Re: Ladder bar suspension
[Re: fourgearsavoy]
#2383224
10/06/17 11:57 PM
10/06/17 11:57 PM
Posts: 1,030 ohio
67mprfan
ohio
What type of rear suspension do you have now
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2383228
10/07/17 12:11 AM
10/07/17 12:11 AM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
Just SS leafs 3800# with Rancho 9 way RS shocks.
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2383236
10/07/17 12:29 AM
10/07/17 12:29 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you want more tire and want to hook up better then put the bars on but if you really want a better suspension then go with a 4 link but the ladder works great also
[Re: fourgearsavoy]
#2383276
10/07/17 02:26 AM
10/07/17 02:26 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
My Duster was a real hoot on the street and strip and it was real easy to hook up with 36 inch ladder bars and double adjsutabel strange Engr. 15 inch long coil overs with a diagonal link I had three inch exhaust all the way to the rear bumper but do to the coil overs the pipes went under the rear end and around the rear tires do to having fender well headers on the car, the 14x7x3 inch inlets and outlets old school Magnaflow mufflers where mounted behind the rear end and between the rear 1/4 panels and rear sub frames I ran the stock Duster gas tank also for the stock not modified look
[Re: sgcuda]
#2383318
10/07/17 10:23 AM
10/07/17 10:23 AM
Posts: 1,030 ohio
67mprfan
ohio
Ladder bars and coil over shocks would drop a significant amount of weight off the back also. I lost about 90 pounds when I switched from leaf Link style suspension to ladder bar and 60fts improve as well
[Re: fourgearsavoy]
#2383387
10/07/17 01:14 PM
10/07/17 01:14 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
You will drop weight, increase your hook, and keep the nose down all at the same time with a set of ladder bars and coil overs. I did this on my Cuda and a SBC powered Foxbody.
[image][/image]
[Re: sgcuda]
#2383394
10/07/17 01:24 PM
10/07/17 01:24 PM
MR_P_BODY
I went with ladder bars on my Rampage.. the race car has a 4 link.. they both hook very well... the 4 link can hook in mud.. I wanted the Rampage LOW so I went with the ladder bars.. if you go with the ladder bars and drive it on the street you should add a bracket on the rear so you dont crack off the bar at the rear.. if you need a pic I can show you what I mean
[Re: dart games]
#2383437
10/07/17 03:04 PM
10/07/17 03:04 PM
Posts: 11,494 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
you dont see pro stocks on the bumper Big difference between a Pro Stock and a stock '64 Savoy. There's a reason many Super Stock cars are set up to wheelstand. They go faster when allowed to pitch rotate. Would doing a mini tub get you the room you need? If so, you can retain the leafs by just moving them in. With the Caltracs and stuff available for leaf spring cars now, ladder bars with leafs and sliders are not seen much anymore. Ladder bars and coilovers can also be used with stock framerails. Or are you looking at a backhalf? At that point, I would consider ladder bars (or a 4 link) and coilovers. Lots more money, work, cutting up the car, etc., than the first option.
[Re: fourgearsavoy]
#2383488
10/07/17 05:03 PM
10/07/17 05:03 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my 64 sport fury has 3"exhaust. gas tank, leafsprings it all fits. Yes its tight. i want too mini tub it to fit bigger tires. backhalf,4 link big bucks. but worth it if your looking for that ET. i'm staying with leafs cause its a street strip car.
Hell Hath No Fury Like Mine
[Re: CMcAllister]
#2383634
10/07/17 11:45 PM
10/07/17 11:45 PM
fourgearsavoy
Rittman Ohio
I have seen some big Hoosier Quick Times mounted on 10" rims and they looked perfect. I'm hooking OK with a 9" slick but I would really like a 10.5 tire and it wont fit with my present configuration. I'm going to mini tub it and probably make my decision up then. Also considering a 9" when I'm doing the job if I can get enough money out of the Dana Gus
[Re: fourgearsavoy]
#2383685
10/08/17 01:40 AM
10/08/17 01:40 AM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
A few things to consider. If this is for the street I vote for 4 link or leafs due to the one fact. Ladders do not allow for any articulation. This is very hard on the car.
As for 3 inch exhaust out to the bumper. It's a challenge with all 3 set ups. Inboard leafs have 3 inch less room to the gas tank, than original and the bar set up needs a panhard bar.
[Re: Magnum]
#2383741
10/08/17 08:52 AM
10/08/17 08:52 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
As for 3 inch exhaust out to the bumper. It's a challenge with all 3 set ups. Inboard leafs have 3 inch less room to the gas tank, than original and the bar set up needs a panhard bar. I agree with this but I think you could get by with a diagonal link instead of the panhard bar for more room. Just go ahead and back half the car with a 4 link Gus. You won't regret it and you will have all you need for the future power upgrades.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: fourgearsavoy]
#2383830
10/08/17 12:38 PM
10/08/17 12:38 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
I have been thinking of adding more tire room on my Savoy and I thought about taking the easy route and going with a ladder bar suspension. I was going to re-locate the springs into the frame rails but that might conflict with my plans for 3" exhaust out to the bumper. Should I just move the springs or go with the ladder bars. I just want more tire clearance and if I could make the suspension just a little better in the process I would be stupid not to make an improvement Gus Just SS leafs 3800# with Rancho 9 way RS shocks. I did a very similar thing. 1967 Charger 3800# Super stock springs relocated to the frame rails. CE shocks up front and C-body shocks out back. The car ran mid elevens. I handled ok on the street, but I didn't like the way it sat or moved around under launch. I mini tubbed the car and added CE Ladder bars with double adjustable QA1's at all corners. I also swapped 318 t bars in to replace the drag bars I had. The added wheel room was great. The ability to adjust the rear ride height was also a nice feature. The final result at the track was a quicker and more consistent launch a definite improvement of the leaf springs. A lot of this improvement can be attributed to the superior dampers. It was just as difficult to move the springs inboard as it was to install the ladder bars. This is a good way to go an a street strip car that doesn't see a lot of miles a year. I was able to keep the interior and back seat functional, I'm not sure if that would be possible on a four link setup. My only regret is that I bough QA1 instead of AFCO or Stanhuff for dampers. This change demonstrated to me how important good dampers are. If exhaust clearacne is an issue using relocated super stock springs. I would think that ladder bars will have issues as well. Take a good look under there and decide what works better before you make a decision.
1974 Roadrunner
1967 Charger
[Re: fourgearsavoy]
#2383874
10/08/17 02:11 PM
10/08/17 02:11 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I was going to re-locate the springs into the frame rails but that might conflict with my plans for 3" exhaust out to the bumper. The ladder bar setup on my 69 Dart looked like it would have been pretty hard to run tailpipes in my opinion. The diagonal bar and front crossmember would have been kinda hard to get around so I just ran turndowns. A good welder/fabricator could probably get it done though. I think a re-located Caltrac setup would be perfect for your car.
