Re: control A999 converter lockup
[Re: BcudaChris]
#2385212
10/10/17 06:36 PM
10/10/17 06:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Lock up is not electrically controlled.
There are versions with an electric unlock solenoid that was used in certain HD applications to prematurely unlock the TC, but if you do not use it then it will function like a normal LU A999. Have you tried just driving it?
I would wire in a WOT switch and let that toggle the unlock if you want to keep it functional.
[Re: BcudaChris]
#2385265
10/10/17 08:38 PM
10/10/17 08:38 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Lock and unlock are controlled on A999's with the electric input. A pressure switch connected to the governor test port will lock the converter when a certain road speed is achieved (10 psi governor pressure is about 10 mph). An adjustable vacuum switch in series with the lockup switch will unlock it at heavy throttle.
[Re: Magnumguy]
#2385639
10/11/17 02:30 PM
10/11/17 02:30 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
I thought on A999's that the lockup was actuated by line pressure/etc. You can buy a spring (at one time anyway) to control the speed of lockup. Around 86 or 87 the lockup function gained electronic control. I have an 85 A999 and it is non electronic.
[Re: 383man]
#2386065
10/12/17 01:47 AM
10/12/17 01:47 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Not the 999's out of my 94 and 86 jeeps, all manual lockup.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 383man]
#2386437
10/12/17 07:03 PM
10/12/17 07:03 PM
John_Kunkel
Rio Linda, CA
A999 was introduced in '74, lockup in '78 and electric lockup in the mid-eighties.
