Page 1 of 2 1 2 >
#2379625 - 09/30/17 09:51 PM For Sale - Big Block Engine - 4th Quarter
moparts Offline
#2379787 - 10/01/17 07:31 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
Suregrip391 Offline
Loc: USA
1967 C440 HP engine block, intake manifold, exhaust manifolds, distributor, carb, oil pan, waterpump housing, windage tray, radiator, balancer, air cleaner, crankshaft, wood wheel, underhood and under dash wiring, misc interior trim, side door glass, will update list later today, more parts included .$3500/all. Perfect fit for your 1967 Plymouth GTX or 1967 Coronet RT. Block cast in 1966, assembly date on front pad 2/2/67.
Edited by Suregrip391 (10/20/17 01:01 PM)
Edit Reason: Add pic
#2379922 - 10/01/17 11:44 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
budman1965 Offline
Loc: Edison, NJ 08817
70's era single snorkel air cleaner-has black wrinkle paint-good condition-no dents or damage-needs blasting and repaint Asking $80
Contact Bud 732-287-0982 or Kramden426@aol.com
#2379933 - 10/01/17 12:05 PM A12 Six Pack Carbs [Re: budman1965]
70sixpkRT Offline
Loc: South San Francisco, Ca
I have a set of Six Pack manual carbs for an A12. Front: Date code 1229 part# 4393. Center: Date code 1229 part# 4391 for manual. Rear: Date code 0929 part# 4394. All 3 carbs are untouched and in good condition.
$1600 + shipping.
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2380014 - 10/01/17 02:13 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
@#$%&*! Offline
New user name, Same old jerk!
Loc: 1940 North Victory Boulevard ...
Holley Street Dominator Intake Manifold RB 440-413
Blasted clean and washed with soap and water. All threads good and chased, never ported, no signs it was ever milled. Someone did shorten the front coil mount pedestal for some reason but it still has enough threads to hold a coil. Perhaps will work with a small-block coil bracket, I should try that.
$200 plus shipping
not offended by offers
PM through board
#2380018 - 10/01/17 02:21 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
'187 Oil Pan and Windage Tray
Factory 187 oil pan for big-block engines and factory windage tray. Good condition, OE paint!
$125 plus shipping
PM through board
#2380023 - 10/01/17 02:27 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
Timing Cover
Not much more to say about it 'cept it's for '72-back with timing tab on passenger side.
$30 plus shipping
PM through board
#2380030 - 10/01/17 02:32 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
933 Oil Pan
Not sure of the original application, maybe Imperial? Drain plug on the side of the sump instead of rear. Otherwise like other C-body BB oil pans in most respects.
$60 plus shipping
PM through board
#2380038 - 10/01/17 02:41 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: @#$%&*!]
@#$%&*! Offline
BB Truck Oil Pan + pickup and dipstick
Fits '72-'93 I believe. Dipstick tube may be bent, not sure of original shape but it's just tubing with a flare on the end and can be easily fabbed.
$125 plus shipping
PM through board
#2380246 - 10/01/17 08:02 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Cal Custom El Toro air cleaner wing nut. $5
Used Crane cam #278-2. Cam only, no lifters. $75
Used chrome thermostat housing. $5
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner hose. $20
Cal Custom 14" aluminum air cleaner with filter. $100
1970 Big block single nipple oil breather with hose. $35
New 12" oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $60
Cal Custom 9" finned air cleaner top and base. No filter. $75
Mr. Gasket 1" thick carb spacer. $15
137 Spectre brand radiator and heater hose clamp covers. Some chrome, some red and some blue anodized. Various sizes. $50 for the lot.
1972 400 parts. Oil pump $5, various AC brackets $50 for the lot, spark plug shields $15 pair, exhaust manifold heat stove for non-hp manifolds (needs a little straightening) $15. $50 for everything.
Carb. throttle linkage pin. $10
Pair of big block exhaust manifolds. Part numbers 3830800 & 3830820. $80
Pair of big block exhaust manifolds. Part numbers 2532626 & 2532464. $100
Pair of big block heads. Part number 2406516. $100
Prices do not include shipping. gt340 at yahoo.com
#2380312 - 10/01/17 09:37 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bill440rt Offline
Loc: NJ, USA
HEMI “215” fan with clutch. No numbers on the clutch, but does not appear to be a "short shaft" type clutch. Clutch is tight. Very minor surface rust in spots on the fan, but no pitting. Very nice part overall.
Price is $120 plus shipping.
PM here or email bill440 "AT" optonline.net if interested.
Thanks!
#2380551 - 10/02/17 11:25 AM 440 HP blocks, '68 and '71 [Re: bill440rt]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
D 440 HP (1968) Magnum Mopar block with matching main caps. This is a BARE block.
No damage and in great shape.
Bores are .030" over currently and looks like it just needs a quick hone to be used at that size.
Cast date 3/29/67, build date 12/23, VIN 8B240592
I also have a G 440 HP (1971) block and it's main caps (again, a bare block) that's currently .040" over and has a professionally installed sleeve in the #5 cylinder. The motor had been run since the sleeve, so there's no problem w/ it. It only had a scratch in the cylinder wall, no cracks or holes, that caused me to sleeve it.
Cast 12/16/70, built 1/11, VIN 1A150062
$400 each. No shipping, but I will wrap in plastic, strap to a pallet, and drop off at one of the local freight shipper.
I do take paypal if you cover the fee.
PM me here or call/text 843-431-8376
Thanks, Chip
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2380726 - 10/02/17 04:18 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
DudleyPerformanc Offline
Loc: North Carolina, USA
Wiseco 440 Pistons 55 Over *New in the box*
$395
Located in Walkertown NC
Near Winston Salem
Contact by Phone @ 336-595-2000
[img:center]http://[/img] [img:center]http://[/img]
Mark Dudley Performance and Parts
Walkertown, NC 27051
(336) 399-7262
We offer a complete line of High Performance
Parts, Engines, Transmission and Body needs for
1960-1970's Mopar's from Street to Strip.
#2380774 - 10/02/17 05:39 PM : For Sale - Big Block Engine - 4th Quarter [Re: DudleyPerformanc]
docr Offline
Loc: Indiana USA
For Sale:
OEM “One Year Only” – 1967 440 HP Dodge Coronet R/T, Plymouth GTX or Charger - Dual Snorkel Air Cleaner (top lid/base), with vent nipple on lid
4-1/4” hole diameter in base (for original AFB Carburetor), 3-1/2” OA height.
(Difficult to find with this base) **** Excellent condition ****
Comes with Super Commando Pie Tin (Fixed to lid)
$425.00 plus shipping and insurance
E-mail only at sacdrose@att.net
Located in the 46530 (Northern Indiana) zip code
***** THANKS TO MOPARTS.COM *******
#2380789 - 10/02/17 05:54 PM Re: : For Sale - Big Block Engine - 4th Quarter [Re: docr]
docr Offline
Loc: Indiana USA
For Sale:
ONE YEAR ONLY – 1967 R/T or GTX --- 440 HP (Auto)
Single Point Distributor PN2642748.
$135.00, includes shipping in lower 48 (From zip 46530 – Northern Indiana)
ONE YEAR ONLY – 1967 440 (HP) Drivers Side (left) Exhaust Manifold.
PN 2806974. For Dodge RT or Plymouth GTX (Dated 10-?-?)
$260.00 (Includes shipping in lower 48 )
Carter 3253S- AM1 AFB '62 361CI (305 Horse Power) A/T – HP Dodge or
Power Pac Ply. ---- (Missing auto spring coil thermostat assembly) --- $60.00
Carter 4328S AFB (Same as 4326S, but with C.A.P.) – F6 Date (June ’66), w/Tag – Manual ----- $65.00 (Missing some linkage parts) – ’67 440 HP, one year only (A-134) – Needs work, 2 Throttle plates stuck.
Carter 4329S AFB (Same as 4327S, but with C.A.P.) – A6 Date (Jan. ’66), w/Tag – Automatic ----- $85.00 - ’67 440 HP, one year only (A-134)
(All carburetors most likely need rebuilt – Shipping extra)
***** THANKS MOPARTS.COM *****
#2380805 - 10/02/17 06:12 PM Re: : For Sale - Big Block Engine - 4th Quarter [Re: docr]
docr Offline
Loc: Indiana USA
For Sale:
Nice OEM – 1965 to 1967 Mopar- Single Round (2-1/4”)
Snorkel Air Cleaner (lid/base) (17' dia)
(“CAP” air nipple on side of lid)
4-1/4” hole diameter in base (for original AFB Carburetor), 3-3/4” OA height.
Accepts standard pie tins on lid
$60.00, (Includes Shipping in lower 48)
#2380959 - 10/02/17 09:29 PM Comp Cams High Energy Timing Set [Re: docr]
mopars4life Offline
Loc: Virginia
Comp Cams High Energy Timing Set - Big Block - New in the Box
I have a new high energy timing set- solid but single link. Retails for $45 but will sell for $35. Moparsforlife@hotmail.com.
#2381382 - 10/03/17 06:09 PM 1969 440 Hp from GTX [Re: mopars4life]
davesmopars Offline
Loc: cheshire, ct
1969 440 HP block
Built By Comp U Flow
528 pump gas E Z Heads
Built for the street
Dyno over 700 HP with sheet
Torque 650
Dyno time only
10.6 to 1 with aluminum heads
Long list of parts all good stuff and work done
14,500 invested
Best offer
only reason selling is I change direction in my 68 Barracuda Installed a 604 Hemi
It was going into an a body with factory mounts
Edited by davesmopars (10/03/17 06:17 PM)
#2383184 - 10/06/17 08:40 PM Edelbrock Mopar 440 RPM intake Edelbrock 1414 800 CFM carb [Re: moparts]
sawdust Offline
Loc: Green Lane, PA
Like new Edelbrock RPM intake, Mopar branded but same intake made by Edelbrock. Also Edelbrock 800 CFM carb in excellent condition. Electric choke, stock jets and metering rods. Used for about 15 miles, ran awesome but wanted more old school look. Switched to dual quad setup so no longer need. $500.
info@kriebeldesigns.com or PM me here.
1967 RO23 4 speed
1967 RO23 4 speed "Poison Ivy"
1967 RO23 4 speed "A-Town Hustler"
1967 NSS Belvedere Post 4 speed
1970 Triple red hemi cuda
2016 PCP Hellcat M6
#2383538 - 10/07/17 05:27 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
hemienvy Offline
Loc: Washington
All for Sale, my 511 RB project:
1977 440 block, now .030, cleaned, magged, and sonic checked.
The sheet is posted here. Sonic numbers are the .030 numbers,
they look pretty good.
KB billet 4.25 crank, magged, all standard, already has a bunch of mallory.
New Hemi rods and Ross 4.375" flattops, plus a used Fluiddampr.
Rebuilt 906 heads, mild port cleanup, new valves/springs/
hardware. Springs are Engle 594/595 double spring for .575"
solid flat tappet. Valves are 2.14/1.81.
Used and dinged up Hooker 5209 headers, but they are ceramic
coated, and have evac tubes.
Weiand Street Dom + Holley 4781-2 850DP/manual choke.
I didn't have them in the pics, but I'm including a set of
valve covers, I have cast Indy and old M/T finned, your choice.
I calculated right at 9.5~9.6 CR using shim head gaskets.
So, I think $3500 is a fair price, it's all good stuff. I live
north of Seattle. I'd prefer you come and visit me, which of
course limits my buyers, but I will crate it up to ship if you
are willing to pay, that could easily be $500+ though.
I can take as many pics as you need, just contact me.
OK. No pics yet. The sonic sheet is a PDF and the pics
are all too big so I'm trying to re-size. Please stand by.....
I give up on the pics, I can't get them small enough. I'll
email pics and sonic sheet to whoever wants them.
Edited by hemienvy (10/08/17 02:54 PM)
Edit Reason: very trying
Page 1 of 2 1 2 >
24,901 Registered Members
184,302 Topics
Firewall grommet hole for tachometer
by 340clone
10/22/17 12:28 AM
Go Astros
by stumpy
10/21/17 11:42 PM
Look who came over for Mopar parts today
by AndyF
10/21/17 09:16 PM
1968 hemi engine for a bee
by dynotune440
10/21/17 09:03 PM
