6.4 Swap Wiring Issues #2384005
10/08/17 05:37 PM
10/08/17 05:37 PM
NOLA
daryld Offline OP
daryld  Offline OP
NOLA
Hey guys
My factory wiring harness is not sending power simultaneously to the ignition position and crank position. It will only send power to one or the other and the Mopar Performance wiring harness system for my 6.4 requires both hot at the same time. Has anyone else had this issue during their swaps? If so, how did you resolve this?
Apparently the previous owner cut some of the factory wires when installing the painless wiring harness during the restoration. Not sure if those missing wires are now causing me issues. I do not want to do anything that might damage or harm my 6.4 computer.
Thank you
Daryl
Re: 6.4 Swap Wiring Issues [Re: daryld] #2384338
10/09/17 11:09 AM
10/09/17 11:09 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
The Fast and Loud guys had the same issue when they did that Challenger they swapped the 6.4 in to the70( I think it was a70) 340 shaker car.
how they fixed it I don't know.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 6.4 Swap Wiring Issues [Re: daryld] #2384771
10/09/17 10:38 PM
10/09/17 10:38 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By daryld
Hey guys
That's how it's designed.
If you need power in both crank and run then tie the two lines together use a diode to prevent back feed.
It's just been covered in the Q&A section for Fitech.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2381202
Don't be the exception.
