Torque shaft adapter B-Body question #2386764
10/13/17 11:32 AM
10/13/17 11:32 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Have headers on my motor and have TTi's shifter adapter to go over the headers. The instructions says to modify the rod for the adapter to go to the tranny. The question is: Is there a different length rod for the tranny? Reason is, it seems mine might be too short to reach the transmission selector arm (on transmission). Tried several times to edit and post a picture but no good
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2386803
10/13/17 12:23 PM
10/13/17 12:23 PM
pics need to be in the right "place" on the computer for you to load em (I don't know how to explain it). Likely you would need to weld an extension on the rod so it will reach & as you know make sure the angles/leverage is correct.
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387222
10/14/17 05:05 AM
10/14/17 05:05 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
I just don't see why you should have to "weld an extension" to the rod. I know many guys has this and have never heard of doing this. I'll have to go look at it again this weekend frown
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387223
10/14/17 05:11 AM
10/14/17 05:11 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
If I am reading this correctly, the rod does not hook to the trans. The adapter does. Maybe you should give TTI a call, they were cool guys at the Van Nuys show. May be worth a try? I didn't know they made an adapter. I would have used it! I had to buy a $350 dollar cable shifter.
Re: Torque shaft adapter B-Body question [Re: Dave Hall] #2387252
10/14/17 10:39 AM
10/14/17 10:39 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
The rod goes from the adapter to the tranny. Tried to post a picture but after playing with the size several times, to make it fit in my post, I gave up. Yes, the instructions say to modify the rod. Basically, bend it downward to reach where the rod connects to the tranny since the adapter goes up and over the header. Doesn't say to cut and weld in a extension. I didn't and couldn't give TTi a call to see what they say but guess will have to on Monday. I'll be going to my friend's shop and we are going to look at it again. Was hoping someone on here had done this and did the "modification".
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387400
10/14/17 04:39 PM
10/14/17 04:39 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Like I said, I definitely would have used it as well. I didn't even know they had such a thing. I will say that their headers fit and look and perform well but are a royal PITA for working on the car.
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387527
10/14/17 11:07 PM
10/14/17 11:07 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sorry, no help on original issue.
I open my pictures in paint, then reduce the size by 50% 3 times.
Close and save changes.
They load up just fine. shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Torque shaft adapter B-Body question [Re: bboogieart] #2387590
10/15/17 02:45 AM
10/15/17 02:45 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
I think I figured the picture part out
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387598
10/15/17 03:19 AM
10/15/17 03:19 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
That looks to be pic from the factory service manual?
Re: Torque shaft adapter B-Body question [Re: Dave Hall] #2387735
10/15/17 01:56 PM
10/15/17 01:56 PM
None
71rm23 Offline OP
71rm23  Offline OP
None
Yes, showing the rod that needs to be modified for the use of the torque shaft adapter that goes over the headers.
Re: Torque shaft adapter B-Body question [Re: 71rm23] #2387949
10/16/17 12:11 AM
10/16/17 12:11 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That rod connects directly with the factory torque shaft and is suppose to result in a straight pull-push on the trans lever.
If the "adapter" raises the torque shaft connecting point, the circled rod will need to have a bend or a curve added so it will maintain the straight pull-push on the trans lever. Depending on how much the torque shaft is raised, and how much adjustment the circled rod has, you may also need to add length to the circled rods length to be able for the trans lever to be able to reach all the trans gears, particularly park or low which are at the extremes of the trans lever movement.
If you were to look sideways at the circled rod as it would be mounted in the car, it will need to have an upward bend added near the torque shaft end (closer to the torque shaft and more radical then the current bend), so that it will connect to the raised torque shaft, and still be in a straight line (height wise) to the trans lever.
If the rod is bent incorrect, it will probably not allow the trans lever to go into park (farthest forward position), or will want to keep pulling it out of park.
If the newly bent rod is too short, you probably won't be able to shift down into low (the farthest rearward position) and if its way too short, you may not be able to shift into 2nd either. Gene
