#2383121 - 10/06/17 06:48 PM Aftermarket Retainer ?
EV2Bird Offline
On Vacation
Loc: Kansas Roads Between 0 and 140...
Aftermarket Retainers with oem valves and locks.... is it possible in any form or fashion?
Ive some hughes retaines for a bit more height and outwardly they seem to fit and are a bit more snug then the oem retainers?
Any red flags here?
Thanks.
#2383141 - 10/06/17 07:47 PM Re: Aftermarket Retainer ? [Re: EV2Bird]
Supercuda Offline
part number of the hughes retainer would go a very long way to answering the question.
Hughes lists 9 different part numbers for retainers
#2383163 - 10/06/17 08:14 PM Re: Aftermarket Retainer ? [Re: EV2Bird]
EV2Bird Offline
On Vacation
Your very right.
Ive got the 1252 and 1254 retainers to consider.
Gonna use the 1110 spring, maybe the 1111 spring.
509/280 mopar solid cam
This is my budget but new small valve 318 heads and I have the new oem valves, did the 3 way and a small back cut on the valves.
Kinda hard to find aftermarket single groove valves that are not costly, the 2.02/1.60 sets are dirt cheap since there so common.
#2383173 - 10/06/17 08:26 PM Re: Aftermarket Retainer ? [Re: EV2Bird]
Supercuda Offline
Ok, both 1252 and 1254 are 7 degree retainers, which is what stock locks need.
Odds are the Hughes retainers were made with a bit more care and on newer tooling than the original retainers.
#2383230 - 10/06/17 10:20 PM Re: Aftermarket Retainer ? [Re: EV2Bird]
EV2Bird Offline
On Vacation
Thank You, I can get new keepers off ebay cheap since the old ones ive got seem a bit worn.
There is only like a 2 gram weight difference as well.
25,150 Registered Members
186,812 Topics
Double your pleasure - Rectrans motorhomes
by NTOLERANCE
02/24/18 08:15 AM
How hard to remove just the engine?
by NHCharger
02/24/18 07:30 AM
70 Roadrunner Heat Riser Valve Question.
by TimS
02/24/18 06:53 AM
Adjustable shocks?
by 451Mopar
02/24/18 02:35 AM
