Where to get heads ported #2383014
10/06/17 04:06 PM
10/06/17 04:06 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Looking at getting my -1s ported this year and wanted to hear from you guys.. looking at turn around time customer service and pricing.. let me know you thoughts.. thanks guys John...
Re: Where to get heads ported [Re: 70dusterjohn] #2383016
10/06/17 04:09 PM
10/06/17 04:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Modern
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Where to get heads ported [Re: 70dusterjohn] #2383029
10/06/17 04:32 PM
10/06/17 04:32 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Porter Racing Heads
Re: Where to get heads ported [Re: SILVER67] #2383036
10/06/17 04:50 PM
10/06/17 04:50 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Originally Posted By SILVER67
Porter Racing Heads
iagree
69 GTX 68 Road Runner
Re: Where to get heads ported [Re: 70dusterjohn] #2383041
10/06/17 04:56 PM
10/06/17 04:56 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Porter too. Both very good
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Where to get heads ported [Re: 70dusterjohn] #2383050
10/06/17 05:14 PM
10/06/17 05:14 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
K&G 419- 345-2556 dave
they are in ohio
they do all my heads and they are the best
Re: Where to get heads ported [Re: 70dusterjohn] #2383069
10/06/17 06:20 PM
10/06/17 06:20 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Porter Racing heads.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Where to get heads ported [Re: SILVER67] #2383072
10/06/17 06:31 PM
10/06/17 06:31 PM
Porter Racing Heads
When I called him on the first set of 440-1 I wanted ported he referred me to Modern Cylinder heads to have them CNC port them work shruggy
He told me he was super busy then and it would be longer than a couple of months to get them done back them, 6 to 10 yrs ago shruggy
OP, call both of them and get all the information you need to decide scope twocents
Re: Where to get heads ported [Re: 70dusterjohn] #2383076
10/06/17 06:52 PM
10/06/17 06:52 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Call Ryan at Shady Dell 814-308-8058 or Bob at Modern cylinder head
Re: Where to get heads ported [Re: JERICOGTX] #2383088
10/06/17 07:20 PM
10/06/17 07:20 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Porter Racing Heads
iagree
Yep Porter Racing Heads. Dwayne is one of the best if not the best and he is nice guy with fair prices who is great to deal with. You cant go wrong with Dwayne Porter. Ron
Re: Where to get heads ported [Re: 70dusterjohn] #2383123
10/06/17 08:52 PM
10/06/17 08:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I appreciate the positive comments from the members here who have had me do the work on their heads....... Thanks!!
However, in cases like this where there is a CNC porting service available for a particular head type...... It's usually the more cost effective option(I still do my porting by hand).
Modern, as well as others, have good programs for those heads...... And it's a little like the old story of John Henry.
It's tough to try and go head to head(pun intended) with a machine.
Re: Where to get heads ported [Re: fast68plymouth] #2383312
10/07/17 09:57 AM
10/07/17 09:57 AM
K
KOS Offline
KOS  Offline
K
[quote=fast68plymouth]I appreciate the positive comments from the members here who have had me do the work on their heads....... Thanks!!
yes but with the customer service you provide I would take the slight difference.
Re: Where to get heads ported [Re: 70dusterjohn] #2383404
10/07/17 01:39 PM
10/07/17 01:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
If I'm selling new Indy heads, and the customer is looking for something that's "fully ported", I just get them CNC'd from Indy, then I do my valve job and prep.
On my bench, after the VJ and prep, a 440-1 CNC 325 flows 360-365.
A CNC 345 goes 380-385.
I'm sure someone has a program that flows more than the Indy 345...... But so far, those have been the best 440-1's to cross my bench.
Re: Where to get heads ported [Re: fast68plymouth] #2383440
10/07/17 03:18 PM
10/07/17 03:18 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
What about a massaging a set of TF240s?
Re: Where to get heads ported [Re: 70dusterjohn] #2383442
10/07/17 03:30 PM
10/07/17 03:30 PM
AndyF Online content
AndyF  Online Content
Your priorities are turn around time, customer service and pricing? How about flow? Or durability?
I'm not just trying to jerk your chain I think you need to consider these things. For example, when Modern did my Indy heads their CNC program was set on "kill". The heads flow a ton of air but they are also fragile since so much material was removed. Is that what you want?? Maybe you do if you are a super serious racer. If you are a bracket racer or a street guy then maybe you don't want your heads ported to the max.
Re: Where to get heads ported [Re: AndyF] #2383512
10/07/17 06:15 PM
10/07/17 06:15 PM
Deerfield, Ohio
Deerfield, Ohio
I want reliability ... I do bracket race a lot the cars driven on the street a lot .. so I don't want something that is fragile. Just looking to make more power than I am now with out of the box -1 heads ..
Re: Where to get heads ported [Re: fast68plymouth] #2383515
10/07/17 06:23 PM
10/07/17 06:23 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
How do these numbers compare to a hand port job? Just wondering if CNC is set for a conservative number as opposed to having someone hand port and get a visual of the actual ports before and after.
Re: Where to get heads ported [Re: 70dusterjohn] #2383523
10/07/17 06:45 PM
10/07/17 06:45 PM
Okay, I think in that case you need to pick up the phone and call a few shops. Be clear that you want to make more power than you are making today but that you do not want lawn sprinklers. The CNC routines may be fine for what you want and they might not. It all depends how aggressive the program is. Since you already have used heads then you might want to start with someone like Dwayne who would pull them apart and check them and figure out a game plan. For new heads I'd start with conservative CNC heads and then step up from there but used heads are a little different situation.
It also depends on what cam you are running. Some of the CNC programs are designed to flow a lot of air up top but if you are just running a 0.600 lift cam then why pay for big flow at 0.800?
Re: Where to get heads ported [Re: 70dusterjohn] #2383530
10/07/17 07:04 PM
10/07/17 07:04 PM
Deerfield, Ohio
Deerfield, Ohio
I bought the heads brand new. I just bolted them on the car and ran them the way they where so I have had them the whole time. I plan on up grading the cam too ..
Re: Where to get heads ported [Re: sgcuda] #2383537
10/07/17 07:24 PM
10/07/17 07:24 PM
So. Burlington, Vt.
So. Burlington, Vt.
I've never seen anything "magical" with these heads...... Meaning flowing more than they "should" for what's been done to them.
Without trying to reengineer what's there...... After you've put a good valve job in them, and blended that into the bowls and chambers...... You pretty much have what you have.
If you want more, it's a matter of just upsizing the entire port(for the most part).
So, to answer the question about what hand ported versions flow..... It usually depends on how much time someone was willing to stand there and make them bigger.
I will add that the intake short turn on the CNC 345 seems to have more height than even an ootb unported 440-1........ So I don't know that you can put that exact same port into a std
440-1.
I don't feel the Indy 345 program is that conservative. It's a pretty spacious port, and the ex ports are pretty big as well.
Myself, I don't like standing there and just hogging chips out of a head to make it "big", so when I port these they are probably more in the 320cc range, and as a result don't flow as much as the CNC versions, which are bigger. I get 350-355 with a 2.19 valve, 355-360 with a 2.25 valve.
Truly "ootb" 440-1's....... Meaning NO porting or blending, barely go over 300cfm.
But with a nice valve job and bowl blend, along with some chamber work, 340-ish is easy to get.
The newest version comes with the chambers CNC'd already, and those are a few cfm better with that first stage of prep.
After that....... You're def at the point of diminishing returns when it comes to the amount of time porting vs the gain in cfm.
Here are some numbers from a new set with the cnc chambers, just as they came ootb, Indy 2.19 valve and valve job. Zero porting.
Lift------ int
.100---70.2
.200--146.8
.300--216.4
.400--271.1
.500--304.8
.600--297.3
.700--310.4
That dip around .600 lift can a little tough to get rid of.
I guess I should clarify the size thing......
Making them bigger doesn't guarantee you'll get big numbers out of them.
The other side of the coin is.......if you keep them on the small side, you're only going to get so much out of that too.
