#2383084 - 10/06/17 05:11 PM front end travel limimters? show me what you have please.
64hemi330sedan Offline
Loc: OHIO THE HEART OF IT ALL
I need to put some on my car. I am looking for a clean,easy and light weight method to do it.
#2383085 - 10/06/17 05:17 PM Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan]
markz528 Offline
Loc: Milford, OH
Made some.
67 Coronet 500 (street car) 13.300 @ 101.75 mph
#2383099 - 10/06/17 05:38 PM Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan]
MR_P_BODY Offline
Loc: Romeo MI
I dont like metal on metal so I used a cable
and a valve spring.. I started with 2 valve
springs but ended up with 1 so it would slow
it up and not shock the system.. worked well..
that was on my old 69 Valiant
wave
W-9 8.94 @ 151 NOW ON E-85
Mike "Raff"...(180)Watching over us
CAR IS FOR SALE
#2383113 - 10/06/17 06:12 PM Re: front end travel limimters? show me what you have please. [Re: MR_P_BODY]
gregsdart Offline
Loc: Frostbitefalls (Rocky&Bullwink...
wave
I used old rubber shock biscuits, eye bolts and cable to produce the same effect; a smooth transition from travel to stopped. I went from the upper a arm upward to the cage tube above it.
Edited by gregsdart (10/06/17 06:15 PM)
GREG
Educated at SHK U
Measure with yardstick
mark with chalk
cut with torch!
528 cubic inch alky injected 440-1 wedge, 3055 race weight.
8.779 at 153.16 mph. 1.289 60 ft. density altitude 1617 feet. Best 60 ft 1.24
#2383371 - 10/07/17 10:43 AM Re: front end travel limimters? show me what you have please. [Re: MR_P_BODY]
markz528 Offline
Loc: Milford, OH
I don't either. If I didn't install the Alterkation front end I would have made it a rubber stop. But I was going for quick and easy adjustability which this setup provided. I looked at using a cable but didn't like that solution with the stock front end so this is what I came up with.
#2383381 - 10/07/17 11:06 AM Re: front end travel limimters? show me what you have please. [Re: 64hemi330sedan]
dvw Offline
Loc: MI, usa
Unless its light on the nose with an aluminum block it'll need the travel. Mine is 54.5% (mega block, steel frt end) on the nose with 113" wb. I'm ready to give it even more. You can tighten the front rebound for a better method of control. Poor track conditions with good power will need the travel.
Doug
25,083 Registered Members
185,774 Topics
5.7 hemi to viper t56 w/ quicktime rm8077, twin disc clutch?
by Silver70
41 seconds ago
1968 Barracuda- Gold interior questions
by copperSwinger
5 minutes 54 seconds ago
Compact Tractor
by DusterKid
36 minutes 36 seconds ago
Auto battery Restoration
by 70RRINVIOLET6PAK
42 minutes 50 seconds ago
