front end travel limimters? show me what you have please. #2383084
10/06/17 07:11 PM
10/06/17 07:11 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline OP
I need to put some on my car. I am looking for a clean,easy and light weight method to do it.
Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan] #2383085
10/06/17 07:17 PM
10/06/17 07:17 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Made some.
Front End Limiters June 2008 1.JPGFront End Limiters June 2008 3.JPGFront End Limiters June 2008 5.JPG
Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan] #2383099
10/06/17 07:38 PM
10/06/17 07:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont like metal on metal so I used a cable
and a valve spring.. I started with 2 valve
springs but ended up with 1 so it would slow
it up and not shock the system.. worked well..
that was on my old 69 Valiant
wave
Re: front end travel limimters? show me what you have please. [Re: MR_P_BODY] #2383113
10/06/17 08:12 PM
10/06/17 08:12 PM
gregsdart Offline
gregsdart  Offline
wave
I used old rubber shock biscuits, eye bolts and cable to produce the same effect; a smooth transition from travel to stopped. I went from the upper a arm upward to the cage tube above it.
Re: front end travel limimters? show me what you have please. [Re: MR_P_BODY] #2383371
10/07/17 12:43 PM
10/07/17 12:43 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I don't either. If I didn't install the Alterkation front end I would have made it a rubber stop. But I was going for quick and easy adjustability which this setup provided. I looked at using a cable but didn't like that solution with the stock front end so this is what I came up with.
Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan] #2383381
10/07/17 01:06 PM
10/07/17 01:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Unless its light on the nose with an aluminum block it'll need the travel. Mine is 54.5% (mega block, steel frt end) on the nose with 113" wb. I'm ready to give it even more. You can tighten the front rebound for a better method of control. Poor track conditions with good power will need the travel.
Doug
