#2379675 - 09/30/17 10:17 PM 71 up - B Body Cars For Sale - 4th Quarter
moparts Offline
#2379791 - 10/01/17 08:01 AM Re: 71 up - B Body Cars For Sale - 4th Quarter [Re: moparts]
moparmarks Offline
Loc: Western Colorado High Desert
Have owned this car for over 15 years and will never do anything with it so up for sale it is.
1971 SSP 318 auto. P/S P/disc, a/c. Light Gunmetal Metallic. Two tone black and charcoal bucket seat interior. Rallye cluster. 8.25 rear. NO motor or tranny. Do have automatics available.
Real clean body. Only rust patches needed for right side of trunk floor, some channel work above windshield and a couple small ones on the fenders. Awesome floors, frames, quarters and trunk extensions, motor bay. Real clean underside.
Car is apart but mostly complete and is a major project.
Clear title in my name and have fender tag but no broadcast sheet..
Have more pictures.
4500.00obo
4000.00 obo.
Edited by moparmarks (10/20/17 12:00 PM)
71 RR A/G 4-sp Dana, 72 SSP 440, 72 Dart 5.9 4-spd, 97 DAKOTA, amoung others.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
moparmark@bresnan.net
#2379891 - 10/01/17 10:49 AM Re: 71 up - B Body Cars For Sale - 4th Quarter [Re: moparmarks]
R/T-X Man Offline
Loc: central, Illinois
1971 Plymouth GTX barn find. Very original and real solid car. All original paint except right front fender. Fender was badly damaged and was replaced with a rust free California fender and color matched. Has a 1972 440HP motor and a 1973 727 torqueflite. Trans has been re-built to stock specs. New lengendary vinyl top and front bucket seats. Super clean trunk and floor pans and frame. Some rust on lower corners of rear quarters. All trim in excellent condition. New radial tires on 14 inch ralleyes(build sheet calls for 15 inch ralleyes). Has power steering and power disc brakes. A/C complete but not operational. Has 2 body tags. Only non-stock parts are the headers and Holley carb( have a correct 1971 440/auto carter carb). Runs and drives but could but a lot of suspension and brakes are original and could use replacement parts to drive better and safer. Light package, console, rear speaker optioned car. This is a great solid original resto car for someone on a budget, can be driven and enjoyed as you replace or restore parts. $15,900 Mike 309-824-6220
#2381197 - 10/03/17 10:03 AM UNRESTORED 1974 ROAD RUNNER 7,300 MILES [Re: moparts]
canoer2 Offline
Loc: Delray Beach, FL
UNRESTORED ALL ORIGINAL WITH 7,300 MILES.
On the cover of Hemmings Classic Car in April 2014. The only 1974 Road Runner that has been certified original by Bloomington Gold Zenith and Survivor car program. Autographed in trunk and glove box by Jack Smith, Father of the Plymouth Road Runner.
Has won awards in concours shows in Boca Raton Fl, Winter Park FL, Pinehurst NC and at Hemmings Concours in Saratoga Springs NY. Plus many other awards. Appeared in the innagural car show at Donald Trumps Mar A Lago show in 2015, even though they did not have a catagory for the car.
This car is a big hit at any car show. The paint is coming off the engine in places, a retired Chrysler engineer said that engine paint was hit or miss on if you got a good paint job or not.
I regularly receive invitations to Concours shows and have an open invitation to one in Canada now.
$35,000 OR MAKE AN OFFER. 561-578-9763
Can't figure out how to get pictures on here so email to: steve@atlanticaccounting.com for photos.
#2383289 - 10/07/17 01:28 AM Re: 71 up - B Body Cars For Sale - 4th Quarter [Re: moparts]
RoadRunnerLuva Offline
Loc: The Great Lakes State
FOR SALE: PRICE REDUCED!!!
1973 Dodge Charger SE: Built OCT. 1972, Lynch Road Assy. Plant:
***CHECKOUT CRAIGSLIST AD WITH PICTURES, BELOW:***
This Charger is an Original E68 code, 400 HP 4-BBL MAGNUM BIG BLOCK factory built car...(WP29P3A) ONE OF ONLY 6,669 BUILT. Has Torque-flite 727 Automatic, Floor Console, with Slap-Stik Shifter and Bucket Seat Interior. Has Original 8-3/4 Rear Axle with Sure-Grip. Color is JF8 Forest Green. This Charger was built with LOTS of options, I have the ORIGINAL (TWO) FACTORY BROADCAST SHEETS, and BOTH FENDER TAGS, and ORIGINAL DOOR VIN DECAL/Dash VIN PLATE still on the car. Charger has a good, STRONG running 400 ci engine from a '77 Charger, original 400 is MIA. I HAVE LOTS OF BRAND NEW PARTS installed recently on this Charger:
* NEW Carburetor ( 4-BBL Thermo-Quad)
* NEW Fuel Filter and Fuel Hoses
* All Vehicle Fluids Replaced (Brake/Trans/Engine/Coolant/Rear Axle)
* NEW Air Filter (ORIGINAL HP DUAL SNORKEL AIR CLEANER W/CAR)
* NEW Cap/Rotor/Spark Plugs/Wires
* NEW Battery
* NEW Starter
* NEW Radiator (w/original shroud)
* NEW Water Pump
* NEW Thermostat Housing
* NEW Thermostat & Gasket
* NEW 7 Blade Fan/Thermal Clutch Unit
* NEW Belts
* NEW 2-1/4" Aluminized Exhaust w/ NEW Turbo Mufflers
* NEW Shocks
* NEW Left Rear Shock Mount Plate w/U-bolts
* NEW Complete Front Power Disc Brakes
(Rotors/Pads/Calipers/Hardware/Hoses)
* NEW Complete Rear Drum Brakes (Drums/Shoes/Hardware kit)
* NEW Brake Lines
* NEW Gas Tank
* NEW Tank Straps
* NEW Fuel Sending Unit
* NEW Fuel Lines
* NEWER Tires (ORIGINAL MAGNUM 500 5-SPOKE ROAD WHEELS STILL ON CAR)
* NEW Tail-lamp bulbs
* NEW Wiper Blades
I have ALL receipts for everything listed above.
This is a good running/shifting/driving BIG BLOCK B-BODY FOR UNDER 10K ..AND IT'S 99% COMPLETE.
***PRICE REDUCED*** $6,995 I also have extra (rust-free) sheet-metal included...along with some other parts as well.
Clean title in my name. Call for honest decription of this car, it does deserve/need resto, but as mentioned, it RUNS/DRIVES/STOPS GOOD, and it's 99% all there...you can drive it, while you re-do it.
Call: (989) 975-9621 or PM here on Moparts. SORRY, NO TRADES PLEASE!
**BELOW is a current Michigan Craigslist ad with pictures:**
https://detroit.craigslist.org/okl/cto/d/1973-dodge-charger-se-400-hp/6325218651.html
#2383658 - 10/07/17 10:37 PM 71 Roadrunner - EL5 383 AG [Re: moparts]
71383beep Offline
Loc: IL
Decided to put my 71 Runner up for Sale:
Specs are 71 Roadrunner, EL5 (Bahama Yellow), 71 383 HP motor and 727 is non numbers to the car but matching to each other. Interior is black bench seat with column shift. It is an original N96 air grabber car which functions flawlessly. The paint to my knowledge is original. It still retains the factory hand brushed black along the bottom of the rockers and the organisol blackout on the rear of the hood and upper cowl is outstanding. As a bonus in its lifetime someone installed the original style rear louvers and spoilers to the car which really standout nicely against the EL5.
As for function it is THE most dependable driver I've ever owned. Ive simply just done tune up work to it and it starts, stops, turns and runs like the factory made. The motor does drip a little and in my opinion is getting a bit tired but its no where near ready to throw the towel in yet. The only other thing i can point to is the suspension is worn and could use an update. I have all new front wiring for it, but haven't had the need to replace it yet.
Fender Tag is as follows:
V8X END
M21 N41 N96 N97 R11 V21
EL5 U A87 B51 J52 J55
EL5 H2X9 TX9 916 040614
E65 D32 RM23 N1E 106594
Cowl and Radiator Stamps Match the VIN. motor and tranny are 1E108170
UPDATE: I have purchased another car and would like to sell this one quick. Therefore PRICE REDUCED $28,995 obo.
I recommend you come and see it. You won't be disappointed!
For pictures please go to the craigslist ad. Im struggling with posting photos on here lately.
71 Roadrunner 4 Sale - Craigslist
Edited by 71383beep (10/16/17 04:09 PM)
'71 EL5 Roadrunner - 383 Auto w/ AG
#2384233 - 10/08/17 11:21 PM Re: 71 up - B Body Cars For Sale - 4th Quarter [Re: moparts]
morty318 Offline
1971 roadrunner, Hemi orange, black interior,professionally built 383 stroker, 727 console, 355 posi rear, modern stereo, disk brakes, turn key cruiser, perfect body.38k or best, Detroit area. 810-343-5534, will send pics on request, morty318@aol.com.
#2385800 - 10/11/17 04:33 PM 1973 Plymouth Satellite Sebring, 37k original miles, NICE [Re: moparts]
dcastine Offline
Loc: New England
1973 Plymouth Satellite Sebring, 37,000 ORIGINAL MILES. 318, Auto, AC, PDB, PS, AM-FM Radio. Extensively documented by all the previous owners, used as the subject for a Hemmings Motor News article showcasing the Mopar B-Body cars for '73. Mostly original paint, 100% original interior, never restored just fanatically maintained - this car has never had ANY rust repair, all original sheet metal. Everything works and it runs and drives like you would expect it to. You'll be very proud driving this into your local cruise night - it's not just another Chevelle, Camaro, or Mustang. Priced very reasonably - get into the collector car hobby, have fun! Life is Short so Enjoy Your Ride! Asking $19,500 obo, fly in and drive her home!
Dave Castine
Vintage Cars Online, LLC.
Wakefield, MA
(617)513-7407
#2385810 - 10/11/17 04:51 PM 1974 Dodge Charger SE 360, CA car - 408 Stroker, car is NICE [Re: dcastine]
dcastine Offline
Loc: New England
1974 Dodge Charger SE Brougham, California car brought here and then built as you see it, never in any bad weather. ALL original sheet metal, all spot welds, all undercarriage bolts, seems, and surfaces are PERFECT! ICE Cold AC, power steering, and power front disc brakes. This is a JOY to drive and cruise easily or mash the pedal for a amusement park thrill ride!
Now for the good stuff - this was an original 360/4v car, backed by a 904 trans and highway friendly set of 2:73'S - NOT ANY MORE !!!
Current owner is a BIG Charger fanatic (also owns a very nice 68 383 Charger - not for sale). He has replaced the ENTIRE drive-train with a bullet proof setup. THIS CAR WON'T BREAK!!
408 Indy Cylinder Head stroker motor, 450hp/530lb ft - Aluminum Indy heads, ceramic coated headers, single plane intake, Holley DP/DF 750 CFM carb, MSD ignition, remote Oil Filter (BIG PLUS!!), trunk mounted battery, electric fuel pump, etc.
TorqueFlite TCI Street Fighter trans, B&M Torque Converter, Cooler - THIS BABY BARKS!!
Original 8-1/4 rear end but all new guts - 3:55 Sure Grip gears no reside in the back end.
All new suspension, leaf springs, Shocks, exhaust, and brake system.
This car is LASER STRAIGHT, with a cool "ghost image" of the hallowed Mopar logo on the doors, fiberglass RT style hood, Rear "Go-Wing", this car is virtually new from front to back.
$26,500
Dave Castine
Wakefield, MA
(617)513-7407
#2387760 - 10/15/17 01:36 PM Re: 1974 Dodge Charger SE 360, CA car - 408 Stroker, car is NICE [Re: dcastine]
chargervert Offline
Loc: RI Deep in the rust belt
I have a 1973 Dodge Charger SE for sale. It is a Basin Street Blue (aka Petty blue )car with a white roof and interior. It is an original 400 big block powered car with an automatic transmission. I confirmed that the car is matching numbers and has the fendertag and build sheet. It is a running project car that would need brake and frontend refreshed to make roadworthy. The car has a Hurst quarter stick shifter and Crager draglite wheels with good rubber on them. The car is pretty solid, but does need some metal work to be done before paint. I have a lot of molding and trim peices to go with it,as well as a dual exhaust rear valence pan,new window weather seals,and other mechanical parts. Another rallye dash with the wiring harness is included as well. The 400 engine has a Holley carb,M/T valve covers,and headers. The car has an unsigned Mass title as well. This is the last of the big block powered high impact colored Chargers,and is a great entry level Mopar project car. Also keep in mind that the early seventies high nickel content 400 blocks are great for building high horsepower, big cube low deck stroker emgines. I am planning on bringing the car to the Mopar show at Lebanon Valley Dragway next weekend and could possibly deliver it within a reasonable range. I am asking $3800.00 for the car,but would sell it for $3300.00 without the wheels and tires. If someone doesn't want the wheels I will include a set of 14 inch rallye wheels. If someone pays the asking price I will include the rallye wheels as well as the Cragar wheels. If anyone is interested in the car they can contact me at 1 401-722-4744,or send me a PM here on Moparts. Thanks Pete.
Edited by chargervert (10/15/17 01:43 PM)
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
24,903 Registered Members
184,382 Topics
96 ram steering box seal leak
by chargers777
10/23/17 11:19 PM
Replacement Key for a 2016-17 Challenger?
by 1971d21
10/23/17 11:17 PM
1969 AMC JAVELIN SST Badger
by FM3_1970
10/23/17 11:08 PM
1973 AMC Ambassador EX-Cop car
by FM3_1970
10/23/17 11:03 PM
