Telescoping Antenna mast nut #2384034
10/08/17 06:37 PM
10/08/17 06:37 PM
Ashland City, Tennessee
Aar1064 Offline OP
Aar1064  Offline OP
Does anyone here know of a source for this. I’ve removed mine to be re-plated but it’s pretty marked up from inappropriate tool use. It’s chrome plated brass and presses onto bottom of antenna mass. I’d like to find a new one or one that’s not so marked up and can be re-plated.
Appreciate it.
Re: Telescoping Antenna mast nut [Re: Aar1064] #2384621
10/09/17 06:47 PM
10/09/17 06:47 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
that should come with the antenna mast I believe
Re: Telescoping Antenna mast nut [Re: AARCONV] #2385050
10/10/17 12:52 PM
10/10/17 12:52 PM
Aar1064 Offline OP
Aar1064  Offline OP
Yes they do but I'm trying to restore my original antenna. Repops that I've purchased are a little different. The original piece is pressed onto the mastand repops are somewhat pressed but came loose. That's why I've decided to restore original.
