What year 8-3/4 rear fits a 73 Satellite? #2386507
10/12/17 09:10 PM
10/12/17 09:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
A kid I know is looking for a rear for his B-Body, do only 71-74 rears fit? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2386512
10/12/17 09:21 PM
10/12/17 09:21 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
73-4 b is a direct fit
71-2 has different center pin hole size on the perch and other parts have to be changed to make work.
tech archives has the widths
http://www.moparts.org/Tech/Archive/axle/17.html
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2386615
10/13/17 12:08 AM
10/13/17 12:08 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
oh I forgot one another option
the hot set up is to get a e body rear
and use the relocation hanger set up from doctor diff
so you have better clearance for wider tires.
I just don't know if the center pin hole issue is the same or not
as I have not done it myself.
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: flypaper] #2386642
10/13/17 12:59 AM
10/13/17 12:59 AM
Rhinotruck
Rhinotruck
Interesting. I guess I need to find out if the rear housing I have is from a B or E. work
A-Body's RULE!
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2386689
10/13/17 06:33 AM
10/13/17 06:33 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Should be able to work around the center pin size if you use mating shock mount plates.
I have a 68 Chrysler 300 housing and axles that should be really close.
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2386768
10/13/17 11:42 AM
10/13/17 11:42 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
New center pins are cheap.
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: sthemi] #2386934
10/13/17 04:48 PM
10/13/17 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The hole in the '73-'74 perch is larger...needs a bushing or custom made center bolt to fit properly on the earlier springs.
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2386944
10/13/17 05:01 PM
10/13/17 05:01 PM
P
Paul_Fancsali Offline
P
I took a 71 B road runner rear end and stuck it right into my 73 using the 71 parts no issue at all
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2387138
10/13/17 11:48 PM
10/13/17 11:48 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
ideally you want to get rid of the rubber isolators around the springs on the 73+ b bodies and go with the more ridged 71-72 design. ebody axles will fit with 71-72 springs and spring relocation kit.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2387153
10/14/17 12:28 AM
10/14/17 12:28 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe all C body 8 3/4 will fit under a 71-73 B body as well. I think they are the same width. Gene
Re: What year 8-3/4 rear fits a 73 Satellite? [Re: Rhinodart] #2387247
10/14/17 10:17 AM
10/14/17 10:17 AM
sw michigan
TB3CUDA Offline
TB3CUDA  Offline
sw michigan
have one out of a 73 satellite comes with sway bar located in sw michigan
