Aftermarket Retainer ? #2383121
10/06/17 08:48 PM
10/06/17 08:48 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Aftermarket Retainers with oem valves and locks.... is it possible in any form or fashion?
Ive some hughes retaines for a bit more height and outwardly they seem to fit and are a bit more snug then the oem retainers?
Any red flags here?
Thanks.
Re: Aftermarket Retainer ? [Re: Porter67] #2383141
10/06/17 09:47 PM
10/06/17 09:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
part number of the hughes retainer would go a very long way to answering the question.
Hughes lists 9 different part numbers for retainers
Don't be the exception.
Re: Aftermarket Retainer ? [Re: Porter67] #2383163
10/06/17 10:14 PM
10/06/17 10:14 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Your very right.
Ive got the 1252 and 1254 retainers to consider.
Gonna use the 1110 spring, maybe the 1111 spring.
509/280 mopar solid cam
This is my budget but new small valve 318 heads and I have the new oem valves, did the 3 way and a small back cut on the valves.
Kinda hard to find aftermarket single groove valves that are not costly, the 2.02/1.60 sets are dirt cheap since there so common.
Re: Aftermarket Retainer ? [Re: Porter67] #2383173
10/06/17 10:26 PM
10/06/17 10:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ok, both 1252 and 1254 are 7 degree retainers, which is what stock locks need.
Odds are the Hughes retainers were made with a bit more care and on newer tooling than the original retainers.
Re: Aftermarket Retainer ? [Re: Porter67] #2383230
10/07/17 12:20 AM
10/07/17 12:20 AM
P
Porter67 Offline OP
Porter67  Offline OP
P
Thank You, I can get new keepers off ebay cheap since the old ones ive got seem a bit worn.
There is only like a 2 gram weight difference as well.
