Re: Dodge 4.7 --towing?
[Re: 493_DART]
#2384545
10/09/17 05:15 PM
10/09/17 05:15 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
318 will blow away a 4.7 in pulling. Empty they run about the same except you got to turn a few more RPM but when they are loaded the 4.7 got no nuts. I have had many of both trucks and towed with most every one of them. The 4.7 engine issues far outweight the 5.2 trans issues.
[Re: 493_DART]
#2384550
10/09/17 05:21 PM
10/09/17 05:21 PM
HotRodDave
Kalispell Mt.
My current 2011 ram 5.7 is the best towing vehicle I have ever driven including souped up 12V stinkys and a couple 24V stinkys. It needs a few more RPM but so what, 300,000 and the motor looks new inside except a worn out cam lobe and that is still cheaper than diesel fuel injection pump, or decent injectors or many other expensive diesel issues.
My 2011 Hemi ram gets the same MPG as my 07 4.7 dakota (actually better when towing). The 4.7 V8 and near twin 3.7 V6 are the reason the dakota (as a new truck) no longer exists. Word spread about what a pile of garbage they were and sales went through the floor, that and the butt ugly styling.
[Re: 493_DART]
#2384894
10/10/17 01:59 AM
10/10/17 01:59 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Does the 5.7 hemi have any common issues? Some have the infamous "Hemi Tick" where it has what sounds like a sticky lifter. I have 294,000 on my 2007 and it had the tick for awhile but it stopped about 50,000 miles ago. The 4.7 is a 287 cubic inch engine. The quad cab trucks are 5000 lbs in 2wd form, add 4wd and you are at 5200. The EFI helps but it is still cubically challenged.
[Re: 493_DART]
#2384908
10/10/17 02:32 AM
10/10/17 02:32 AM
Posts: 5,998 Salem
Grizzly
Moparts Proctologist
Salem
Its a nightmare finding a decent truck within my budget.
Drove a 04 Hemi ram today...rusted to hell with 158k on it.. Well, what's your budget? Know where there's an '07 Hemi Sport with 9,800 miles on it. Obviously, no rust and not abused. It's expensive, but you get what you pay for.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2385158
10/10/17 04:54 PM
10/10/17 04:54 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
Drove a 04 Hemi ram today...rusted to hell with 158k on it.. Well, what's your budget? Know where there's an '07 Hemi Sport with 9,800 miles on it. Obviously, no rust and not abused. It's expensive, but you get what you pay for. 6K
[Re: 493_DART]
#2385341
10/10/17 10:59 PM
10/10/17 10:59 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Does the 5.7 hemi have any common issues? Some of them have had issues dropping valve seats. Not overly common, but still happens.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: 493_DART]
#2385738
10/11/17 05:09 PM
10/11/17 05:09 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
just bought an 04 quad cab / 4wd 5.7 for $4500 ! Good move! What gear? They run ok with 3:55's, but 3:92's really help with towing. Congrats on the purchase.
[Re: 493_DART]
#2385953
10/11/17 10:57 PM
10/11/17 10:57 PM
493_DART
Worst Weather USA
not sure on the gear--doesnt feel low like a 392 , its got the Tow Mode button
I dig the truck--its got the usual rust over the wheels and rockers..but runs/ drives perfect . Loaded with leather int.
SO--how hard are the plugs to change ? The drivers side looks fun......
[Re: 493_DART]
#2386326
10/12/17 03:13 PM
10/12/17 03:13 PM
HotRodDave
Kalispell Mt.
There is one down the street from me at a lot for $3000 that matches that description, I am trying to figure out how to get the cash to buy it, don't know why.
The plugs are not as hard as they look once your in there doing them. 2.5 hours is average book time and I had no problem doing my first set in 1.5 hours, got em down to about an hour now useing air ratchets and such for speeding up turning all the little bolts. I can't remember what year they got rid of the stupid plug wires going under the intake, my tip on those is to pull the wires all out and just loop em all back to where one coil fires both plugs on one cylinder, they run a hair smoother firing both plugs on power stroke and the next plug change is waaay easier. Don't forget to zip tie em out of the way of moving parts like steering shaft and hot exhaust parts. You can also buy the short jacobs wires to make it clean and neat. An even cleaner way to do it is to buy a set of the later coils and matching valve covers and get adapters for the primary plug-in.
