Page 1 of 6 1 2 3 4 5 6 >
#2379636 - 09/30/17 09:56 PM For Sale - Race Parts - 4th Quarter
moparts Offline
#2379741 - 10/01/17 01:49 AM JW Trans powerglide [Re: moparts]
440W8 Duster Offline
Loc: San Antonio,TX
I have a JW trans Ultra Case Ultra Bell Roller tail shaft with 8in stalls at 5400 UCC converter with flywheel for a Small Block for sale or trade has Pro Brake 1.80 straight cut gears asking $3000 or
trade for a 904 or 727 with pro brake billet front drum and 8in converter with similar stall and a CSR fiber shield plus some cash my way.
Edited by 440W8 Duster (10/01/17 01:53 AM)
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
#2379842 - 10/01/17 09:32 AM Small Block Mopar Top end NEW [Re: 440W8 Duster]
DaKuda Offline
Loc: Down South
$3500
OPEN TO TRADES FOR....?
Sold my car so I don't need. Only reason for selling.
Small Block Mopar Top end.
All parts bought new from Marsh Performance.
All port work done by Larry Smith....well know Mopar cylinder head porter.
Everything is Brand new unused in boxes.
1. Sidewinder aluminum heads
2. Edelbrock Super Victor intake
3. COMP Cams Pro Magnum Shaft Mount Roller Rocker Arms 1622-16
Heads are Competion ported and work is absolutely TOP notch.
Super Victor intake is also competition ported.
All done by Larry Smith.
Specs are as follows:
Intake numbers
.100 78
.200 148
.300 202
.400 249
.500 291
.600 320
Exhaust
.100 66
.200 111
.300 159
.400 192
.500 200
.600 215
Valves are Ferrea F6203 and F6202 which are the 6000 series valves in 2.08 and 1.60 sizes with 11/32 stems they are 5.06 long with single groove valve locks.
Comp Cams 943-16 valve springs
Comp Cams 611-16 valve locks
Comp Cams 749-16 Retainers
11/32 Viton Valve seals
Manley spring cups
#2379887 - 10/01/17 10:46 AM Small Block 3.58 Stroke Forged Crankshaft - 340 Main - New [Re: DaKuda]
Rocket Offline
Loc: CT
I have a new Mopar Performance 4340 Forged steel crankshaft with stock 6 bolt small block flange still in the box. Fits 273-318-340 main engine blocks. I bought this for a project that I will not get to. It is standing in the corner and want to offer it to someone who can use this. It requires the use of a Chevy connecting rod - 2.100 in rod journal. In a 340 block with stock bore the engine will displace 367 ci and with a 0.030 overbored 340 block the displacement will be 373 ci. Here is the description from Mopar Performance.
Surface hardened, forged Small Block Crankshafts feature radiused fillets at main and rod journals. Each features a 6-bolt flange and is forged from 4340 steel. 3.58" Stroke, 50 lbs., 2.100" Rod Journal, Generic Rear Flange, 340 Main.
Price is $750 shipped in the lower 48 states.
Email me at procketrichard@hotmail.com with any questions.
#2379896 - 10/01/17 10:52 AM Small Block W2 Harland Sharp Rocker Set Up - New 1.5 Ratio [Re: Rocket]
Rocket Offline
Loc: CT
For sale is a new set of small block Mopar Harland Sharp aluminum roller rocker arms, shafts and blocks for the W2 and W5 Mopar Performance cylinder heads. Intake and exhaust rockers are 1.5 All rockers, shafts and blocks are new. These rockers can be used on W2 heads with milled pedistals and W5 small block Mopar cylinder heads.
Part number S70025W2k.
Description from the HS site and some links are below.
* Needle bearing allow for more oil flow to the rockers.
* Oil restrictors may be necessary to maintain oil pressure.
* Rockers are designed for big lift cams requiring .100 to .150 taller valves.
* Rocker shafts are drilled to allow for 3/8 mounting hardware.
* Rocker spring clearance is limited to 1.500 if more spring clearance is
required, contact our customer service department to discuss your options.
* W2/W5 Race kits come with .180 offset shafts & stands.
Instructions
Harland Sharp needle bearing, single shaft mount, rockers for Small Block
Chrysler are like no other on the market. The only shaft rocker of this style to feature heavy duty needle bearing fulcrums matched with specially heat treated, heavy wall, rocker shafts. Harland Sharp Mopar kits are designed for extreme applications with valve springs up to 1.500 diameter and .900 lift cams. The
7/16-20 x 5/16 ball adjusters are designed for use with the factory style pushrods, length to be determined after you have rockers installed. Harland Sharp SB Mopar kits require taller valves. Approximately .100-.150 are necessary for correct geometry but sometime lash caps can be used. Kits include rocker arms, shafts, spacers, rocker stands, adjusters and nuts. See our instruction link for replacement and service parts #s.
New price for kit including rockers, shafts and blocks is $1,180 at summit. I will sell my new set for $975 shipped in the lower 48 states. Feel free to contact me to discuss.
Email procketrichard@hotmail.com for more information.
#2379899 - 10/01/17 10:59 AM Small Block Fluidampr - New [Re: Rocket]
Rocket Offline
Loc: CT
I have a new small block fluidampr that I purchased but will not be using. I purchased this a number of years ago and has been boxed and on the shelf.
Price is $375 shipped to the lower 48 states.
Contact procketrichard@hotmail.com for more information
#2379901 - 10/01/17 11:03 AM Small Block 360 4 Bolt Iron Main Cap Kit - New [Re: Rocket]
Rocket Offline
Loc: CT
I have a new 4 bolt main cap kit Mopar Performance part # P5249675 for 360 engines. These are the same main caps used for Mopar R series race blocks. They are ductile iron. They are a superior material to stock caps and use more material for strength. You can use these on a stock 360 block without using the outer bolt holes. Some builders cut off the outer 2 bolts for ease of installation. A great upgrade for stroker engine builds. Kit comes with 4 caps and bolts.
I used a similar 340 main kit on a 340 stroker I built and machined off the outer two extra bolt holes. Fit perfect.
This 360 main cap kit lists for $180 on summit. I will sell it for $140 shipped in the lower 48 states.
Contact me at procketrichard@hotmail.com with questions
Edited by Rocket (10/01/17 11:04 AM)
#2379935 - 10/01/17 12:09 PM A12 Six Pack Carbs [Re: Rocket]
70sixpkRT Offline
Loc: South San Francisco, Ca
I have a set of Six Pack manual carbs for an A12. Front: Date code 1229 part# 4393. Center: Date code 1229 part# 4391 for manual. Rear: Date code 0929 part# 4394. All 3 carbs are untouched and in good condition.
$1600 + shipping.
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
#2380017 - 10/01/17 02:17 PM MSD 6Al BTM. [Re: 70sixpkRT]
dodge turbo Offline
Loc: Dirty Dena, Maryland
Replaced this with a programable ignition
Everything words good. Comes with timing retard knob.
$150
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
#2380062 - 10/01/17 03:30 PM MSD 2 STEP with adjustable chip [Re: dodge turbo]
dodge turbo Offline
Comes with adjustable MSD rpm chip
$50
#2380117 - 10/01/17 04:51 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
Low deck six pack intake. New, never used. $375 plus shipping. PM me on the board, check, money order or PayPal for payment.
#2380118 - 10/01/17 04:52 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
RB distributors. MSD ready to run $300, 440Source ready to run for $40. Shipping extra. Check, money order or PayPal for payment. PM me on the board.
#2380121 - 10/01/17 04:54 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SS hangers for E body car. These are new Mopar Performance parts. Never used. $40 for the pair plus shipping. PM me on the board. Check, money order or PayPal.
#2380125 - 10/01/17 05:01 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD
Edited by AndyF (10/03/17 01:09 PM)
#2380127 - 10/01/17 05:03 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
Old school fuel filter. I have a new housing with a new filter element. The old housing on the left is cracked. $40 plus shipping. Check, money order or PayPal for payment. PM me on the board.
Edited by AndyF (10/01/17 05:05 PM)
#2380129 - 10/01/17 05:05 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
Sold
Edited by AndyF (10/04/17 12:34 AM)
#2380132 - 10/01/17 05:09 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
AndyF Offline
Loc: Oregon
SOLD
Edited by AndyF (10/13/17 08:22 PM)
#2380193 - 10/01/17 07:07 PM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
gregsdart Offline
Loc: Frostbitefalls (Rocky&Bullwink...
Gen 3 parts
Nib Apache heads, loaded $1200 shipped
Complete intake system , loaded as it came off 485 hp crate motor, zero time on it. $450 shipped
Helcat blower, needs front bearing (typical warrantee problem) $ 1600 shipped
5.7 core motor, eveything but valve covers make offer
Jeep srt8 exhaust manifolds, $400 shipped
Scat 6.2 long sbc hbeam rods frm same 6.1 drag pack motor, 2.1 bearings on rods .927 pins, warm up time only, $230 shipped
Stock dual plug coils from newer 6.1, $80 shipped
Molner 3.888 stroke Gen 3 hemi crank, $600 plus freight
Possible package deal
5.9, 5.2 Magnum parts
Standard length Magnum engine stainless steel 2.02 intake valves (already back cut 30* angle), 1.62 exhaust valves, new in box. Springs, retainers, keepers, seals and locks, new, never opened. New, 399 +$30 for back cut, from Hughes, $340 shipped
5.2/5.9 Magnum hydraulic roller cam from Comp, 225 dur at .050 int, 225 dur at .050 ex, 107 lsa, .480 lift. $220 shipped
Small block distributor FBO advance limiting plate and Mr Gasket spring kit, $25 shipped
BB parts
6 2.25 intake valves for 440-1 heads $75
8 2.19 intake valves for 440-1 heads, $120
three sets ball to ball pushrods, one low deck for Jesel , two high deck for Jesel, 3/8, Indy 3/8 heavy wall. Make offer.
One set ball to cup 8.60 length pushrods, make offer.
Rocker shaft retainer kit for Indy 440-1 original rockers $190 (?) from Indy, $100 shipped
Greg 763 439 2129 gregsdart5547@yahoo.com
Edited by gregsdart (10/01/17 08:04 PM)
GREG
Educated at SHK U
Measure with yardstick
mark with chalk
cut with torch!
528 cubic inch alky injected 440-1 wedge, 3055 race weight.
8.779 at 153.16 mph. 1.289 60 ft. density altitude 1617 feet. Best 60 ft 1.24
#2380510 - 10/02/17 10:11 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
an8sec70cuda Offline
Loc: Marion, South Carolina [><]
Digiset timer...used for my nitrous. Nothing wrong w/ it at all. Comes w/ the base and instructions.
$75 shipped in the lower 48
Titanium valvespring retainers, set of 16. Very little use.
For 1.550" springs and 10° locks, Overall OD is 1.500", small step is .720", large step is 1.120"
$100 FIRM shipped in the lower 48, paypal accepted if you cover the fee
PM me here or call/text 843-431-8376
CHIP
'70 hemicuda...8.91 at 150.5 mph street car...Mopar Action feature Dec. '14
'69 road runner 446" w/ Indy SRs
'69 road runner 440-6, 4 speed...Dad's ride
'71 Demon 340 resto project
'01 Ram 2500 QCSB 4x4 Cummins...toy hauler
'16 Grand Caravan SXT...baby hauler
#2380530 - 10/02/17 10:41 AM Re: For Sale - Race Parts - 4th Quarter [Re: moparts]
Billy Offline
Newest Village Idiot
Loc: Chicago adjacent
1968 Dodge Dart fiberglass fenders excellent quality and in perfect condition! I am converting my Dart back to original therefore I do not need the fenders
$250!!!
Located outside of Chicago
24,903 Registered Members
184,386 Topics
Advise on setting cedar posts
by StrokerPost
10/24/17 01:21 AM
Ok, so who all is going to Fall Fling??
by dart4forte
10/24/17 12:33 AM
Dome light glows when map light is off
by 3XBlack6packGTX
10/24/17 12:32 AM
Converting rims to bead locks, who does that?
by Cab_Burge
10/24/17 12:14 AM
