Re: trying to pin point a front end clunck
[Re: John_Kunkel]
#2382264
10/05/17 02:48 AM
10/05/17 02:48 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
i also replace the original torsion bars with the next heavier (GTX) ones. Did you grease the hex ends of the T-bars?
[Re: Kern Dog]
#2382312
10/05/17 10:05 AM
10/05/17 10:05 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i also replace the original torsion bars with the next heavier (GTX) ones. Did you grease the hex ends of the T-bars? YIKES! i will, i will!!i just am not looking forward to sliding them back out! Andrewh - the clunk is very definitely a suspension issue. just not looking forward to the task!
[Re: mikemee1331]
#2383083
10/06/17 07:07 PM
10/06/17 07:07 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
i raised up the front via the torsion bars but now i have a clunk i didn't have when it was lower. This changes the relationship of all the alignment components. Lots of good advice above. Look for signs of wear. Should be easy with all new parts. Tighten everything up, and get the new set-up properly aligned.
I have mechanical Aptitude. I can screw up anything.
[Re: dvw]
#2383836
10/08/17 12:47 PM
10/08/17 12:47 PM
mikemee1331
bethlehem pa
Did you rock it as I suggested? With over 30 years as a dealer tech specializing in suspension I had many difficult noises to locate. The method mentioned found 95% of them. Doug i will be doing this first! yes, tons of good advise here and i really appreciate every bit of it! i will update this when i get a chance to work on her. before i do anything i have to get the ride height, back and front, where i want it. the back is a little too high now that i put the 'extended reach' KYB's on there. i was hoping they would settle down some but no dice. i'll put those where they belong, on my sons Ram pickup and just go with the regular KYB's. that should work as i have the springs where i want them. then move to the front. thanks again all!
