Ladder bar suspension #2383212
10/06/17 11:41 PM
10/06/17 11:41 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I have been thinking of adding more tire room on my Savoy and I thought about taking the easy route and going with a ladder bar suspension. I was going to re-locate the springs into the frame rails but that might conflict with my plans for 3" exhaust out to the bumper. Should I just move the springs or go with the ladder bars. I just want more tire clearance and if I could make the suspension just a little better in the process I would be stupid not to make an improvement shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Ladder bar suspension [Re: fourgearsavoy] #2383224
10/06/17 11:57 PM
10/06/17 11:57 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What type of rear suspension do you have now
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Ladder bar suspension [Re: 67mprfan] #2383228
10/07/17 12:11 AM
10/07/17 12:11 AM
Rittman Ohio
Rittman Ohio
Just SS leafs 3800# with Rancho 9 way RS shocks.
64 Plymouth Savoy
Dana 60
Re: Ladder bar suspension [Re: fourgearsavoy] #2383236
10/07/17 12:29 AM
10/07/17 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want more tire and want to hook up
better then put the bars on but if you really
want a better suspension then go with a 4 link
but the ladder works great also
wave
Re: Ladder bar suspension [Re: fourgearsavoy] #2383257
10/07/17 01:13 AM
10/07/17 01:13 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I have 3" exhaust to the bumper on my '72 Dart with relocated springs, and there's lots of room including glasspacks for resonators under the trunk floor. Of course the fuel tank isn't under there any more smile
Re: Ladder bar suspension [Re: fourgearsavoy] #2383263
10/07/17 01:31 AM
10/07/17 01:31 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Ladder bars and coil over shocks would drop a significant amount of weight off the back also.
[image][/image]
Re: Ladder bar suspension [Re: fourgearsavoy] #2383276
10/07/17 02:26 AM
10/07/17 02:26 AM
Cab_Burge Online work
Cab_Burge  Online Work
My Duster was a real hoot on the street and strip and it was real easy to hook up with 36 inch ladder bars and double adjsutabel strange Engr. 15 inch long coil overs with a diagonal link up
I had three inch exhaust all the way to the rear bumper but do to the coil overs the pipes went under the rear end and around the rear tires do to having fender well headers on the car, the 14x7x3 inch inlets and outlets old school Magnaflow mufflers where mounted behind the rear end and between the rear 1/4 panels and rear sub frames up I ran the stock Duster gas tank also for the stock not modified look whistling devil
Re: Ladder bar suspension [Re: fourgearsavoy] #2383304
10/07/17 07:09 AM
10/07/17 07:09 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
was just reading on yellow bullit,can take timing out or 4-link with the right set up can curve wheel stands,a chebby owner thinks hes big with 200 ft wheelies here at local track,i prefer myself to keep the nose down,which equals faster et,you dont see pro stocks on the bumper
Re: Ladder bar suspension [Re: sgcuda] #2383318
10/07/17 10:23 AM
10/07/17 10:23 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I lost about 90 pounds when I switched from leaf Link style suspension to ladder bar and 60fts improve as well
Re: Ladder bar suspension [Re: fourgearsavoy] #2383387
10/07/17 01:14 PM
10/07/17 01:14 PM
sgcuda Offline
sgcuda  Offline
You will drop weight, increase your hook, and keep the nose down all at the same time with a set of ladder bars and coil overs. I did this on my Cuda and a SBC powered Foxbody.
[image][/image]
Re: Ladder bar suspension [Re: sgcuda] #2383394
10/07/17 01:24 PM
10/07/17 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I went with ladder bars on my Rampage.. the
race car has a 4 link.. they both hook very
well... the 4 link can hook in mud.. I
wanted the Rampage LOW so I went with the
ladder bars.. if you go with the ladder bars
and drive it on the street you should add a
bracket on the rear so you dont crack off the
bar at the rear.. if you need a pic I can show
you what I mean
wave
Re: Ladder bar suspension [Re: dart games] #2383437
10/07/17 03:04 PM
10/07/17 03:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Big difference between a Pro Stock and a stock '64 Savoy. There's a reason many Super Stock cars are set up to wheelstand. They go faster when allowed to pitch rotate.
Would doing a mini tub get you the room you need? If so, you can retain the leafs by just moving them in. With the Caltracs and stuff available for leaf spring cars now, ladder bars with leafs and sliders are not seen much anymore. Ladder bars and coilovers can also be used with stock framerails.
Or are you looking at a backhalf? At that point, I would consider ladder bars (or a 4 link) and coilovers. Lots more money, work, cutting up the car, etc., than the first option.
Re: Ladder bar suspension [Re: fourgearsavoy] #2383488
10/07/17 05:03 PM
10/07/17 05:03 PM
N.Y.
sixpacksteve Offline
N.Y.
my 64 sport fury has 3"exhaust. gas tank, leafsprings it all fits.
Yes its tight. i want too mini tub it to fit bigger tires.
backhalf,4 link big bucks. but worth it if your looking for that ET.
i'm staying with leafs cause its a street strip car.
Hell Hath No Fury Like Mine
Re: Ladder bar suspension [Re: fourgearsavoy] #2383614
10/07/17 10:37 PM
10/07/17 10:37 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Plenty of people going fast on leafs. Some are very fast.
Re: Ladder bar suspension [Re: CMcAllister] #2383634
10/07/17 11:45 PM
10/07/17 11:45 PM
Rittman Ohio
Rittman Ohio
I have seen some big Hoosier Quick Times mounted on 10" rims and they looked perfect. I'm hooking OK with a 9" slick but I would really like a 10.5 tire and it wont fit with my present configuration. I'm going to mini tub it and probably make my decision up then. Also considering a 9" when I'm doing the job if I can get enough money out of the Dana no
Gus
64 Plymouth Savoy
Dana 60
Re: Ladder bar suspension [Re: fourgearsavoy] #2383685
10/08/17 01:40 AM
10/08/17 01:40 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
A few things to consider. If this is for the street I vote for 4 link or leafs due to the one fact. Ladders do not allow for any articulation.
This is very hard on the car.
As for 3 inch exhaust out to the bumper. It's a challenge with all 3 set ups. Inboard leafs have 3 inch less room to the gas tank, than original and the bar set up needs a panhard bar.
Re: Ladder bar suspension [Re: Magnum] #2383741
10/08/17 08:52 AM
10/08/17 08:52 AM
Guitar Jones Offline
I agree with this but I think you could get by with a diagonal link instead of the panhard bar for more room.
Just go ahead and back half the car with a 4 link Gus. You won't regret it and you will have all you need for the future power upgrades.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Ladder bar suspension [Re: fourgearsavoy] #2383830
10/08/17 12:38 PM
10/08/17 12:38 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
Gus beer
I did a very similar thing.
1967 Charger 3800# Super stock springs relocated to the frame rails. CE shocks up front and C-body shocks out back.
The car ran mid elevens. I handled ok on the street, but I didn't like the way it sat or moved around under launch.
I mini tubbed the car and added CE Ladder bars with double adjustable QA1's at all corners. I also swapped 318 t bars in to replace the drag bars I had.
The added wheel room was great. The ability to adjust the rear ride height was also a nice feature.
The final result at the track was a quicker and more consistent launch a definite improvement of the leaf springs. A lot of this improvement can be attributed to the superior dampers.
It was just as difficult to move the springs inboard as it was to install the ladder bars.
This is a good way to go an a street strip car that doesn't see a lot of miles a year.
I was able to keep the interior and back seat functional, I'm not sure if that would be possible on a four link setup.
My only regret is that I bough QA1 instead of AFCO or Stanhuff for dampers. This change demonstrated to me how important good dampers are.
If exhaust clearacne is an issue using relocated super stock springs. I would think that ladder bars will have issues as well. Take a good look under there and decide what works better before you make a decision.
1974 Roadrunner
1967 Charger
Re: Ladder bar suspension [Re: fourgearsavoy] #2383874
10/08/17 02:11 PM
10/08/17 02:11 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
The ladder bar setup on my 69 Dart looked like it would have been pretty hard to run tailpipes in my opinion. The diagonal bar and front crossmember would have been kinda hard to get around so I just ran turndowns. A good welder/fabricator could probably get it done though.
I think a re-located Caltrac setup would be perfect for your car.
Re: Ladder bar suspension [Re: fourgearsavoy] #2383877
10/08/17 02:16 PM
10/08/17 02:16 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How did it handle on the street compared to the SS springs? work
