Power Brake Booster for 1970 GTX
#2383838
10/08/17 12:49 PM
10/08/17 12:49 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hi. I started out driving and my power brakes worked great, but sometimes the pedal gets hard after I drive it for a while. I can drive it for ten miles or more and it works perfectly. Is there any way to ID to power brake boosters if I need to get one and where is the best place to get one? Also, does anyone know where I can get a check valve? The one I have has two fittings. One fitting to a vacuum gauge. And the gauge says I have thirteen to fourteen lbs. of vacuum. Thanks. I have a 1970 GTX btw.
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Power Brake Booster for 1970 GTX
[Re: 6bblgt]
#2384020
10/08/17 06:12 PM
10/08/17 06:12 PM
Posts: 6,221 JERSEY
RJS
JERSEY
Drum brake w/power use the Midland Ross booster. Vacuum is measured in inches not llbs..
Disc's had the Bendix unit Ron
[Re: GTXKARL]
#2384311
10/09/17 09:55 AM
10/09/17 09:55 AM
Posts: 601 Mass
charge70
Mass
Some 70 drum brake cars had bendix boosters.It is not the same as the disc brake one,sorry I don't have a pic of one right now.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
