Manual master cylinder bore diameter #238653
02/28/09 05:37 AM
02/28/09 05:37 AM
Finland
mopster Offline OP
mopster  Offline OP
Finland
I´m looking for Strange style alum master cylinder for my Duster, but I´m not sure what bore diameter I need. I´m converting from power brakes to manual. It´s orginally a manual brake car and pedal ratio is for manual brakes. I have drums in rear and ´73-76 a-body discs in front. The car weights about 3300lbs with driver.
Re: Manual master cylinder bore diameter [Re: mopster] #238654
02/28/09 06:43 AM
02/28/09 06:43 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Not sure if this will apply or not. I did a SSBC swap (put discs on the front),,and had to change the MC,,,
I have manual brakes.
I went with a "smaller" bore MC,,,,and used a 7/8" bore (the one supplied with the SSBC swap was too big)
It ended up being a 73 Dart MC for MY application.
Note; mine is not aluminum...
Not sure if this helps you or not.
Doug
Post deleted by Defbob [Re: 69CHARGERMD] #238655
02/28/09 10:12 AM
02/28/09 10:12 AM
Re: Manual master cylinder bore diameter #238656
02/28/09 01:40 PM
02/28/09 01:40 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
1 1/8, change the pedal ratio to 6.5 or 7 to 1 and forget about it. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Manual master cylinder bore diameter [Re: mopster] #238657
02/28/09 02:10 PM
02/28/09 02:10 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
An 1 1/32" bore master works nicely for that application.
