have to disagree on the higher comp. Aluminum heads will disapate the heat faster which will allow you to run higher comp and not have detonation. Its a know fact thats also why most say you can get away with about 1 point higher comp with aluminum heads and not because of the combustion chamber design which I do agree the newer aluminum heads do have better combustion chamber design's. Ron There is zero data to support your conclusion and "it's a known fact" doesn't count unless you can show the data. Closest I have seen is that car craft did a iron to aluminum comparison with two otherwise identical aftermarket heads. They tested the myth that the ability of aluminum to wick away heat would affect power output. Zero difference in power output. They also detected zero issues with detonation, 10.88:1 comp ratio, using pump gas and speculated that maybe the compression ratio needed to get higher to see anything. But at that level there was NO difference in power or detonation between the two materials. http://www.hotrod.com/articles/ccrp-0602-iron-versus-aluminum-cylinder-heads-test/ Well if thats true then you did show fact to back most of your theory and I will admit that. They did say that they did not prove about the fact if aluminum heads will support more comp because they did not run high enough comp as they did prove at 10.88 comp both seem to be about the same. What seems funny to me is most I talk to with aluminum heads say they usually like less timing but maybe they are comparing a new aluminum head with a modern design chamber to an old iron head. And as far as I know its a proven fact that aluminum will disapate heat faster then cast iron but maybe not enough to make a difference. I dont know if anyone has ever tested the same thing to back the saying about aluminum being able to run higher comp but I seam to hear so many say it and many eng shops seem to believe its true also. But after seeing that test it may be that since most aluminum heads out there today have much better combustion chamber design then the older iron heads from the 60's and 70's and maybe thats why many believe the aluminum work better and can get away with higher comp. And most today including me build their engines with good quench and swirl flow chamber aluminum heads and can get by on higher comp. And of course I can run higher comp on pump gas with my closed chamber aluminum heads and good quench when compared to running an open chamber 906 head. That is an interesting article and thanks for posting it as I have never seen that article. Ron
[Re: 383man]
#2387117
10/13/17 11:04 PM
10/13/17 11:04 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
[Re: cudaman1969]
#2387172
10/14/17 01:39 AM
10/14/17 01:39 AM
383man
Balt. Md
Ron, I'll add one thing. Kenny L at Indy Head told me on my 499 engine with their heads that he built while at Mc Candless, I needed to be at 200 degrees on the starting line because if not the engine would be down on power. The heads lost heat to fast and had to build the heat. When first running the car I went 5.50s with engine getting over 200* and hotter. I dropped the temp (at the line with better shrouds and fans) to 160*, not wanting that much temp,and ran 5.70s. Ran it back hot again after he told me this and ran 5.50s. I would say he knows what he's talking about. I take it they were aluminum heads ? Ron
[Re: 383man]
#2387205
10/14/17 03:38 AM
10/14/17 03:38 AM
cudaman1969
fredericksburg,va
Ron, I'll add one thing. Kenny L at Indy Head told me on my 499 engine with their heads that he built while at Mc Candless, I needed to be at 200 degrees on the starting line because if not the engine would be down on power. The heads lost heat to fast and had to build the heat. When first running the car I went 5.50s with engine getting over 200* and hotter. I dropped the temp (at the line with better shrouds and fans) to 160*, not wanting that much temp,and ran 5.70s. Ran it back hot again after he told me this and ran 5.50s. I would say he knows what he's talking about. I take it they were aluminum heads ? Ron Yes, If I remember right, been over 18 years, 440-1 low deck, in 95 whatever was the best for a stock block, around 830 hp
[Re: Rhinodart]
#2387209
10/14/17 04:00 AM
10/14/17 04:00 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
[/quote] Steel is a generic term, lighten up Francis... [/quote] "Anyuos homoos wanna call me Francis????????????? I-ke-ya!!! Hey man, just the having no water in the exhaust manifold bolts was enough to convince me to go with an aluminum head. Iron heads are always cracking and crap. Aluminum is just better, period.
[Re: cudaman1969]
#2387210
10/14/17 04:04 AM
10/14/17 04:04 AM
Dave Hall
Cotati, CA
Funny, on my 340 F/Sock engine, NHRA rates the iron head at 300 hp and the Eddy aluminum head at 297 hp. They are lighter but we have to add the weight back somewhere. If just doing a valve job, keep them, unless you got money to burn. Downside, no hardened seat for the ex valve in stock form. Compare both on paper, list all the good-bad points and cost for each. You'll see which way is best for YOU. So the lower hp engine will actually run farther under the index than the iron head? Makes sense.
[Re: Dave Hall]
#2387260
10/14/17 11:15 AM
10/14/17 11:15 AM
cudaman1969
fredericksburg,va
Funny, on my 340 F/Sock engine, NHRA rates the iron head at 300 hp and the Eddy aluminum head at 297 hp. They are lighter but we have to add the weight back somewhere. If just doing a valve job, keep them, unless you got money to burn. Downside, no hardened seat for the ex valve in stock form. Compare both on paper, list all the good-bad points and cost for each. You'll see which way is best for YOU. So the lower hp engine will actually run farther under the index than the iron head? Makes sense. Car can be 30 pounds lighter, hard to say if faster. Depends on how they "prep" the heads. Mr Hatch has a 71 Duster with E heads that went 9.99 in D weight, that's flying for a stock car-engine.
[Re: cudaman1969]
#2387281
10/14/17 11:47 AM
10/14/17 11:47 AM
383man
Balt. Md
Ron, I'll add one thing. Kenny L at Indy Head told me on my 499 engine with their heads that he built while at Mc Candless, I needed to be at 200 degrees on the starting line because if not the engine would be down on power. The heads lost heat to fast and had to build the heat. When first running the car I went 5.50s with engine getting over 200* and hotter. I dropped the temp (at the line with better shrouds and fans) to 160*, not wanting that much temp,and ran 5.70s. Ran it back hot again after he told me this and ran 5.50s. I would say he knows what he's talking about. I take it they were aluminum heads ? Ron Yes, If I remember right, been over 18 years, 440-1 low deck, in 95 whatever was the best for a stock block, around 830 hp Thanks , Ron
