consistancy items #238398
02/27/09 09:38 PM
02/27/09 09:38 PM
W.Va
fowl play Offline OP
W.Va
what items are the most important to the consistancy of your drag car? What should i workon this year to improve this? this a race only Dart 414 smallblock 727 w/brake ladder bar with coilovers . shock settings, rpm, temp,and what else?
Re: consistancy items [Re: fowl play] #238399
02/27/09 09:40 PM
02/27/09 09:40 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
If your class allows it, get an air or electric shifter and a two step to launch the car.
Re: consistancy items [Re: fowl play] #238400
02/27/09 09:49 PM
02/27/09 09:49 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Temp is a biggie. But so is fuel delivery. Driver Routine is another way to stay consistent; Do the same thing at the same time everytime. Same length burnout everytime etc.
Yeah, it's got a smallblock.
Re: consistancy items [Re: 340B5] #238401
02/27/09 09:56 PM
02/27/09 09:56 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Great BIG tires
Yabba dabba doooooooo ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: consistancy items [Re: bigdad] #238402
02/27/09 09:58 PM
02/27/09 09:58 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Great BIG tires
Someone got some new ones Huh. Jim
Re: consistancy items [Re: fowl play] #238403
02/27/09 10:24 PM
02/27/09 10:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Shock setting will change from track to track and
some what at the same track but mostly once you have
the sweet setting they tend to stay the same. Ladder
bars are violent on the launch so have GOOD adjustable
shocks. Most of the other stuff the guys have said
but it ALL starts at the tire and if its a bracket
car get big tires(you dont care if its a tad slower
due to the size). Also a little fat on the carb is
better. The rest is up to the driver to do ALL the
things the same way EVERY time temp, burnout, stageing
and the tree
Re: consistancy items [Re: fowl play] #238404
02/28/09 10:51 AM
02/28/09 10:51 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
If you have a Tach with a nob to ajust your shift light, I would recomend you get one that takes the pill. I found that my light was changing from vibration , it would read different comeing down the return road then when I set it befor the run.
If you are footbraking a brake presure gauge helps stage the same.
A playback tach will help you get every thing the same every run show you the run not what you thaught was the run
Good raceing
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: consistancy items [Re: wildcargo] #238405
02/28/09 12:38 PM
02/28/09 12:38 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I am still learning,,,and follow ALL of the above advice, very good info.
I have found using a WEATHER STATION... is a big plus.
I thought my car was "changing" from day to day,,,or track to track,,,when actually the weather was playing a huge role,,,and when you crunch the numbers into the weather station,,,,and take out the variables,,the car was about the SAME....as far as what it was doing or wanted...
I learned alot about it this past summer,,after using the weather station,,and charting every run....
Mid way thru the season,,,i could punch in the weather parameters,,,check my log book,,and know what the car was going to do that day,,,,or as the weather changed...
I was able to go a few more rounds than usual, which was cool for me.
What i need to do,,,is figure out what "settings" the car wants for various weather conditions,,,,so i know what "jet" to throw at it,,,
I didnt TOUCH any jet settings all year,,,and watched the car pick up and slow down based on the weather alone....
this is just my observation,,,,Mike (Mr P body),,is pretty savvy on this stuff as well...
before i used the weather station,,,,i was running around changing all kinds of stuff,,,(jets/timing/etc),,,but not knowing if i was going in the right direction or not,,,and then started thinking something was "wrong" with the car,,,,especially when it slowed down....come to find out,,,it was the weather changing the car...not the "car itself"
again, i was amazed at how much the weather condtions affects stuff....
Doug
Re: consistancy items [Re: 69CHARGERMD] #238406
03/03/09 11:28 PM
03/03/09 11:28 PM
PA
moparacer Offline
moparacer  Offline
PA
Just hold .05 and drive the stripe....As long as you cut the best light you will never go wrong.....
Consistency items for me are engine temp, trans temp, tire pressures, tire temperatures and shift points.
I dont like a light, always use the needle.
I found that if I write every little detail down about weather, track temp, run information etc....I end up over thinking a dial in prediction a get it wrong. To many variables from one week to the next to take any prediction software as the gospel.
That gut feeling, first instinct dial in for me is usually the best guess....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: consistancy items [Re: moparacer] #238407
03/04/09 08:56 AM
03/04/09 08:56 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
stage as shallow as possible each time .this effects et.
have to learn top end racing lift to much other car goes around you .
dial too far under so you don't brake out you give up to much.
dial up sandbag might brake out .
just go out and practice
what you will learn my your time slip racing someone is the MOV where reactions have come into play
somedays its just your lucky day enjoy it
good luck
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
