Power Brake Booster for 1970 GTX #2383838
10/08/17 12:49 PM
10/08/17 12:49 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I started out driving and my power brakes worked great, but sometimes the pedal gets hard after I drive it for a while. I can drive it for ten miles or more and it works perfectly. Is there any way to ID to power brake boosters if I need to get one and where is the best place to get one? Also, does anyone know where I can get a check valve? The one I have has two fittings. One fitting to a vacuum gauge. And the gauge says I have thirteen to fourteen lbs. of vacuum. Thanks. I have a 1970 GTX btw.
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Power Brake Booster for 1970 GTX [Re: GTXKARL] #2383943
10/08/17 04:11 PM
10/08/17 04:11 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
1970 b-body with disc brakes should have a dual-diaphragm Bendix power brake booster
if you need to replace/repair - your best bet would be having yours rebuilt by: BOOSTER DEWEY up
Re: Power Brake Booster for 1970 GTX [Re: 6bblgt] #2384020
10/08/17 06:12 PM
10/08/17 06:12 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Drum brake w/power use the Midland Ross booster. Vacuum is measured in inches not llbs..
Disc's had the Bendix unit
Ron
Re: Power Brake Booster for 1970 GTX [Re: RJS] #2384119
10/08/17 09:41 PM
10/08/17 09:41 PM
IN
ahy Offline
ahy  Offline
IN
Disc or drum matters a lot. For discs, a repop 8" dual diaphram unit is available from Dr Diff.
Are your brakes getting weak after hard use... or just with time running? 10 inches mercury vacuum at idle is marginal for vacuum assist power brakes. Is vacuum getting even weaker when hot maybe? Suggest you check.
Re: Power Brake Booster for 1970 GTX [Re: GTXKARL] #2384311
10/09/17 09:55 AM
10/09/17 09:55 AM
Mass
charge70 Offline
charge70  Offline
Mass
Some 70 drum brake cars had bendix boosters.It is not the same as the disc brake one,sorry I don't have a pic of one right now.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
